Old 05-03-2013, 09:05 PM   #1
damianbryand
What is this?
Any clue what this is? It's on the driver side of the block between the two front plugs.
damianbryand is offline   Reply With Quote
Old 05-03-2013, 09:07 PM   #2
turp mcspray
turp mcspray's Avatar
Re: What is this?
Temperature sending unit.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 05-03-2013, 09:09 PM   #3
damianbryand
Re: What is this?
Awesome. Thanks. Any idea where the unit is for the oil pressure gauge?
Old 05-03-2013, 09:24 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Re: What is this?
Oil pressure gauge is mechanical, there is no sending unit.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-03-2013, 09:28 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: What is this?
... As long as your truck has gauges and not idiot lights, and it connects on the block right behind the intake manifold, slightly to the drivers side of the truck from the distributor.
Tx Firefighter is offline   Reply With Quote
Old 05-03-2013, 11:16 PM   #6
wgr2112
Re: What is this?
As I understand it, the sender you posted is for the temperature gauge. There is one on the passenger side of the block for the Temp. idiot light.
wgr2112 is offline   Reply With Quote
Old 05-04-2013, 08:34 AM   #7
Tx Firefighter
Re: What is this?
You should have one or the other depending on which dash your truck has (gauge or light). There will be a block off plug screwed into the passenger side cylinder head. 1/2 NPT is the thread size.
Old 05-04-2013, 09:22 AM   #8
wgr2112
Re: What is this?
Mine has them on both sides. Of course it's a 40 year old combination of trucks, who knows what has been done in the past.
Old 05-04-2013, 12:02 PM   #9
ERASER5
ERASER5's Avatar
Re: What is this?
The piece on the passenger side in not for an idiot light. It is part of the Transmission Spark Control system (TSC). This was an early attempt at emissions control. The temp switch provided the ground leg for a relay. If the coolant was below 32°, the switch was open and did not provide a ground leg. The other parts were a switch in the transmission that only closed in 3rd gear providing power for a relay. When the engines was warm AND the trans was in 3rd, the relay sent power to a vacuum switch. The Vac switch allowed the vacuum to reach the vacuum advance can on the distributor.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 05-04-2013, 12:35 PM   #10
wgr2112
Re: What is this?
Had no idea!
Mine has nothing attached to it, but I doubt I'm missing anything!
Old 05-06-2013, 10:07 AM   #11
ERASER5
ERASER5's Avatar
Re: What is this?
Most of the TSC part are long gone leaving a unused switch in the trans and unused switch in the passenger head. This stumped me as well, but I actually had ALL the parts, they were just unhooked.
I did sell some parts to a guy doing a concourse rebuild, so don't just throw them out.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 05-06-2013, 10:41 AM   #12
68gmsee
Active Member
68gmsee's Avatar
Re: What is this?
Wow! Wonder if Rube Goldberg had something to do with this one.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
