Old 04-26-2013, 12:06 AM   #1
cjohnson6772
cjohnson6772's Avatar
steam line and purge tanks and expansion tanks....just what is all this mess?
I found this picture on ls1tech and I'm wondering if anyone here is using a setup like this. I am thinking that the puke nipple on my stock radiator is going to be the line tee'd into the steam line and the rest should be just like shown. Thoughts? Pics? Is there a rule for height of these components?
cjohnson6772 is offline   Reply With Quote
Old 04-26-2013, 09:40 AM   #2
ghettoluxury
ghettoluxury's Avatar
Re: steam line and purge tanks and expansion tanks....just what is all this mess?
If you are using your stock radiator than you need none of that, this is how they are setup from the factory since they no longer have caps on the radiators. For the steam line you can have a nipple added into your radiator at a local shop. You could also tap the water pump and put a fitting in, or get a pipe with a fitting in it that you splice your upper radiator hose and put in between. There is no rule on height, if you look at the radiator these engines came factory with you see the fitting for the steam line is about half way down them.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 04-27-2013, 05:22 AM   #3
ls1nova71
ls1nova71's Avatar
Originally Posted by cjohnson6772 View Post
I I am thinking that the puke nipple on my stock radiator is going to be the line tee'd into the steam line
You can't do this, it doesn't work that way. As stated above, I would hav a fitting added to the radiator. As for the rest of whats pictured, if you had it all from the donor truck it could be made to work, but it would be hard to package it all under the hood of a 67-72. And if you did get it all in there, you wouldnt really be gaining anything.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-27-2013, 08:45 AM   #4
awhite4557
awhite4557's Avatar
I just had a bung welded into the top of the radiator below the radiator cap and connected the steam line to the radiator. Works great. The radiator is a four row factory radiator.
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy C-30 1-ton
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2005 Dodge Ram 2500 5.9 Cummins
2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 04-27-2013, 09:48 AM   #5
cjohnson6772
I concede. Haha. I will bow to greater wisdom and save myself a lot of headache Could the nipple just be brazed into the old heater line return on the radiator (half way down) or should I have it added to the top like pictured?
Old 04-27-2013, 10:15 AM   #6
ls1nova71
ls1nova71's Avatar
Yep! That would fix two problems at once, you get a steam line fitting and you get rid of the heater fitting.
Old 04-27-2013, 10:16 AM   #7
Thealien
Thealien's Avatar
The steam line should go as high in the system as you can get. I had my factory radiator modified with a steam port just below the fill. I also had the inlet and outlet swapped so I could use the factory hoses from my 2005 donor vehicle.
Old 04-27-2013, 10:20 AM   #8
cjohnson6772
I guess thinking about it now: even if a bubble was introduced low in the radiator it would always rise to the top...
I guess the problem would arise if I had a steam line that went up and then back down. The air pocket would get trapped at the high part of that bend...
Old 04-27-2013, 11:46 AM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm the only weirdo who ran his steam lines into my heater lines......all my air bubbles are in my heater core lol.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-28-2013, 01:21 PM   #10
cjohnson6772
Actually I think GM ran it to the return heater line.
Old 06-05-2013, 06:23 PM   #11
BigShoe24
True Addiction
BigShoe24's Avatar
Does anyone know off hand what size of line fits properly to the original steam hard line coming off the motor? I have an LS3 but assume they are all the same size diameter.
Thanks,
RCC
BigShoe24 is offline   Reply With Quote
Old 06-05-2013, 06:59 PM   #12
cjohnson6772
1/4" I believe
