#126 |
Re: My new project 86 Silverado
moved my cab out of the carport, now can sand and prime the bottom over the next few days.
moved my frame back into the carport up on jackstands. now i can stay out of the rain while i do the frame, and clean up frame parts. will be redoing all the tie-rod ends now, and the installing the LCA's pics tomorrow... will be going flip kit, and 2.5" drop spindles in the front after may 1st.
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
#127 |
![]() Join Date: Jun 2010
I am glad you said that about the tie rods. I need to go ahead and put all my new steering stuff on. Did you end up getting any drop springs or are you cutting yours down?
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
#128 |
i'm going with Mcgaughy's drop spindles, and flip kit. not going to cut any springs, don't want the ride to suck
#129 |
Sounds awesome man!!! Can't wait to see the pictures!!!
![]() Posted via Mobile Device
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
#130 | |
I know the pieces fit
#131 | |
![]() Joe@cmengines said 2-3 weeks for the engine...
#132 |
frame is up and ready to be put back together
stripped all the dash foam off the dash panel.... i think i'm going to sand it down, and paint it so it looks like part of a cockpit panel or something and leave all the bullet holes in it.... finally got to where I can pull out my doors/fenders/bed etc.
#133 |
start weldin all those holes up....lol. I think it would look cool.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#134 | |
plenty of places for switches and lights
#135 |
I for one would like to see that happen. I would prefer the holes filled if it were mine but its not.
Either way I would like to see it finished out. That would probably be pretty cool.
#136 |
guess i'll have to save up for a mig welder then LOL
#137 |
Seriously, I think you might be on to something there. That would have never crossed my mind. The metal is pretty thin isn't it. I would be worried about it warping. Still a great idea. Do it!
#138 |
i could weld some reinforcements underneath, it would stay rigid. i just thought it would be different. never seen one done like it before.
#139 |
It's going to look awesome with whatever you decide to do!
maybe weld some of the holes up, and leave a few to put some lights or guages in maybe?Posted via Mobile Device
#140 |
hood - half done
10 60 grit DA disks and 2 80 grit DA disks later.... damn my hands are buzzing...
#141 |
Looking good bro!! Keep it up
It's one of the joys of sanding even when your done you still feel like your sanding
#142 |
epoxy primed bottom of cab...
stripped the hood to bare metal... epoxy primed
#143 |
Looks great! At this pace you will have it back together in no time.
#144 | |
i'll be glad to get the front/rear suspension done so i can hang this cab...
#145 |
stripped the fender, 10 60 grit DA disks.... no body filler found on the hood or the fender so far.
degreased, and will prime later today after a final 80 grit DA sand damn i'm tired...
#146 |
Looking sharp man! You can do it, just think when it's all done you can sit back and admire your handy work and say DAMN I did a awesome job!!
#147 | |
Nice build so far, keep at it. Can't wait to see how the dash is going to turn out.
81 GMC C15 RC SWB 5.3L 4L80E project
#148 |
both fenders stripped to bare metal....
no body filler found! right one has a few dings here/there... will epoxy prime tomorrow after 80 grit and a wash
#149 |
Good Lord, you've removed some material haven't you? How big a compressor do you have? Looks great, tuned in for the progress.
#150 | |
, man I wish I would have had 40 grit ![]() compressor is a porter cable 6hp 6.8 SCFM@90 psi 25 gallon tank - not a powerhouse but it will get the job done, i'll be spraying the whole truck with it too...
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy Last edited by naphtali5725; 04-23-2013 at 09:43 PM. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
