Old 05-01-2013, 07:48 PM   #1
Bfork1
Bfork1's Avatar
Different steering wheels
Can someone tell me if the 73-87 steering wheels fit a 72 model? Modifications needed? What about 88 models up?
Bfork1 is offline   Reply With Quote
Old 05-01-2013, 08:14 PM   #2
Gene
Gene's Avatar
Re: Different steering wheels
Yes 88 up will for sure.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 05-01-2013, 09:08 PM   #3
kcsa75
kcsa75's Avatar
Yes. Pretty much any GM wheels up until they started putting air bags in them will fit fine.
kcsa75 is offline   Reply With Quote
Old 05-01-2013, 11:06 PM   #4
landy
It'll bolt onto the steering shaft, however, the horn may no longer function correctly. I tried a 2nd gen steering wheel on my 1st gen Blazer and couldn't get the horn to work right. Eventually put an original wheel back on. I think some folks just add an external horn button to avoid the hassle.
landy is offline   Reply With Quote
Old 05-02-2013, 07:18 AM   #5
My '72 GMC came with a later-70s steering wheel and the horn worked as normal. I have no idea what was done,but I swapped an original wheel on directly.
Old 05-02-2013, 01:38 PM   #6
~Shep~
~Shep~'s Avatar
Is Comfort-Grip the correct term for the wood wheel / aluminum 3 spoke steering wheel I've been seeing more of on here? My factory black wheel is shot and this might be the wheel I go with in the future. I have a 13" Grant on there right now.
1972 Cheyenne K20
Cool Options Include Manual Throttle - Tilt - Dual Gas Tanks - Sliding Rear Glass
...they just forgot to put a super emblem on at the factory!
~Shep~ is offline   Reply With Quote
Old 05-02-2013, 01:42 PM   #7
wgr2112
Heck, my wheel is from a 70-81 Camaro or early Chevelle.
Sometimes with the newer wheels, you may have to convert to the newer style cancel cam/horn button system. All of the parts are cheap and readily available.
wgr2112 is offline   Reply With Quote
Old 05-02-2013, 05:32 PM   #8
ChainGang
I just put one on my truck from LMC Truck catalog and they call it a Classic Wood Steering Wheel.
ChainGang is offline   Reply With Quote
Old 05-03-2013, 06:43 AM   #9
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I used to think that too until I tried to put a 65 Corvair wheel in my 66 Chevelle. The shaft is alot smaller on the Corvair so no go.
Just thought I'd toss that out there in case anyone wanted to put a Corvair wheel in. They are a nice looking wheel too.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
