05-05-2013, 09:56 PM | #1 |
Factory Assembly Manual, Navigation
I got a Factory Assembly Instruction Manual, and I can see there is a lot of good info in there. How do you find the info that you are looking for, no index no table of content or page numbers ?
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
05-05-2013, 10:04 PM | #2 |
Re: Factory Assembly Manual, Navigation
I've thumbed through page by page. I have pieces of paper with the name (windshield)etc. on top.
Posted via Mobile Device |
05-05-2013, 10:13 PM | #3 |
It's a PDF file so you're probably using Adober Reader to read it.
On the left side of the page click the "paperclip" and then the "binoculars" and then you can do a text search for whatever part you're looking for. Hope this helped. |
05-05-2013, 10:48 PM | #4 |
This is what I have been doing. I also have a Chassis Service Manual and a Haynes Repair Manual, are there any other good books to get ?
05-05-2013, 11:31 PM | #5 |
05-05-2013, 11:46 PM | #6 | |
The Older Generation
I purchased the CD version of the manual from here. http://www.gregsonline.com/eshop/Assembly/67TFAC.htm It has a search feature that works very well. They also have some neat '67-'72 Chevy "T" shirts if you click on the "licensed apparel" at the bottom of that page. LockDoc
05-06-2013, 01:07 AM | #7 |
You can try this link. I found it here on the forum about a year ago. It will require that you number all pages... 1064 if I recall correctly. I'm also not sure the document is complete.
https://docs.google.com/spreadsheet/...sOXcwVWc#gid=0 |
05-06-2013, 09:24 AM | #8 |
I also have the CD version, it's easy to use, searchable and I can print out a page or two if needed. I have it on my iPad so its handy were ever i need it. Before I got the CD version I made an index in excel, it only takes about an hour and makes things a lot easier to find. I have not used the tome since I got the digital version.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
05-07-2013, 08:17 AM | #9 | |
05-07-2013, 08:19 AM | #10 | |
05-07-2013, 09:24 AM | #11 |
On the extreme right side of the spreadsheet it lists the board members that contributed time & expertise to this project. A big thanks to them...
LockDoc
12-11-2013, 02:40 PM | #12 |
A little late to the party, but here is a link to an index that was created by some of our members a few years back. Check out Post #9 for the link to the Google Doc that contains the index.
http://67-72chevytrucks.com/vboard/s...d.php?t=351185
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
12-11-2013, 03:56 PM | #13 | |
So UPC 0 = Labels/literature UPC 1 = body structure UPC 2 = Frames UPC 3 = Front axle UPC 4 = Rear axle UPC 5 = Brakes UPC 6 = engine UPC 7 = transmission UPC 8 = exhaust UPC 10 = tire/wheel UPC 11 = front end sheet metal, radiator support UPC 14 = bumpers It is cumbersome, at best, to use, even for those guys that have grown up with it. The only way to navigate quickly was to create your own cheat sheet (in the pre-internet/per-computer days) or use a search feature as you guys have done. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
