#376 |
![]() Join Date: Jul 2012
Re: 69 GMC "Ol' Blue"
Far closer to perfect than what mine will be. I'll be tackling that in a week or two, as well.
Nick Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986 http://67-72chevytrucks.com/vboard/s...d.php?t=545356 Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck. |
#377 |
Thanks guys! I'm pretty happy about how they turned out. Now I just need to figure out what I'm going to do next.
Posted via Mobile Device |
#378 |
Looks really good MJ!
Brett ![]() 67 Camaro SS: 67 Camaro Build 72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build 72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD YouTube: https://www.youtube.com/@6dee7-7dee2 |
#379 |
Still Learning
very nice progress!
#380 |
Thanks Brett and Mike!
#381 |
Last night I got one of the shock mounts tacked in. Of course this was after I was in a panic because I thought the shocks were too short. Turns out I just so happened to grab the boxes for the front instead of the rear
![]() Here's the temporary fixture I made to hold the tab at the right angle All tacked in! Today, I need to finish grinding off the old mount on the driver's side (which I swear the po used an entire case of welding rods on). Then I should be able to tack the driver's side. From there, I think my next course of action will be to disassemble the frame for the top coat of chassis black. I will also use that opportunity to get the axles all cleaned up and painted. |
#382 |
I was able to grind all the gob welds off the old shock mount and tack the new one on. I think all frame mods are done, so it's now time to tear her down again so I can paint the frame!
If anyone sees anything wrong with this setup, please chime in before it's too late :-) Posted via Mobile Device Posted via Mobile Device |
#383 |
Last night I ran across a post by see ten that had a trick using a socket over the studs on the steering arm to "shock" the cone washers out so that you can get the arm off the knuckle. I honestly thought it was BS but I just had to try it. Guess what!?! It worked like a champ!!!! I had it off in about 10 minutes (after hours of heating and banging and cussing prior to that). Of course I destroyed my 1-1/8 deep Mac socket, but you know what that was a sacrifice I was willing to make.
#384 |
![]() Join Date: Jul 2009
Looking really good Mike! Should go back together pretty fast once you finish painting the frame.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ![]() 2001 GMC Sierra K2500 |
#385 |
So what did you do with the socket? I've got a 4x4 now, too, and may need to do that at some point.
#386 |
![]() Join Date: Aug 2010
Came over to check out your build. Very nice man!
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
#387 | ||
![]() Quote:
![]() Thank you! I've been following your build as well. Coming along nicely! |
#388 |
Is the frame painted yet? At least disassembled?
#389 |
I was more asking about the trick you talked about doing with the socket, not so much about what you are doing with the socket now that its toast...
#390 | |
Lol...no, I haven't even worked on it this weekend. I did bring the engine hoist home so I can pull the motor.
#391 |
Well, the frame is all torn down. Should be able to paint the frame this weekend.
#392 |
Dang! That was fast. I was only kidding in my last post
#393 |
#394 |
Yeah! Somebody has to make some progress...
#395 |
I was hoping it would be you!
#396 |
Well, progress is being made, just not on Mustard. I've been getting Blue Bell (the 87 K20) up to snuff. I ended up replacing a stretch of brake line, and I gotta say that your's looks much better than the hodge podge job I did. I think I'll be getting a better bender (like yours) when I do Mustard. The one I have just can't bend a tight enough radius to look decent.
#397 | |
#398 |
Frame painted and chassis reassembled yet? No pressure at all here, but you've had a couple of weeks now
#399 |
![]() ![]() Thanks for checking in though...I think it helps me lure that bugger in here. ![]() |
#400 |
Hottest day of the year so far here. Nothing like a light baking in the garage
![]() Today my suspicions were confirmed. I tore the front axle apart and found a broken shaft. Damn...oh well, with the axle ripped down this far, it will be getting new seals, u joints, ball joints and a fresh coat of paint. Missing something here ![]() |
