#76 |
Re: how much horsepower does your truck have
I had a 327 in my last '57 truck and it had plenty of power. Nothing like a well setup LS motor, but enough to get me in trouble.
Posted via Mobile Device |
#77 |
I have a 350 engine out of a mid 90s Chev truck, and have added some block huggers and a "towing" type cam that falls over by 5500 revs. I think I would be lucky to get to 260hp, and its actually not enough.
Truck has Jag front & rear suspension, 235/75/15 whitewalls on chromies at the back and has run a best of 16.1 on the quarter at about 78mph. Its a slug and I have a twin turbo set up in the shed....... However, my street legal t bucket has 851hp (dyno'd) from its blown 540 cube engine and that was too much. I put it into the wall at the National Drags last month. It was a much nicer car when it only had 627hp with the blown 454. I have learned that you CAN have too much horsepower, tho I can claim to have had a street driven 9 second hot rod. Well I still have it but it needs a rebuild now. |
#78 |
^^^^ DANG! Glad you are still here. Your month long road trip in the truck sounds like a good time, hitting the wall in that thing doesn't.
#79 |
![]() Join Date: Jul 2011
With that short of a wheelbase and 851hp, sounds like fun but I wouldn't drive it. Glad you are safe thank roll cage!
Build for my 1959 Fleetside... http://67-72chevytrucks.com/vboard/s...d.php?t=518308 |
#80 |
We run under IHRA sanction down here at the two main tracks. The safety gear did its job and I got no cuts, no bruises, no headaches and no race harness rash. The car can be repaired one day.
#81 | |
#82 |
![]() Join Date: Dec 2012
What does the 59 Gmc 100 have the HP ?
1971 GMC Sierra 1959 GMC 100 |
#83 |
Don't know if 59 is different but my 56 has the hp rating printed on the vin tag on the forward driver side door jamb. Might go look at yours and see if it's the same.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
#84 |
My truck with a 5.3 is "rated" at 285 hp but is untuned and the fuel trims show I'm losing power through timing and fuel issues.
My father in law has a 305 hp LS1 62 Vette My brother in law has a 550hp LS7 vette One of my bosses just got a Nissan GTR conclusion...I like my truck but the vettes are much faster, but traction limited. Though it's not as cool as the old cars, the GTR with it turbos and all wheel drive is just flat out awesome. It's stupid fast because it not only makes dumb levels of power but can hook it to the ground like it's glued to it. It may the first car that has really scared me when I rode in it. Could be because of the driver, too, though...
#85 |
Holy crap !!
The Axle broke off
#86 |
Certified Car Nut
I can't tell you much about that front end other than its a fiberglass frontend. I've spoken to the guy before and found him to be a butthead and I'm allergic to buttheads.lol So once I see a person is a a**hole I walk away and leave it at that.
#87 |
56 - autocross
Thanks. I am allergic to them as well.
#88 |
My 57 has a 1973 350 from a Monte Carlo. Make sure your sitting down. It has 145 (net) hp. NET!!! My HEI distributor is larger than the 2bbl carb! I have added headers and a 2.5" exhaust so I am sure its pushing 150+ ponies, easily.
#89 | |
#90 | |
make sure you re-install the smog pump, that should suck a few more ponies out it ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
