Closed Thread
Old 05-05-2013, 06:05 PM   #7601
jsdoyle
jsdoyle's Avatar
Re: What did you do to your truck today?
New fuel pump installed today on my SB350. It started and ran well so I guess I did it right.
65 Chevy C10 Fleetside
jsdoyle is offline
Old 05-05-2013, 07:01 PM   #7602
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
not today but last thursday Holley 500!!!!!
49 chevy 5 window 20 year project (sold)😟
57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.)
62 GMC 305 V6 custom L/B
72 HIGHLANDER K5 BLAZER 2nd owner
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
62 GMC SHORT BED SERVICE BODY V6 (STUMPY)
74 GMC CUSTOM 1500 L/B
Matt's k5 is offline
Old 05-06-2013, 12:08 AM   #7603
64shortbox
64shortbox's Avatar
Still working on my 73 suspension/disc brake change over. Trying to bleed the brakes was driving me crazy. Pumping the brake pedal & bleeding didn't work, gravity bleeding didn't work, using a Mighty-Vac didn't work. I've NEVER had this much trouble getting brakes to bleed. So while at work I cut up a piece of 3/8" scrap aluminum slightly bigger than my master cylinder with a rubber gasket to match. I drilled & tapped the plate to 1/8" pipe thread, installed a regulator & ball valve, topped off the master with brake fluid, chained down my contraption, cranked the air pressure to 14 lbs and bled my brakes. I now have firm pedal pressure and good brakes!!! Next, paint the motor and get it installed.
64shortbox is offline
Old 05-06-2013, 04:43 AM   #7604
markeb01
Senior Enthusiast
markeb01's Avatar
Initiated the process of pulling my engine.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 05-07-2013, 07:29 PM   #7605
TJ's Chevy
TJ's Chevy's Avatar
I painted my side covers today. Blue was a little lighter than expected.
TJ's Chevy is offline
Old 05-07-2013, 07:31 PM   #7606
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by azdude1964 View Post
Here is my new 1964 bbw longbed ..its gonna get restored .....stay tuned if you have a set of hubcaps i would be interested in buying them also need stock 283 air cleaner.
I had a set of hubcaps!
Old 05-07-2013, 09:29 PM   #7607
robber grin
My son-in-law dropped off first of four homemade WWW's.
I leveled the chassis with the 283 on the side mounts and standard bell housing mounts - then checked the motor for level across the exhaust manifold and it was very close to being level as well.
Blocked up the engine to keep the same position.
Cut the bell housing cross member out and cleaned up the frame.
Cleaned the FILTHY TH350C that I put in the 62 tonight. Replaced input and output shaft seals before I installed it. Worked on my filler tube since it was dinged up at some point.
Leveled engine and tranny and sat the tail-shaft on a jack stand.
Pulled some string from yoke to yoke...
Stared at it for 20 minutes since it seems so high in the frame (to me anyway).
rg
robber grin is offline
Old 05-07-2013, 09:48 PM   #7608
Lugnutz65
Lugnutz65's Avatar
I went from THIS
to THIS
to THIS
All by myself in just under 4 hours. (OK, a friend helped me lift the engine out, but I had it all set up . )
So the 250ci is now out of my parts truck and getting ready for a freshen-up.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 05-07-2013, 11:59 PM   #7609
ACK
ACK's Avatar
Dropped the TH350 today so I can install the correct size flex plate for the new starter. The old starter blew the nose cone to pieces over the weekend because the PO used about 1.5" worth of washers to shim it in place so it would mate with the flex plate. As luck would have it, the supply store ordered the wrong size flex plate so I'll be stopping by there tomorrow to get the right one.
My truck ain't dead, it just smells funny.
ACK is offline
Old 05-08-2013, 01:23 AM   #7610
doobiebro
doobiebro's Avatar
Good problem solving my friend.. I just rebuilt a complete brake system on a 63 c-10 panel and used a pressure bleeder from the farthest wheel cylinder and worked my way to the front with no hassles....
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline
Old 05-08-2013, 01:40 AM   #7611
LT1 Burb
LT1 Burb's Avatar
Got my new AC compressor mounted.
LT1 Burb is offline
Old 05-08-2013, 07:57 AM   #7612
jbgroby
jbgroby's Avatar
you are in Canada why do you need a/c
jbgroby is offline
Old 05-08-2013, 12:20 PM   #7613
donthekawguy
donthekawguy's Avatar
I got the rear end in, hooked up the shocks, put in the new track bar. I still need to put the driveline in, replace the rubber brake line, fill the diff and put all new brake stuff on. It's nice to have all new shiny parts on!
66 shorty
donthekawguy is offline
Old 05-08-2013, 07:32 PM   #7614
LVPhotos
LVPhotos's Avatar
Back home. Took the 1962 out for a ride and updated my build thread. Got the hood back from paint, final bodywork no seams, just in time to get to show on Sat. Working on striping doors.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline
Old 05-08-2013, 07:35 PM   #7615
LVPhotos
LVPhotos's Avatar
Cleaned for show, set ride height. Lil low, hit stops without the rear shocks.
LVPhotos is offline
Old 05-08-2013, 07:48 PM   #7616
ca90ss
Pulled the cylinder head to be rebuilt before putting it on the donor engine. Found out what was rattling around in the old engine
ca90ss is offline
Old 05-08-2013, 10:19 PM   #7617
MARTYZ
MARTYZ's Avatar
Wink Re: What did you do to your truck today?
Gets pretty warm up here once the igloos all melt
MARTYZ is offline
Old 05-08-2013, 11:18 PM   #7618
donthekawguy
I tried to install the new rubber line for the rear brakes and it wouldn't come lose from the hard line. Good thing I got a new complete kit last week. But the rubber line is the wrong size so I need to call classic parts and see what to do. They have the wrong line listed on the site for my 66.
66 shorty
Old 05-08-2013, 11:48 PM   #7619
SCHRUMGMC
SCHRUMGMC's Avatar
Nice white truck man
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline
Old 05-09-2013, 01:03 AM   #7620
LT1 Burb
LT1 Burb's Avatar
Picked up a nice gauge set and cleaned the garage so I can start bodywork.
LT1 Burb is offline
Old 05-09-2013, 01:18 AM   #7621
SCHRUMGMC
SCHRUMGMC's Avatar
Went to the Bank and Cashed my Government Check I got and turned my 20's into one HUNDRED dollar bills ...Got a trailer to pick up tomorrow and go get my Truck
1971 GMC Sierra
1959 GMC 100
Old 05-09-2013, 02:12 AM   #7622
MikeS.
MikeS.'s Avatar
I got the 2nd gas tank back from repair and installed in the motor home.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline
Old 05-09-2013, 03:40 AM   #7623
WCHLVR
WCHLVR's Avatar
Make this my first post-
Installed some 64 Cadillac Hub Caps on my new 64 Custom. If you know about Caddy caps you know this is not any easy task! LOL
Used them as a cheap way to cover the rusty chrome mods it has on it!
As you can see I also took off the All Terrains in favor of some passenger car tires. 3" whites coming soon!
WCHLVR is offline
Old 05-09-2013, 10:40 AM   #7624
dantimdad
dantimdad's Avatar
Nice truck!
Welcome to the board!
I would have never thought hubcaps would work those rims.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 05-09-2013, 10:43 AM   #7625
racecougar
racecougar's Avatar
Pulled the stock sixxer and three-speed. Once I get the rust repair on the cab finished up, we'll take it down to a bare frame.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline
Closed Thread
