Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board
Old 04-18-2013, 02:55 PM   #1
cal30_sniper
cal30_sniper's Avatar
SOLD Milodon High Volume Water Pump, 350 Chevy Serpentine, Low Miles
Hey all,
I've got a serpentine belt style Milodon High-Volume pump with only 12k miles on it that I need to get rid of. I used it for about 9 months on my old 1990 Suburban before I switched over to the Big Block. It kept the 350 below 165 degrees all the way down from Maryland to Texas during the August heat while towing a boat (at 70-75 mph in 100+ degree heat), and I had it weighed in at the truck stop at 11,000 lbs with the trailer.
In my opinion, its the best waterpump out there for the cost. I'm running one on my 454 too. The only other pump I trust is the Edelbrock 8881, which is what I have on my GTA. These are very sturdily built, and it made a big difference over stock in cooling. It runs $89 new from Summit http://www.summitracing.com/parts/MIL-16213/. I'm asking $49 shipped (or $35 picked up locally).
I installed it after doing a double system flush with Peak Radiator Flush. After the flush, I drained ALL coolant from the engine until it was running straight distilled water. I then added the proper amount of concentrated Peak Lifetime Antifreeze to bring it up to a 50/50 mixture over the complete system (complete capacity given by the factory service manual). I also added Water Wetter additive for the seals. The motor it was on only had 30k on it (the pump went on at the same time that I put the Vortec heads on, and it was clean as a whistle inside). There's still a huge amount of life in the pump, I'd say it's barely broke in.
I'll mark it as soon as it's sold.
-cal30sniper
In case you didn't click on the link, this is a reverse rotation water pump for an '88-up Serpentine Belt system small block.
86 Chevrolet K20/30 Suburban - 8.1/NV4500/NP205/Dana 60/14 bolt FF, build in progress
73 Formula - 400/Doug Nash 4+1, resto on hold
86 Chevrolet K30 3+3 - 350/TH400/NP241, Air Force/Forest Service Rescue Truck, for sale
01 Ram 2500 - 5.9L Magnum, daily driver
91 BMW 325i - Chumpcar series racecar
cal30_sniper is offline   Reply With Quote
