04-30-2013, 11:05 PM | #1 |
auto shifter linkage ....need help
i got the brackets off a newer c20.... not looking like its right, im going from a 3 on the tree to 700r4...and not sure what it should look like...see the angle?
what bracket do i need and where can i get one...Picture would be great on how yours look....
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
05-01-2013, 12:34 AM | #2 |
Msgt USAF Ret
Re: auto shifter linkage ....need help
The 700r4 in my truck uses the same brackets as the Th350, however I can't speak to the frame configuration on the standard shift. You might consider contacting LOKAR products for a linkage cable. It is a simple straight cable to the shifter on the trans side cover and does away with the brackets and linkage in the stock system.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-01-2013, 11:43 AM | #3 |
DO I have the wrong parts??? or mounted wrong???
05-01-2013, 07:52 PM | #4 |
Active Member
Hi - I used the same linkage on my 68 GMC when I put a 700R4 in it. It's actually not the right linkage. I just put in a couple of nuts for spacers and used the original holes in the frame. Works perfect. See attached picture. I have the correct linkage on my project truck if you need a picture of that.
