Old 05-04-2013, 10:35 PM   #1
LockDoc
The Older Generation
LockDoc's Avatar
Rear Axle Ratio Charts For 1967 - 1972 GM Trucks
I have saved these from different places so they don't match each other. I saved them as image files and they are all different resolutions and sizes. They really need to be typed into a document file so the size and style of font matches on all of the charts. Unfortunately I don't type good enough to do that so we will try it this way. I just hope they are all readable with the image size restrictions for the board. I think I have them sized close to the maximum that the board allows. Disregard the C14 designation in the '67 chart, it should be C10.
In case someone is thinking Photobucket or some other photo hosting service, I won't do that for two reasons. One, I am not going to sign up for an account & Two, If the photobucket account is ever closed the thread will be worthless because their won't be any pictures of the charts in it, just empty boxes ...
Thanks.
LockDoc
Leon
Old 05-04-2013, 10:36 PM   #2
LockDoc
LockDoc's Avatar
Re: Rear Axle Ratio Charts For 1967 - 1972 GM Trucks
This is the last Chart. It looks like they are mostly readable. A couple of them may be a little blurry.
There is no guarantee of correctness or completeness (is that a word?) in any of these charts
Edit: I might as well add this chart to the thread too.
Rear Axle Ratios
Ratio 2.56:1 - Tooth Combination 41,16
Ratio 2.73:1 - Tooth Combination 41,15
Ratio 3.07:1 - Tooth Combination 43,14
Ratio 3.08:1 - Tooth Combination 40,13
Ratio 3.08:1 - Tooth Combination 37,12
Ratio 3.31:1 - Tooth Combination 43,13
Ratio 3.36:1 - Tooth Combination 37,11
Ratio 3.42:1 - Tooth Combination 41,12
Ratio 3.55:1 - Tooth Combination 39,11
Ratio 3.73:1 - Tooth Combination 41,11
Ratio 4.10:1 - Tooth Combination 41,10
Ratio 4.11:1 - Tooth Combination 37,9
Ratio 5.14:1 - Tooth Combination 36,7
The tooth combination numbers will be found stamped into the ring gear when you take the back cover off.
They may not all be for the trucks.
LockDoc
Leon
Old 05-04-2013, 10:50 PM   #3
bruceman1968
bruceman1968's Avatar
Nice job LocDoc, thanks for posting those.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 05-04-2013, 11:26 PM   #4
This is great! I'm thinking this is for Chevrolet with the 10,20,30 designates. And,I don't see any posi for K/20,only No-Spin. A Dana 60 would have the Power-lok. It shows a 4.11 for K/20,which is the Dana 60,
Old 05-05-2013, 12:44 AM   #5
Hawghauler
Hawghauler's Avatar
Thanks LockDoc!
I'm sure many people will be less confused. Now there is a place to direct people searching for that elusive code!
If I have to be on 4 wheels, It has to be a classic Chevy
1967 c10 Longbed (Hawghauler/Icy weather transport)
2003 BMW K1200GT (Rain bike)
2007 Softail Deuce (Sun bike)
2009 Ultra Classic Electra Glide (Everything else bike)
Hawghauler is offline   Reply With Quote
Old 05-05-2013, 02:20 PM   #6
LockDoc
LockDoc's Avatar
No problem guys. It might be nice to have them all in one place. I added some info to my 2nd post also.
LockDoc
Leon
Old 10-27-2013, 03:24 PM   #7
sambudo
sambudo's Avatar
where can you find these codes on the axel?
1968 C10, 250, L6 4spd OTF, Fleetside
Upgrades: Power Steering
.......................____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
sambudo is offline   Reply With Quote
Old 10-27-2013, 08:34 PM   #8
LockDoc
LockDoc's Avatar
Usually on the passengers side axle tube. Just use the first 2 or 3 letters which ever it has.
LockDoc
Leon
Old 10-28-2013, 06:31 AM   #9
Keith Seymore
Keith Seymore's Avatar
Thanks for posting those, Doc.
I'm not offended that the fonts and sizes don't match. Lends credibility to the documents, in my way of thinking.
k
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-28-2013, 08:40 AM   #10
I never knew of a 3.36:1 ratio in these trucks. Looks like it was just in Vans. That would be a sweet ratio to swap into a little C/10
Old 10-28-2013, 10:50 AM   #11
Sandemonium
Proud owner of a 55.1 AD
Sandemonium's Avatar
Thank you for posting. Great information.
Sandemonium is offline   Reply With Quote
Old 10-28-2013, 12:35 PM   #12
indianbullet
Location: North Cal and no Sac or Bay area is not NORTH
Good stuff.
Never argue with an idiot, they will bring you to their level and beat you with experience..
indianbullet is offline   Reply With Quote
Old 11-15-2013, 09:40 PM   #13
slikside
slikside's Avatar
Originally Posted by indianbullet View Post
Good stuff.
Yes, it is. Subscribed.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 11-18-2013, 11:33 PM   #14
Longhorn 70
Longhorn 70's Avatar
I climbed under the truck this afternoon and coudln't find the axle code on the tube. Could they have put it under the spring mount? I REALLY don't want to unbolt the springs to check it.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 11-18-2013, 11:44 PM   #15
swamp rat
swamp rat's Avatar
Are you talking the front axle? dana 44? that axle stamp is just to the right of the front of the pumpkin towards the upper area..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-19-2013, 12:39 AM   #16
LockDoc
LockDoc's Avatar
I don't think it would be under the mount. Sometimes they are stamped pretty light. There may be some that didn't get stamped. If that is the case you would have to pull the rear cover off, check the numbers on the ring gear and use the "Red" chart in post #2...
