Removing tree sap off the hood & roof
The latest truck I got was parked under trees & sap dripped onto it. I have tried dish soap & then citrol but not much luck.The black sap really shows up on a white truck! Any ideas??? Thanx.
Posted via Mobile Device Posted via Mobile Device
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" ![]() |
Re: Removing tree sap off the hood & roof
Use peanut butter. Put a little on your fingers, rub it for a bit and then let it sit for awhile. That should get it off.
1979 ![]() 1996 Silverado x-cab "the daily" |
#3 | |
I would start with mineral spirits. This will get most of it pretty quickly. Then follow up with a clay bar. That will get all of what's left. If you only had a little bit, the clay bar would do it, but you would ruin it with too much contamination.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
being in the roofing industry, we get tar & different kinds of bitumen all over our trucks, same sticky consistency of sap. if you go to a roofing supplier, you can get "Trim S", made to take tar off ANYTHING, & leaves no stains. i have used this stuff to take tar out of carpet with no staining. have also used good 'ol WD40 without any damage to paint either
Thanks for all the suggestions,going out to shop in a bit and try them.Will post results later.
Several suggestions. Dawn dish soap and soft but stiff sponge and if you have Dollar Tree stores up there they sell a cleaner called Awesome. Comes in squirt bottle and works well for everything I have tried to remove. Had a Camaro one time, was white and had been parked under a maple tree for a long time. Cleaned up real well with the Dawn. Only bad part it was February and snowing outside. That was cold!!
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
![]() Join Date: Jun 2007
wd40 x2
Rubbing alcohol, it will soften the sap right off
WD-40 is all I use,,works on that & removes tar too.
Posted via Mobile Device |
Tried WD40,peanut butter,solvent,citrol but not any luck.I forgot to say in my first post too,this truck sat in the trees for about 7-8 years so it's had a long time to soak in...Will try a few more of the ideas here,thank again
Try Maguires CLEANER WAX !!!!
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
I assume you are meaning the dryish black tree staining. If it is old you may have to use a buffer and a light rubbing compound, followed by a polish.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
White truck...Black sap...7-8 years, Bifman has the right idea, but even then, it might possibly not all come out.
![]() 1985 C10 2004 Avalanche |
#15 |
Ya,sorry guys.I wasn't clear enough.Yes it's the dry black sap,not fresh green stuff.On a white truck,it really shows up eh....
#16 |
Single edge razor blade and be very careful. Only use one side of the blade and if you drop it chunk it.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
#17 |
![]() Join Date: Oct 2008
X2. I used a 50/50 mix with water. You may need full strength. Wax afterwards.
Posted via Mobile Device Edit: Actually it was denatured alcohol like you get at the hardware store. Last edited by Hertzdaddy; 04-30-2013 at 07:53 AM. |
#18 |
Try clorox. It helped with mine but it's red.
#19 |
Walmart sell some stuff called "GOO-gone". you can find it where the sell the mops and brooms and other cleaners. this stuff works pretty good.
good luck buddy.
#20 |
I used some maguires and rubbing alcohol and it took it off of my buick. Another wierd one is orange hand cleaner. I accidently dripped some on a guys old blue truck. wiped it off and it shined like new penny
#21 |
Will try some more of your suggestions,thanx again eh.....
#22 |
Goop hand cleaner works great for most glues and such. My son just removed chewing gum from a car with it today, worked great. Regular old vegetable oil is another one (it's the oil in peanut butter that does the work). Let the oil soak in overnight. Since the sap is so old, it has dried out and hardened. Vegetable oil is the cheapest and won't harm the paint.
#23 |
![]() Join Date: Jun 2009
I would strongly suggest AGAINST using a razor blade. I am a pefectionist and it is still easy to nick the paint. You can get a plastic razor blade and most automotive paint stores or use a plastic putty knife if you want to try and scrape it off. NEVER use something metal to scrape on a painted surface you want to preserve. I would use the Trim S like dieseldawg suggested. If anyone should know about removing tar it is a roofer!
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
#24 |
I own an Auto Body shop and we also do auto detailing, all we have ever used is gas line antifreeze. It softens it but I'm not sure about something that old.
#25 | |
