Old 04-16-2013, 10:46 PM   #1
FordFighter
FordFighter's Avatar
small trouble,little advice wanted.TH350
Two bolts thru the crossmember brace the rear of the tranny,the edge of the cross member keeps me from taking the rest of the bolts out to drop the pan to service the thing.Whats the proper order to line the crossmember/trans mount bolts once I finish getting everything out of the way/servicing the trans?
Work on your truck and work your truck your my kind of people,
Love my ol'20..
FordFighter is offline   Reply With Quote
Old 04-17-2013, 01:08 AM   #2
stsalvage
Scrapper 1
stsalvage's Avatar
Re: small trouble,little advice wanted.TH350
there should not be anything in the way.the tranny pan bolts are at least 2 inches away from the mount it self.Now If you had a 3 on the tree and left the cross member then you have a problem.If you have to.You can undo the 5/8's bolts that bolt the mount the the trans get a jack and gently jack up the tail shaft remove the mount then the bolts are right there
stsalvage is offline   Reply With Quote
Old 04-17-2013, 05:27 AM   #3
JimKshortstep4x4
I use a 1/4" drive setup with a 1/2" swivel socket for the two bolts in question. I have not run into the issue of a wrong cross member, though.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-18-2013, 07:13 PM   #4
FordFighter
The cross member looks to be right where it's suppost to be,how else would you mount the transmission?
theres two bolts....that I can't get to holding up the back of the transmission pan,the only way to get to them is to drop the duel exhaust and move the crossmember out of the way,it's a TH350 short tail shaft,
you telling me the cross member isn't correct?
Love my ol'20..
Old 04-19-2013, 01:38 AM   #5
BlackedOut67shorty
BlackedOut67shorty's Avatar
I know my crossmember was a custom made one from the po and I always have to move it out of the way to service my tranny... Very quite annoying to do
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
