Old 04-17-2013, 01:41 AM   #851
mosesburb
I had a V-8
mosesburb's Avatar
Re: The Story Of A Cummins Suburban (Lots Of Pics)
Originally Posted by Dieselwrencher View Post
I will. It idles steadily and is the quietest 24v I've ever heard.
Yeah, I bet it's absolutely silent.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 04-30-2013, 01:24 AM   #852
mosesburb
I had a V-8
mosesburb's Avatar
Well, with all this chat about oil coolers I think I should give an update here. In trying to consolidate my biohazard by separating as much of the oil and coolant as I could, I stumbled across the box with my old oil coler core in it. I had been trying to devise a way to pressure test it to see exactly where it failed. I decided that since I drained the cooling system through the oil pan drain plug I should be able to fill the cooler with water and notice a massive leak pretty quickly.
So I did. I filled it with water and let it sit.
And sit.
And sit.
I guess it has been about a week and a half now and it is still holding water and there is no hint of moisture near where the cooler is sitting, leading me to believe what the first person I called after the catastrophe (Dieselwrencher) had told me. He said that most likely the gasket had failed and not the cooler. Now, I had no reason to doubt him, but in my situation, being far from home and on a very tight time-frame, I opted to change everything in the hole to be as sure as I could that everything was tip-top and ready for the 425 mile trip home through the Great Sonoran Desert.
It's good to know that the cooler didn't fail. I will now recommend oil cooler gasket changes to everybody I know that has a B series motor. They are not difficult to do in a controlled environment and the mess they can prevent makes the effort well-worth the time.
Old 04-30-2013, 05:52 PM   #853
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I don't blame you one bit for replacing it all. That could have been a really bad deal. AKA rebuild engine and a tow home. Not cool. It's pretty crazy how these early gaskets are way inferior in design compared to the parts they sell now.
Ryan
1969 Chevy milk truck
Old 04-30-2013, 08:34 PM   #854
ryanroo
ryanroo's Avatar
this is a non conclusive test in your neck of the woods. it could be completely empty of the test fluid and you would have never seen the evidence. water does not stay around in liquid form on the surface of the sun.
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 04-30-2013, 09:02 PM   #855
6lcummins
Ryan
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 05-01-2013, 01:24 AM   #856
mosesburb
I had a V-8
mosesburb's Avatar
That is pretty much why I did it. Hard to roll the dice on a replacement motor and all the labor and bs associated with that when a cooler and gaskets were a few hundred dollars. If I was at home, I probably would have done it differently, but it's hard to justify possibly saving a few bucks and risk a motor, the rest of a vacation, etc.
Yeah, the new inner gasket is a thing of beauty compared to that wretched fiber/concrete gasket from the old days. Ugh.
Ryan
Bah, it was only 102 yesterday and I think it only hit 100 today, so it's not hot yet. It won't be long, but not yet....
Old 05-01-2013, 08:43 AM   #857
hgs_notes
GEARHEAD
hgs_notes's Avatar
Only a hundred he says. I took this about 10 minutes ago...
hgs_notes is offline   Reply With Quote
Old 05-01-2013, 09:49 AM   #858
RatRod68
RatRod68's Avatar
eff. That.
build Threads:
Nasty 68 C10. My lil hotrod
Leftovers 68 C20
D-Ranged Ford Ranger on steroids
Semper Fi
RatRod68 is offline   Reply With Quote
Old 05-01-2013, 01:06 PM   #859
jbclassix
Junk Yartist
jbclassix's Avatar
Originally Posted by RatRod68 View Post
eff. That.
I'll take the white stuff if you don't want it.
You got us beat Nick, it was only 99 here
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 05-01-2013, 01:11 PM   #860
RatRod68
RatRod68's Avatar
you sir, can have it. I'm much happier with the 5683905675830 degree heat. As long as the A/C works
build Threads:
Leftovers 68 C20
Semper Fi
Old 05-01-2013, 03:58 PM   #861
Dieselwrencher
I'll take the dry heat and no snow!
Ryan
Old 05-01-2013, 08:45 PM   #862
ryanroo
ryanroo's Avatar
We get snow, we get dry heat, we get NO humidity. its about 70 today and sunny
WIN
72 K20 12v build
Old 05-01-2013, 10:02 PM   #863
6lcummins
WIN
I dislike you on so many levels now...
"STOCK"
ASSEMBLY THREAD
Old 05-02-2013, 07:14 AM   #864
RatRod68
RatRod68's Avatar
right there with ya buddy!
This snow stuff is for the birds! That is the one thing that makes the craziness of southern california bearable... The weather is AMAZING
build Threads:
Leftovers 68 C20
Semper Fi
Old 05-02-2013, 07:50 AM   #865
ryanroo
ryanroo's Avatar
You guys are crazy! snow is nice. and so is cold. i also like warm and sunny, so i guess i picked a good spot.
