Old 05-02-2013, 03:37 PM   #1
utee05
HEI Swap ('72 1500): Parts List
Hi All,
I am finally going to do an HEI swap for my '72 1500 V8 350. To make things easier on myself I figured I would get recommendations on what parts I will need to get. Since I do not know how long ago the PO installed ignition items I am going to go ahead and get new plugs, wires, cap/rotor as well.
I assume I can just use the same ignition coil? I just bought a new one a couple weeks ago.
HEI: Something from a late 70s Chevy
Plug Wires: 76-78 Vette or Taylor 8mm Wires
Plugs: ?
Cap/Rotor: ?
Anything I might have missed? Also if anyone has specific part numbers from when they did their conversion would be helpful as well.
'72 GMC Super Custom 1500 350 V8 w/AC
utee05 is offline   Reply With Quote
Old 05-02-2013, 04:21 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: HEI Swap ('72 1500): Parts List
Most HEI coils are integrated into the cap.It's a different style so you probably need a new one.Somewhere member "shifty" has a great write up on doing this to a 6.It has lot of info on how to wire it,parts # for electrical connectors and such.The HEI requires 12 volts so you will need to replace the resistor wire that is powering the coil now.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-02-2013, 04:25 PM   #3
utee05
I found that thread. I had not noticed it listed out the parts. I assume I would just have to change some things around.
Here is a link to the thread to keep things in one place for me: Shiftys HEI Swap
Old 05-02-2013, 05:22 PM   #4
1972SUPERSB
1972SUPERSB's Avatar
I just did this on my 72 as well. Pretty straight forward. I got the plug wires for a 75 vette and they fit pretty good
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 05-02-2013, 05:29 PM   #5
ole dollor
ole dollor's Avatar
just make sure you run a wire that has a full 12 volts from the ign. side of the fuse box, don't use the ign wire for the point dist. hot with ign. on and off when ign is off...
ole dollor is offline   Reply With Quote
Old 05-02-2013, 05:51 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
You probably know this already, but since it hasn't been mentioned in this thread..... plugs are same as stock, and gapped at .045".
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 05-02-2013, 09:13 PM   #7
utee05
Thanks for the reminder on the plug gap and ignition wire change.
@1972SUPERSB, what HEI did you go with?
Can I go with all my HEI related parts from a '75 vette as well or is there a cheaper option?
Old 05-02-2013, 09:17 PM   #8
1972SUPERSB
I bought the GM performance parts HEI for a good price on amazon part #93440806.
Jeff
Old 05-02-2013, 09:20 PM   #9
utee05
Accidentally entered the post twice
Old 08-12-2013, 10:55 AM   #10
utee05
Looks like that part number is on sale for $125. Guess I'll go ahead and finally take the plunge and move to HEI. Thanks for the part number.
Old 08-12-2013, 11:06 AM   #11
Zeke's Garage
Zeke's Garage's Avatar
Just to throw this in.. I've purchased two of these, one for my 396 Chevelle, and another with a tach drive for my 427 Vette.. Worked flawlessly, and can be used with standard GM components like caps,coils, ignition modules as well as being able to swap the drive gears if you've got a billet cam. You may just want to verify that the advance canister is the same as yours.. I've heard of some aftermarket (even high dollar ones) having less vacuum advance than stock.
Shawn
'67 Chevy Stepside
250 Inline 6
Megasquirt Fuel Injection
T5 5 speed conversion
Ferric Oxide impregnation throughout
Zeke's Garage is offline   Reply With Quote
Old 08-12-2013, 11:20 AM   #12
utee05
Shawn
Hmm well that is a bit better in terms of price. I assume I could just order it and then if the vacuum advance isn't the same that I could just use my stock one, correct?
Old 08-12-2013, 11:26 AM   #13
Zeke's Garage
I'm not sure about the mounting differences between the two styles.. You might just send them a note and see.. Seems they were pretty responsive when I asked about the tach drive distributor for the Vette. Otherwise, yes, you could always replace it if it's not right.
Shawn
'67 Chevy Stepside
250 Inline 6
Old 08-12-2013, 01:29 PM   #14
utee05
Looks like it would work as is. Now decision between that one or an acdelco part.
Old 08-12-2013, 01:35 PM   #15
GobbleStalker
GobbleStalker Calls
GobbleStalker's Avatar
So what happens if you do use the points power wire?
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino.
Stay Tuned!
1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD!
09 GMC Sierra SLT All Terrain pkg.
2014 Jeep Wrangler Sahara unlimited. ( The wifes ride )
GobbleStalker is offline   Reply With Quote
Old 08-12-2013, 01:59 PM   #16
Zeke's Garage
The original point power wire is a resistor wire, and only supplies about 7~8 volts. This keeps the arcing down between the points (along with the condenser). If you try to run the HEI with that level of power, your spark will be weaker and it can drop out at mid RPM's. Some ignition modules won't fire at all at that voltage.
Shawn
'67 Chevy Stepside
250 Inline 6
Old 08-12-2013, 01:59 PM   #17
Bigdav160
Bigdav160's Avatar
The ignition coil is basically a step-up transformer. Lower voltage in will produce lower voltage out.
It makes it harder to fire the plugs.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-12-2013, 04:49 PM   #18
72bowtiestepper
Shawn
I have seen those Skip White distributors advertised elsewhere.....How long have you been running them in your vehicles? The price seems too good to be true .
72bowtiestepper is offline   Reply With Quote
Old 08-12-2013, 05:11 PM   #19
utee05
I agree the price seems just too good. I went with the acdelco part that superswb posted earlier. Now to figure out the current problem with my remoter starter solenoid.
Old 08-19-2013, 04:45 PM   #20
utee05
Well got the distributor in. I am just waiting on my new harness to get in.
I am curious about get the distributor at TDC. Any tips on how to do this?
Old 08-19-2013, 04:51 PM   #21
1972SUPERSB
What I did was take out #1 spark plug which one on drivers side closest to front of truck. Then manually turn engine with a ratchet using the bolt on the balancer until you feel compression coming out of the hole where the #1 spark plug was. . Once you feel compression then the mark on the balancer should be close to the timing tab on the engine. This means your engine is at top dead center on cylinder #1. This is how I did it. Others may have different ways to do it.
Jeff
Old 08-19-2013, 04:55 PM   #22
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Ugh... I wouldn't use one of those china made Skip White distributors in any vehicle. There has been some testing by a one of the guys on here and the distributor isn't as grand as it seems. So yes... the price is too good to be true. There are some that use them and get lucky...
You need to have the engine at TDC as per your service manual. Plop the distributor in the hole with the rotor pointing at the #1 plug wire. Then bump the starter until the Distributor fully seats. EZPZ.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-19-2013, 05:23 PM   #23
utee05
I got the GM ac delco starter. Decided I'd rather spend the money on this part.
To bump the starter I'd need something like this: Remote Starter Switch
Old 08-19-2013, 07:31 PM   #24
Stocker
20' Daredevil (Ret)
Stocker's Avatar
No question that's probably the best way, but not absolutely necessary. You can pull the old and drop in the new as long as you mark exactly where the rotor is pointing and make sure the new one drops into the same position. And of course don't bump the starter or otherwise rotate the engine.
- Mike -
RIP El Jay
Old 08-19-2013, 08:12 PM   #25
leddzepp
Moderator
leddzepp's Avatar
I've used several of them and had them run for years with no issues. I guess I must be one of the lucky 10,000 people who have never had a problem with one.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
