Old 05-03-2013, 10:55 PM   #126
mechanixman
mechanixman's Avatar
Re: 1952 1 Ton Rebuild
That was the original plan. But after listening to Chevybrad and Coralhead, and finding out that these frames are rare enough, I decided to do the whole toolbox thing. Besides, once I drop the 327 in, I intend to travel long distances in. Things like power tour.
And while on vacation, I was wondering what I would do with my luggage. Something kinda like the trunk on Ogre's truk. So I figured the toolbox would work for that too.
mechanixman is offline   Reply With Quote
Old 05-07-2013, 10:26 PM   #127
mechanixman
Now that I got the engine running, it's time for some...adjustments.
I'm tired of the jerry rigged throttle linkage, so I use the original Rochester model B carb.
Here's the story: I already had the original carburetor. (see post #7) So I decided to rebuild it. Problem was, the bolts holding the throttle plate to the shaft broke off.
I was getting ready to drill them out and hope to not screw everything up when I found out it didn't fit the intake manifold! I found out the carter carb did, so I just let it be.
But the man I got the fenders from had a 216 lying on it's side in his yard. I mentioned that my carb didn't fit the manifold, and he said, "it doesn't? Let me get a wrench. If you take it off, it's yours." So I got the manifold and the carb! I just finished cleaning up the throttle assembly on it, and mating it to the one I already rebuilt.
What do you guys think of the difference?
Next on the list:
-Replace gaskets
-Do a valve job
-find a way to mount the new alternator/generator.
Old 05-09-2013, 09:00 AM   #128
Denee007
Denee007's Avatar
How nice that man is! That is looking much better! You'll run into a lot of rusted frozen aggravation challenges. Keep up with the good work and keep looking for finds like this carb/ intake!
Dne'
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 05-11-2013, 01:34 PM   #129
mechanixman
Thanks!
Funny, I've already run into some of those....
I finished building both intakes, My problem right now, is the power plunger seal has shrunk. So I need to find one of those before I can run with the new carb.
Old 05-12-2013, 11:52 AM   #130
mechanixman
Real quick, I found a picture that comes damn close to what I plan on doing:
So same idea. Except I'll just have the top open. No drawers by your feet/knees (depending on how you stand in your bed)
Old 05-13-2013, 11:06 PM   #131
mechanixman
I put new U joints in the drive shaft, and the drive shaft in the truck.
I didn't have a U bolts that hold the joint to the yoke for the diff. side.
I went around to all the parts stores looking for these clamps, and no one seemed to have the right size if any at all.
I went to milwaukee last Saturday and bought a trans and got the clamps off that (hey! it was cheap enough )
Old 05-14-2013, 06:25 PM   #132
mechanixman
Well, BB&S took his first steps today!!
From the chocks to where it is in the picture.
But I have a small problem....
As you can see, he peed a little...
Which I have no problem with, considering I don't have the oil filter or oil pressure gauge on right now. What does is the color of the oil.
I know when antifreeze mixes with the oil, it becomes that mocha color, and gets to be quite frothy.
But this doesn't happen to be frothy..
What do you guys think happened?
Here are the car facts:
The motor oil is fresh, and was black until now.
There was fluid in the block, it was filled up to the water pump. (it poured out when I rebuilt the pump)
It seems like this started when I topped the radiator off, and tried starting it.
(It's running pretty rough with the new carb on it.)
Old 05-15-2013, 04:50 AM   #133
65Ch3v3LL3
I would say cracked head or head gasket.
1952 3800 GMC
2008 Harley VRSCDX
2011 Road King Classic
2012 Sierra Denali 2500HD
1966 Datsun Roadster 1600
1965 Chevelle SS
65Ch3v3LL3 is offline   Reply With Quote
Old 05-15-2013, 06:30 AM   #134
coralhead
coralhead's Avatar
Looks like you need to pull the head and have it checked out. Lots of times there is a reason like this the truck had been put out in the field. Hopefully it is just a head gasket.
coralhead is offline   Reply With Quote
Old 05-15-2013, 10:27 AM   #135
Katrina/10
Katrina/10's Avatar
I've seen cracks in the water jacket behind the lifter cover on these engines if allowed to freeze.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 05-16-2013, 12:00 AM   #136
mechanixman
Thanks for the tips guys.
