04-18-2013, 08:11 PM | #1 |
key switch/ignition
Ok to start out i got this truck from a friend and it was running when i got it...i started tinkering and i went to start it and nothing happened when i turned the keys...i pulled the starter off and crossed the hot wire over to the start terminal and it engaged,is this a key switch problem? Or bad solenoid? Ps how do you get the key switch out to change it,i broke that looking for the problem
Posted via Mobile Device |
04-18-2013, 08:16 PM | #2 |
Re: key switch/ignition
turn the key full left to ACCY, insert object into hole depressing pin. turn key& cylinder left and pull out. To remove ignition switch from dash unscrew bezel, unhook electrical from the back and then remove.
04-18-2013, 08:35 PM | #3 |
04-18-2013, 08:36 PM | #4 |
How does the bezzel come off?
04-18-2013, 09:17 PM | #5 |
You have to take the tumbler out as mentioned above, the the bezel just unscrews.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
04-18-2013, 10:05 PM | #6 |
72 GMC super custom. |
04-19-2013, 12:32 AM | #7 |
Any special way to unscrew the bezel because mine wont budge
04-19-2013, 12:53 AM | #8 |
If you have the tumbler part out then u can maybe use a flat head screwdriver in the notches on the bezel with some tapping of a hammer counter clockwise to get it started
04-19-2013, 01:01 AM | #9 |
That worked with half swing of the hammer just very Tight......anyone know about the original problem?
04-19-2013, 01:06 AM | #10 |
I know another guy had some wires come loose in the ignition. Just wore out?
04-19-2013, 02:23 AM | #11 |
Will find out i guess...im replacing starter and key switch assembly tomorrow, there is however a black wire coming off the fuse box that has an inline fuse that was blown but the wire was not hooked up,its labeled on the fuse panel as ignition but i have no clue where it goes
04-20-2013, 06:36 PM | #12 |
The black wire with the inline fuse coming from the ignition spot on the fuse panel....where does it go that is my highest suspicion
04-20-2013, 06:43 PM | #13 |
Maybe someone else will chime in. I would just follow it and find out
04-20-2013, 08:00 PM | #14 |
Your help is appreciated thanks a ton....when i get some time ill follow the wire off the start terminal on the solenoid and see where it goes because it isn't getting power i guess
04-20-2013, 08:02 PM | #15 |
Could very well be it
