Old 05-03-2013, 12:58 AM   #1
imsuchaman55
imsuchaman55's Avatar
tailgate interchange?
I See In Some Catalogs A Blazer Tailgate Is The Same From 73-91, While Others Show 73-77 And 78-Up. Will A Newer Tailgate Bolt On Without Any Issues Onto My 73? My Tailgate Has A Rip In The Steel On The Top Lip In The Center, And Want To Make Sure I Find One That Will Work
Also, What Causes These To Rip Like This, So I Can Avoid Having It Happen Again?
imsuchaman55 is offline   Reply With Quote
Old 05-03-2013, 10:39 AM   #2
RED 1970
Re: tailgate interchange?
Yes, they are all interchangeable. You can also swap a pickup tail gate on.
The blazer gates often rip at the corners, this is due to the window components being attached mainly to the outer skin and flexing over time fatigues the metal, short of not driving it there isn't much I know of that would stop it from happening again.
RED 1970 is offline   Reply With Quote
Old 05-03-2013, 06:39 PM   #3
gclark1
gclark1's Avatar
I would be pretty sure they are all the same too. I put a gate off of an 85 on my 77 with no issues if that helps dispell any of the rumors about the break in years you list.
gclark1 is offline   Reply With Quote
Old 05-03-2013, 08:07 PM   #4
mgchevyparts
mgchevyparts's Avatar
Obviously, the pick up won't have a window glass but it still "fits"?
mgchevyparts is offline   Reply With Quote
Old 05-03-2013, 09:10 PM   #5
imsuchaman55
Thank You. Just Wanted To Make Sure, Since Finding A Clean Tailgate Is Easier From The Newer years
Old 05-08-2013, 11:13 PM   #6
The difference is in the skin. GM put a rib across the upper portion that wasn't on the early K/5s. Pickup gates can be "made" to work on a K/5 with a soft top that doesn't use the glass. I have the rare '73 GMC gate I was going to put on my '85 Jimmy with soft top
Old 05-12-2013, 11:09 PM   #7
kevinr1970
Literally every K5/Jimmy I have ever seen is ripped in those corners, the '89 Jimmy and the '82 K5 I own are both ripped, both sides.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 05-13-2013, 10:12 AM   #8
imsuchaman55
It looks like I will be keeping the one I have and adding reinforcement plates along the entire top. Thank you guys for the info
