Old 04-21-2013, 08:48 PM   #726
UPNADM
UPNADM's Avatar
Re: 1981 Chevrolet C50 Pick-up Conversion
http://youtu.be/7oMrSg6_PcE
My son wanted to go for a little spin today... Took a lot of arm twisting.
UPNADM is offline   Reply With Quote
Old 04-21-2013, 08:49 PM   #727
UPNADM
UPNADM's Avatar
Another view...
http://youtu.be/WLJfWNHv7Ck
Old 04-21-2013, 08:51 PM   #728
UPNADM
UPNADM's Avatar
Can anyone offer some assistance to me on how to have your video directly on your page? I am unable to get my head around this process..
Old 04-21-2013, 08:52 PM   #729
MadManAndrew
On the youtube page, copy the "embed" link to here.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 04-21-2013, 08:55 PM   #730
UPNADM
UPNADM's Avatar
On the youtube page, copy the "embed" link to here. - I have tried that, but I keep getting nothing...
Old 04-21-2013, 08:57 PM   #731
matchstick321
matchstick321's Avatar
Never thought I'd be jealous of a child. Haha The truck looks good on the road!
1979 chevrolet k-20 "O'l Blue" 350 muncie 465. Project in process.
matchstick321 is offline   Reply With Quote
Old 04-21-2013, 09:06 PM   #732
UPNADM
UPNADM's Avatar
Not a very busy day. Got the rear speaker pods hung.
Have some new Kenwood 4x10's on the way.
Old 04-21-2013, 09:08 PM   #733
UPNADM
UPNADM's Avatar
Any thoughts on this situation... Why GM ever thought putting torx heads on seat belts was a good idea is beyond me.
I have broke two bits on them now... I am hoping some heat and a pipe wrench will do the trick.
Any suggestions?
Old 04-21-2013, 09:10 PM   #734
MadManAndrew
Quality bit, penetrating lube, and some heat. They use them so they can't be easily removed.
Old 04-21-2013, 09:13 PM   #735
UPNADM
UPNADM's Avatar
I have got the first on moving a little on its own... I really was not in the mood to dick around with it today.
The donor C50 where I got the new belts was all bolts. It was a little older though.
Old 04-21-2013, 09:13 PM   #736
68Timber
I know the pieces fit
68Timber's Avatar
Cool! Why'd the grill and bumper need to come back off?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-21-2013, 09:18 PM   #737
chevybuilder18
chevybuilder18's Avatar
Any suggestions?
pipe wrench it with a cheater.. lol thats wat i do. of coarse your not me. i mean what harm would it do to that bolt? and for the sheet metal.. i think itd damage the sheet metal before itd damage that bolt....
Her name is Quicksilver
1978 Chevrolet silverado, shortbox stepside currently being swapped IN is a LM7 5300 vortec, 4l80E, factory 4.11s, slammed, a dream ride and coined QUICKSILVER
gotta pay $$ if you wanna play
chevybuilder18 is offline   Reply With Quote
Old 04-21-2013, 09:21 PM   #738
UPNADM
UPNADM's Avatar
I had to take the grill out to install my overflow tank for the radiator. Two of the bolts where easier to get at with the grill out. Never got it back in today.
As for the rear of the bumper, a couple things, I scuffed some of the paint when we did the fit for the new brackets and installation. And I need to finish installing the lights that are mounted in the bumper as well as the license plate lights.
I keep bouncing around my finish list, keep crossing things off. I keep saying to myself, do one thing, then the other, but I see something and it draws me to it.
As long as it all gets done... ha.
Old 04-21-2013, 09:23 PM   #739
motornut
78K & 79C Jimmys
motornut's Avatar
Any suggestions?
square them off like a bolt
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 04-21-2013, 09:26 PM   #740
UPNADM
UPNADM's Avatar
Good idea...
I thought worst comes to worst, I will get my cousin to come over and weld some nuts on the top of these bolts.
We have done this in the past to remove some broken wheel locks...
Old 04-22-2013, 08:08 AM   #741
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Using all of the heavy duty methods mentioned is asking for trouble. If you snap that bolt off you have a bigger problem to solve. Use good penetrating oil, top and underneath and some patience. Spray it every day for a week or so. Then have someone under the truck with a little propane torch to heat the welded nut up nice and warm next time. I'd bet it comes out and you won't be left with having to drill and remove a broken bolt stub.
Tx Firefighter is offline   Reply With Quote
Old 04-22-2013, 09:19 AM   #742
matchstick321
If I'm not mistaken those bolts are located above the saddle tanks so the only place to torch it from is the top.
Old 04-22-2013, 09:32 AM   #743
Tx Firefighter
I was looking at the pictures and it looks like he's just running that big square gas tank under the passenger side door. Looks like heat on the weld nut might be an option. I guess he's the only one can tell for sure what access he has under there. It would surely help if he can make it happen.
Old 04-22-2013, 09:37 AM   #744
UPNADM
UPNADM's Avatar
I can get under and heat them up. Lots of room.
Good idea, heat is always your friend in these situations...
Old 04-22-2013, 09:40 AM   #745
matchstick321
Oh yeah that's right! Duhh I haven't had my coffee this morning haha.
Old 04-22-2013, 03:19 PM   #746
motornut
78K & 79C Jimmys
motornut's Avatar
can you hit the lower exposed thread with a sand blast
John
Old 04-22-2013, 03:24 PM   #747
UPNADM
UPNADM's Avatar
The threads/bolts are really clean... Just really tight... ha.
Old 04-22-2013, 04:44 PM   #748
MrBeast
high-Tech Red Neck
MrBeast's Avatar
PB Blaster and a few days will probably be more than enough to work them right loose.
As well if you have to heat them PB Blaster is a great oil to use because it comes in a spray can.
I would just spray a bunch on it from the top and bottom, it will soak through, give it a couple of days. With applying more every day.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 04-22-2013, 04:55 PM   #749
68Timber
68Timber's Avatar
PAM cooking spray works really well. I've tried them all but in the past year I've been using it over anything else.
John
74 Honda Z50 build
Old 04-24-2013, 08:41 PM   #750
UPNADM
UPNADM's Avatar
Did a little blasting tonight...
Seat mounts done, sun visor frames ready for paint.