72 K20 12v build
Old 05-02-2013, 11:16 AM   #866
Dieselwrencher
Snow in May, not my idea of fun son.
Ryan
Old 05-02-2013, 11:56 AM   #867
jbclassix
Junk Yartist
jbclassix's Avatar
Did we hijack enough yet?
-Jeremy
Rebuilding an NP205
Old 05-03-2013, 03:18 PM   #868
6lcummins
March 3, 2013....
10-12" of snow
I was done with snow 2 months ago...
"STOCK"
ASSEMBLY THREAD
Old 05-03-2013, 03:19 PM   #869
6lcummins
Officially HiJacked...
"STOCK"
ASSEMBLY THREAD
Old 05-03-2013, 09:04 PM   #870
ryanroo
ryanroo's Avatar
sitting outside the fabled coffee shop, finger in the air sipping a nice brew. in a t shirt. totally comfortable in the sunshine...
72 K20 12v build
Old 05-03-2013, 10:18 PM   #871
6lcummins
Fu
"STOCK"
ASSEMBLY THREAD
Old 05-08-2013, 09:42 PM   #872
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Hey mosesburb... it's me, Mike (ExpoMike on ExPo). No idea why I never saw this post before or even figured out you were on this site too.
I am really glad everything worked out in the end and still more than happy to have been part of getting you guys back home safely. It was quite a day but seeing you guys driving out of Rick's place and to your hotel, to continue your trip, was worth it all.
Glad you it sounds like you got things cleaned up and no serious damage was done. Stay in touch and we'll definitely get in touch next time we ever get to Phoenix.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-09-2013, 01:56 AM   #873
mosesburb
I had a V-8
mosesburb's Avatar
Hey Mike!! Yeah, yet another internet back-alley that I hang out in.
I'm glad everything worked out as well as it did too. No way we could have driven out of there that night without your help. I gotta say, I'm REAL glad the brakes worked when I backed out of Rick's driveway. That would have been totally deflating to get to that point after all that thrashing and not be able to drive it because of improperly functioning brakes.
It all seems good. I am getting ready to do a final flush on it here soon. There is just an ever-so-slight film in the reservoir, so I think another flushing and I'll be good to put the high-dollar Rotella ELC back in it.
I'm not sure how much of this novel you read, but it looks like it was the gasket and not the cooler that failed. I filled the cooler up with water awhile back and it is still holding all of it. Not an actual "real" test, but with the amount of coolant we had coming out of the oil pan drain plug, if it was the cooler core, it would have leaked SOMETHING by now and it hasn't.
Are you going to OEX??
Old 05-09-2013, 02:53 PM   #874
chevy_mike
chevy_mike's Avatar
Yeah I was reading the last couple pages. Weird as it didn't look like the gasket was bad but who knows.
We were planning on OEX but my '64 wagon ate a piston and having to deal with the cost of getting this fixed, blew any budget for that trip. We ended up cancelling our reservation. Hopefully next year!
Old 07-25-2013, 03:32 AM   #875
mosesburb
I had a V-8
mosesburb's Avatar
One of the things I learned last year on our trip was that the spare tire and water can/s were taking up way too much valuable interior space. I was looking at some swingout tire carrier designs and while many had some positive attributes, none seemed to be exactly what I wanted. Both Larry and Bill use double swingouts which have their benefits (light weight, easy to manufacture, loads per side are less than one single swingout), but having to unlatch two swingouts every time I needed to get in the back was not desirable. I had discussed their designs at some length with them and I think it was Bill who had run a single at one time and his biggest complaints were that the thing was heavy, hard to keep open and too long. I figured with a good pivot the heavy and keeping it open could be dealt with and I figured the length would not be such a problem. I started researching how I could do it. I contacted a couple well know pivot suppliers with my idea and they said their pivot spindles did not have the capacity I needed. They spoke from experience. They had failures with single swingouts with similar loads to what I was wanting to put on them. Hmm what to do?? I got an idea. The idea was nothing without a bumper to put it on so I started making a bumper.
I started with some 1/2" x 4" cold rolled flat stock to make the brackets. I flame cut it to the shape I needed with all the intricate notches and angles pre-figured into it. I then took a piece of 1/2" x 4" flat stock, cut it lengthwise so it was 2" wide and welded that to the main brackets. It extends forward to reach the first bolt hole in the frame. This would get me close to the 1.125" that a recovery shackle normally uses.
