Old 04-23-2013, 06:40 PM   #1
425HP409
425hp409
425HP409's Avatar
WTB: 71-72 rear differential
I need a 71-72 1/2 ton rear differential housing, bare will be OK.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 04-23-2013, 07:45 PM   #2
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Re: WTB: 71-72 rear differential
Your avitar has a 68, did you know the rear end is slightly wider on a 71-72?
I may know where there is a housing, I am checking now
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 04-23-2013, 07:50 PM   #3
gdavis
gdavis's Avatar
1 1/2 plus wider. I have one I will give ya if you are doing a 68, but it comes with a long travel from florida.
gdavis is offline   Reply With Quote
Old 04-23-2013, 07:59 PM   #4
orngsikL
orngsikL's Avatar
i got a one from a 70
build thread - 1972 C/10 "Ethyl"
1974 C/10 " Paw Paw"
C/10 Club Louisiana
instagram -
@esso_c10
@projectpawpaw
orngsikL is offline   Reply With Quote
Old 04-23-2013, 09:21 PM   #5
425HP409
425hp409
425HP409's Avatar
Yes I know it is wider, I went to 5 lug and put 72 axles in my housing and they are too long.
Charles
90 ZR1 Corvette
Old 04-23-2013, 09:30 PM   #6
chevytruckluver
Hmmm, you know if you change housings to reuse the 72 axles you will have to have some one set up the gears, you can not just swap the center section without checking pinion depth and backlash, would also require new crush sleeve and seals.
The best option is to get some 5 lug axles from Moser engineering that will fit the 68 rear housing. they will run you about 250.00
then sell the 72 axles
Trey
72 Short Step
Old 04-24-2013, 12:00 AM   #7
425HP409
425hp409
425HP409's Avatar
I was wondering if someone made the short 5 lug axles, but forgot to check on it before posting this. That would be a whole lot easier too....I'll try Moser, thanks.
Charles
90 ZR1 Corvette
Old 04-24-2013, 01:58 AM   #8
Vova
Let me know if you want to sell the 72 axles. They should work in my 70 rear end.
Vova is offline   Reply With Quote
Old 04-24-2013, 09:42 AM   #9
Hart_Rod
Hart_Rod's Avatar
Moser sells them, ECE sells them, Summit sells them, etc lots of choices, .
Hart_Rod is offline   Reply With Quote
Old 04-24-2013, 10:31 AM   #10
CC69Rat
CC69Rat's Avatar
you're looking for 30 1/2" long from the mounting flange to the end of the splines (early rear end) The later ones are 31 5/16" long from this same measurement.
I agree, I'd do the early setup, you can run less backspacing too (your wheels will appear wider) Your early housing is highly desirable too, especially on the bagged trucks simply because it's a bit narrower. Your 71-72 5lug axles will be an easy sale.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 04-24-2013, 11:28 PM   #11
425HP409
425hp409
425HP409's Avatar
I found the early 30.5" 5 lug axles from my differential parts supplier in Dallas for under $150 each. Yahoo.....
Charles
90 ZR1 Corvette
Old 04-24-2013, 11:29 PM   #12
425HP409
425hp409
425HP409's Avatar
You have first dibs on my 72 axles
Charles
90 ZR1 Corvette