Example: If the numbers 41 : 11 were stamped into the edge of the ring gear it would be a 3.73 ring & pinion.
LockDoc
Leon
Old 11-19-2013, 09:23 AM   #17
Longhorn 70
This is for the Eaton HO52 under the Longhorn.
Thanks Leon. It may not have been stamped or these old peepers just didn't catch them. I'll look again from different angles. It may also help to get my 5 year old under there. She sees EVERYTHING.
Thanks for your guys help on this subject. I truly appreciate it.
Old 11-19-2013, 11:21 AM   #18
LockDoc
LockDoc's Avatar
No problem. Be sure and take a strong light and some coarse sandpaper under with you...
Funny how those kids see it all....
LockDoc
Leon
Old 11-19-2013, 02:31 PM   #19
swamp rat
swamp rat's Avatar
Look on top of the pumpkin passenger side of the pumpkin. I didn't think the Eaton had a stamp on the axle, i didn't see one on mine.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-19-2013, 02:44 PM   #20
Longhorn 70
OK I'll look there too. I did see some stuff stamped there.
Old 11-19-2013, 05:47 PM   #21
FreeRangeChicken
FreeRangeChicken's Avatar
Okay, here's a total noob question, please don't flame me too badly ...
For 1967 what's a C14 and why isn't there a C10 in the chart? Quick google on 1967 and C14 yielded nonsense. Is that a misprint for C10?
Dave L.
1967 Chevy C10 SWB Stepside, L6 250
1967 Chevy C10 Fleetside, LS2 6.0L
1972 Chevy C10 LWB Fleetside, 350
FreeRangeChicken is offline   Reply With Quote
Old 11-19-2013, 06:37 PM   #22
JointTech
JointTech's Avatar
well since i dont see it yet. I can probably OCR these are convert them to text. Ill fiddle with it today.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 11-19-2013, 06:41 PM   #23
JointTech
JointTech's Avatar
Well my OCR software is kind of crappy but it wont take to much to clean this up. You guys prefer csv, xls or just a text file. the coloms are never going to line up correctly in the forum so it should be a download of some kind.
C14 . (3.73 ratio). HA-MD
C14. (3.07 ratIo). HB
C14 Positraction t3.13 ratio) HC
C14 Overdrive (4.11 ratio) HD
610..... (3.36ratlo) HI
610 (3.73 ratio) (2900 lbs.) Hi -ME
610 (4.11 ratio) (2900 lbs.) HK -MG
610 (4.11 ratio) (2400 lbs.) HL -MF
G10 Positraction (3.36 ratIo) HM-MH
GlO Positraction (3.T3 rallo) HN -MJ
610 Positractlon (4.11 ratio) (2900 lbs.) HO -MK
610 Positraction (4.11 ratIo) (2400 lbs.) HP-Ml
1(10 (3.13 rallo) HQ
PlO (4.11 rallo) HR
P10...., Posltraction (3.73 rallo) HS
PlO (3.l3ratio) HT
C20 (4.57 ratio) HU
C20 Positraction (451 ratio) HV
CZO (4.11 ratio) (Z9OU lbs.) HW
C20 (4.Slratio)DuaI Wheels HX
C20 Positraction Dual Wheels (451 ratio) HY
1(20 (45lratig) HZ-ND
P20 (4.5lratlo) IA
P20 Positraction (4.57 ratio) IB
C30 (4.57 ratIo) LW-MC-MW-MY
C30..... (5.14 ratIo) UJ -MO
C30 (Sl4ratio) IC-MR
C30 Dual Wheels (5.14 ratio). ID-MS-MV
C30 Dual Wheels (5.14 ratio) LV
C30 Positraction (5.14 rIo) lE-MO-MT
C30 Dual Wtieels, Positraction (5.14 ratio) IF -MU
P30 (5.I4ratlo) 1G
P30 Dual Wheels (5.14 ratIo) 1H
P30. . ... Posltraction 5.14 ratIo) II
C30 (4.5lratlo) iN
dO Positractlon (4.11 ratIo) JQ
C20 wP’327” (4.57 ratio) JS
C20 wr’32r, dual wheels (451 rallo) JI
C20 wP’327” (4.11 ratio) (2900 lbs.) JLJ
C30 (4.57ratio) MP
C30 (&lTrallo) MX
P20 (4.llratio) MZ
P30 (4.llratlo) NA—NB
P30 (4. ratio) NC
P30 (6.llratio) NE
72 C20 Long Bed
Old 11-19-2013, 09:17 PM   #24
LockDoc
LockDoc's Avatar
I don't see a c14 listed for '67 in any of my literature so it is probably a misprint...
LockDoc
Leon
Old 11-19-2013, 10:51 PM   #25
67chevy1series
67chevy1series's Avatar
For 67 is c14 3.73 positraction the equivalent to a 67 c10 with 3.73 posi?
67chevy1series is offline   Reply With Quote