Then I took a piece of 2.5 x 2.5 angle and cut the vertical leg down to 2.25". I put a piece of 1/4" x 3" cold rolled on top of that and welded the length of it to the top of the angle, then make a mount for the pivot plate: (it's upside down in the pic)
Now, for the pivot, I decided to use a splined hub assembly off of a 10 bolt front axle. I took it to Russ to have him machine off everything that it had that wasn't a swingout pivot part. He removed the mounting flange where the spindle mounts to the knuckle and the flange from the hub that mounts the rotor and ultimately the wheel leaving me a splined "cylinder". He also machined a hole in a piece of 1/2" plate to fit the OD of the spindle into. That plate fits into the bracket on the bottom (top in the pic) of the bumper: (The plate is intentionally large so I can cut it down as I figure this out)
Plate tacked in with splined hub on it. Notice the second mounting bracket for the plate. It is the same as the first one, but taller to reach the upper plate of the bumper:
Swingout tube fitted to splined hub ready for welding:
The splined hub acted like a dirty cast iron when it was machined so I got some Eutectic 680 rod to use as filler and TIG welded it to the swingout tube after preheating the hub and peening it with a needle scaler as I went. Necessary?? Not sure, but I know I don't want a failure of this connection.
In along here somewhere I decided on a latch to secure the swingout tube to the fixed bumper. That is a standard cooler it is sitting on:
Figuring out the rear cover plate:
I used 1/8" cold rolled flat stock to make the filler plate out of and when I finished I added a piece of 1/8 x 1" flat stock welded at a 45* angle to enhance strength and aesthetics:
I used a standard receiver tube to mount the wheel flange on. The wheel flange is 3/8" plate. I cut the outside with the plasma cutter. I need more practice on the heavy stuff as I had a real challenge with it. 1/4" and less--no problem, but with the heavier stuff I need to figure out the settings a little better. That being the case I flame cut the square hole to fit over the receiver tube so that I would have no issues with that.
About this time I figured out that Bill and Larry had valid points about the length of a single swingout. It doesn't seem like much until you swing it out and it hits the welder in the garage. Something needs to be done here. I don't want two swingouts. Hmm.
Upper hoop installed:
So, after quite a bit of butt scratching and endless staring at the situation I came up with a plan. I got another toggle clamp like the previous one pictured (but much smaller), made a coule hinges out of some DOM tubing and 5/8" bolt shanks for hinge pins, added it all together and came up with this:
Swing it out and realize it is going to hit whatever is behind it:
Throw the latch on the main tube and fold the tube inward:
Keep going until it folds up into a nice wad over on the side of the vehicle--problem solved!! The simple functionality of a single swingout when clearance is not an issue, but the compactness of dual swingouts when space it tight:
I wanted to reuse the original license plate mounting assembly from the original bumper, but of course that wouldn't fit....so, I had to make my own:
Main latch mounted. It has reinforcements behind the plate on the bottom and inside the tube on the top.
So now I have a tire mounted. What to do about the water cans and propane cylinder. I was talking with my friend Lance and he had a Sportsmobile van that had a box mounted on one of the swingouts. He loved it and it sounded like a great idea so I started searching one out. I found that they are tremendously expensive (for aluminum). Also, I was having a real difficult time finding one that was close to the dimensions that I needed. They were either a bit too small or way to big. I found one that was kind of close, but was too deep. I figured I could cut it down and weld it back together, but then I took a step back and thought about it and I was going to spend $500.00 on a box and cut it up?? Steel is cheaper, but twice the weight--not good. I started looking at the weight per square foot of material and I found that expanded steel is approximately the same weight as aluminum sheet metal. Obviously it is not as opaque, but I don't really care at this point (I'm getting close to the end of my available timeframe). Expanded metal it is. I fabbed up a framework using 2x2 x 1/8 angle for the bottom (sides taper to 1" at the back) and 1 x 1 x 1/8" angle for the rest of it, then cut the expanded metal to fit in the openings:
I made a jig for my plasma cutter so I could cut e-track holes at strategic points in the structure so I could use common e-track components to secure the contents easily.
I'm not enamored with the aesthetics of the box, but it is secure and functional. I can deal with the aesthetics later. I tore it all down and had it powdercoated. I usually paint everything, but this is going to be in the line of fire for rocks and trail debris kicked up off the tires so I figured I'd give it a fighting chance of survival with some powdercoat.
Reassembly. Got some work out of the boy: (Yes, he is installing a Rotopax mount)
Here is the finished product: (the gas can is for when we take a Honda Generator with us. It's rare, but I don't want to add it later....)
So there it is. One bumper that I would be completely and thoroughly embarrassed to admit to even 10% of the amount of time I have in fabricating it. Does it work?? Absolutely beautifully. I have not found anything I would have done differently--yet?? I am planning on doing something about the box and I have some ideas, but I have some other things that are taking precedence right now. We'll see what I come up with.