Today, I found out what an ordeal it is to pull the head off these motors...
I can't believe you have to pull the rockers off for one bolt...argh!
Anyways, here are some pictures
Maybe I'm in luck!
It doesn't seem like there even is a gasket....
Old 05-16-2013, 12:02 AM   #137
mechanixman
And here are a few from the air. You get a nice shot of my uber messy garage...
and I found a great place to store parts!
Old 05-16-2013, 08:06 AM   #138
mechanixman
Originally Posted by mechanixman View Post
Maybe I'm in luck!
Aww shucks.
I started using a scraper on the bottom of the head, turns out there was a gasket, but it was squeezed so much, that it stuck to the head like white on rice
-Nick
Projects:
1952 Chevy 1 ton = The Build page
Old 05-16-2013, 10:27 AM   #139
Truck Guy99
I was gonna say, it looks like there is one deep in there in the first picture in post #136. Did you get a toolbox yet? If not, have you decided on one? BTW, truck is looking SWEET! Let us know!
My names Tye. No Chevy right now
Truck Guy99 is offline   Reply With Quote
Old 05-16-2013, 11:43 AM   #140
coralhead
coralhead's Avatar
Re: 1952 3/4 Ton Rebuild
Originally Posted by coralhead View Post
From the movie "Christine" "You know Pepper, You can't polish a turd" even though I think the "myth busters" actually did.
Keep up the good work and stay focused.
Nick, hope it is not bad on the water leak but as before......(above)
Now that you have the head off you can get it checked for cracks and/or get new hardened valve seats installed. If it not cracked then the block may be the culprit. Either way you may be looking at that tri-power setup you have your eyes on.
Good Luck
John
Old 05-16-2013, 03:48 PM   #141
mechanixman
yeah, when i made the first post, I only looked at the block.
No I don't have one quite yet. I plan on making mine from scratch. This is the type of box that come to mind. (at last that's what i'm envisioning)
By the way, Thanks!!
Yeah, that's whats been bouncing around in my head for a while..... I don't know whether or not the cost will be worth it.
On one hand, that V8 still needs $600 of intake.....
But on the other, I'm going to be spending at least a hundred bucks on new valve seats, and thats just the start..
-Nick
Projects:
Old 05-16-2013, 09:34 PM   #142
ChevyBrad
ChevyBrad's Avatar
Aw man, sorry about your luck and yeah unfortunately from your picture, it does look as though the gasket is blown which, like everyone else is saying it's a good possibility of a cracked head or block...
ChevyBrad is offline   Reply With Quote
Old 05-16-2013, 10:39 PM   #143
mechanixman
Damn...
So what's the deal with cylinder number 3?
could that be near the problem?
I don't see any reason for that combustion chamber to have no soot...
Old 05-19-2013, 10:44 AM   #144
ChevyBrad
ChevyBrad's Avatar
Hmm... yeah that is interesting
Old 05-20-2013, 09:45 PM   #145
coralhead
coralhead's Avatar
Nick, Go get a fresh head gasket and put it back together with some fresh CHEAP oil and see if it was just a bad head gasket. The most you will be out is the cheap oil. That way you can eliminate the bad gasket part of the puzzle.
Good luck, John
Old 05-20-2013, 09:53 PM   #146
mechanixman
Well I have this rusty gunk that came out all the orifices of the head, I'm starting to agree with katrina, my water jacket is crap.
I found a guy on craigslist, I'm getting a head, and oil pan, and a distributor cap for $60.
Old 05-21-2013, 07:55 AM   #147
Russell Ashley
Russell Ashley's Avatar
Damn...
That's where the leak was. Back in "the day" we used to pour a coke bottle of water down the carb while keeping the engine at about 1500 to 2,000 rpm. You dribbled the water a little at the time to clean out the combustion chambers. I guess you could say it was steam cleaning the pistons. At least that's what we said then, LOL.
Russell Ashley is offline   Reply With Quote
Old 05-21-2013, 04:51 PM   #148
coralhead
coralhead's Avatar
I've done that before, it works.
Old 05-21-2013, 11:52 PM   #149
mechanixman
Alright, thanks for the tip.
I'll definitely try that!......once the motor runs again.
Old 05-22-2013, 10:44 PM   #150
ChevyBrad
ChevyBrad's Avatar
Nice!
