Old 04-19-2013, 12:39 PM   #1
tex_waco_usmc
Project Heaven in my 67!!!
Lowering an 86
Can someone help me with a lowering question:
I want to get 3.5" front and 5" rear drop.
Whats the best way? Secondly, if I do the rear axle flip kit do I need to C-Notch my frame?
If I do, does anyone have any pics of their C-Notch. Mind you I dont want to cut a hole in the floor of my bed on this one.
tex_waco_usmc is offline   Reply With Quote
Old 04-19-2013, 12:52 PM   #2
Hook0215
Re: Lowering an 86
I was worried about the cutting holes in the bed thing too. I did 2 in spindles and cut 1 coil in the front springs. The rear however, I did 2 in shackles and 2 in hangers and to get the rest of the drop, I had my leaf springs de- arched 2 inches. I have a 305/35/20 on the rear and the wheell well sits right on top of the tire.
Hook0215 is offline   Reply With Quote
Old 04-19-2013, 01:05 PM   #3
tex_waco_usmc
Re: Lowering an 86
Can you post some pics of how yours looks? Maybe some pics while you were doing it? Ive never cut a coil out so I am a little nervous and I didnt even realize you could do hangers and shackles in the rear...
Old 04-19-2013, 01:26 PM   #4
Hook0215
Re: Lowering an 86
Not sure how to post pics from my ipad....
Old 04-19-2013, 01:30 PM   #5
J Knight
J Knight's Avatar
Re: Lowering an 86
Hook0215 it sounds like you did a 4.5/6in drop the hard way. It would have been easier to do a 5in flip and a 1-2in shackle. As far as the tire issue, what is your backspace on the wheels and how much room do you have from the outside of the tire to the fender lip? Also how much does the tire need to move out to clear the inner fender?
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 04-19-2013, 01:35 PM   #6
J Knight
J Knight's Avatar
Re: Lowering an 86
2.5in spindle, 1in spring and a flip kit. No c-notch needed.
John
Old 04-19-2013, 01:59 PM   #7
Hook0215
Re: Lowering an 86
You're right. I did a 2/4 and was not happy with the results. Was still too high.....
Old 04-23-2013, 10:58 PM   #8
tex_waco_usmc
Re: Lowering an 86
ok, the painful question:
Where to obtain the parts? Which are the best parts to use to do the rear axle flip and 2.5" spindles and 1" spring in the front?
Ive read many people talk about cutting their front springs... A little hesitant to do this but I know it isnt too hard. How much would I have to cut to get a 1" drop in the front to go with my 2.5" drop spindles?
Old 04-24-2013, 08:51 AM   #9
Jonboy
Slots go on anything!
Re: Lowering an 86
I bought the stuff I used for my '79 from Jeff at CPP. I had a great experience, but others haven't. Travis at AZ Pro Performance has a good rep here too. For the coil, start at 1/2 coil cut, and adjust from there. You may have to put it in and drive it a few times before you find your happy place.
Jonboy is offline   Reply With Quote
Old 04-24-2013, 09:03 AM   #10
tex_waco_usmc
Re: Lowering an 86
I just want to make sure I understand on the coil... When you mean cut 1/2 a coil basically just turn the coil 180 degrees from the current cut and cut it? if I wanted to cut 1 coil out then I would just cut exactly where the current cut is just one coil below?
Old 04-24-2013, 02:27 PM   #11
Jonboy
Re: Lowering an 86
Correct.
