Old 05-03-2013, 11:13 AM   #1
jaros44sr
jaros44sr's Avatar
fuel tank...opinions
getting ready to buy my aluminum fuel tank from boyds welding, great guy to talk to...
Just need to know from you guys any thoughts or problems you may have run into on this swap
Hope our sending unit is 90 ohms. Fill will be in the bed, and it will be set up for EFI. -6 feed and return lines
Best capacity seems to be 19 gallons, with standard fuel tank. 4WD, sooo, i may be able to add some capacity to the depth, dunno. Thats where you guys come in
Ill start to read through the builds and see if can get any help there
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-07-2013, 05:36 PM   #2
TonyJohnson
TonyJohnson's Avatar
Re: fuel tank...opinions
I'm interested too. Tired of hearing my Holley Red grinding away back there... It would be worse if it wasn't for my exhaust leak. lol
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 05-07-2013, 05:58 PM   #3
Dale99
I have a 91 model 31 gal tank, with a stock replacement TBI pump. I had to remove and make my own rear cross member. Also hangs a tad low. But if your not doing any hard core wheeling, it wont matter.
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Dale99 is offline   Reply With Quote
Old 05-07-2013, 05:59 PM   #4
jaros44sr
jaros44sr's Avatar
Yeah well, were not getting alot of feedback, so we may be the lab rats
Next day or so im going to order the tank, takes about a week to make, and then shipping
Hope it fits
SAFETY FIRST
AS usual, off topic
Jim
Old 05-07-2013, 06:00 PM   #5
TonyJohnson
I'm wondering if a '96 tahoe tank will fit... Gotta climb under there in the morning.
Tony Johnson
Old 05-07-2013, 06:02 PM   #6
TonyJohnson
Hope it fits
Post a link here to the results. I've also got a FI '94 S10 Tahoe that I'm eyeballin'
Tony Johnson
Old 05-07-2013, 06:04 PM   #7
jaros44sr
jaros44sr's Avatar
Thanks for the info. Dale...i dont want to move the crossmember if i dont have to, but well see....wheeling? Yeah, i could see that in the future might as well build a 2wd if you dont take it off the pavement
SAFETY FIRST
AS usual, off topic
Jim
Old 05-07-2013, 06:13 PM   #8
Dale99
My trucks already butchured and the member was bent. So I didnt mind removing it. Ive done some wheeling and it cleared with my setup.
Old 05-07-2013, 09:04 PM   #9
AJs72K5
AJs72K5's Avatar
Mine came in right at 20 gallons from Fuelcellguy. Fully baffled EFI tank with intank pump. Mark was great to work with. If I had to do it over again from a fitment perspective, I'd sacrifice a little ground clearance for a top fill as opposed to a side fill.
I can't offer any practical feedback as I haven't turned the engine over yet.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 05-08-2013, 09:32 AM   #10
jaros44sr
jaros44sr's Avatar
Thanks AJ, ill contact him and see whats up
SAFETY FIRST
AS usual, off topic
Jim
Old 05-08-2013, 11:43 PM   #11
Jdubs71
Jdubs71's Avatar
I also ordered a custom tank from Mark (FuelCellGuy) and I'm of no help since I haven't mounted it yet. My tank is 23 gal I believe and is baffled. It also came with the in-tank pump.
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
