Old 05-09-2013, 09:47 AM   #126
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: 85 lwb turbo 5.3 build
Originally Posted by 79shortbed View Post
What hose and fittings are you using? I need to do the same, just don't know what fittings I need to connect AN hose to the 87 sending unit
If there is a straight section of steel tube, I would use a compression to -6 AN adapter. Summit has them, as do most decent local speed shops.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 05-10-2013, 10:38 PM   #127
85burb
85burb's Avatar
Got the fuel cell and coolant and oil sensor adapters in the mail today. Should have the rest of the fuel system Monday. On summit it said the cell has -6 fittings on it. I looked at them today and they look to be -8. Now I have to get some reducers.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 05-13-2013, 08:27 PM   #128
85burb
85burb's Avatar
I got 90% of my fuel system in today. Got pump, lines, regulator, fittings, spark plug wires. After reviewing my box i remembered i need a few more parts. I needed a plug and two o-ring to an fittings. And -8 to -6 adapters for the fuel tank fittings. I hope to have it all this weekend. Sat i may install everything but sunday i have to go help buddys drop a motor in a vette. Not looking forward to that.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-13-2013, 09:06 PM   #129
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
looks like you have a set of manifolds on the motor already...do you still need my old ones?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-13-2013, 09:11 PM   #130
85burb
85burb's Avatar
Yes I still do. The ones I have will not work cause they have egr ports and it hits the frame. And most of the studs are crap.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-13-2013, 10:09 PM   #131
68GMCCustom
OK. If I could get them part of the way there to say Greenville some weekend day.....would that work?
Mine's driving....just have a vibration I can't find keeping the mileage/speed down.
Kurt -
Old 05-13-2013, 10:14 PM   #132
85burb
85burb's Avatar
I can meet you there sat when ever. Sunday I have to put the motor I sold out of the 85 into a vette. If that will work.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-13-2013, 10:26 PM   #133
68GMCCustom
When it gets closer to the weekend... we can work it out then.
Kurt -
Old 05-13-2013, 10:27 PM   #134
85burb
85burb's Avatar
Works for me. Thanks.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-14-2013, 02:22 PM   #135
85burb
85burb's Avatar
Just to make sure on my fuel set up the fuel should come from pump threw the rails then to the regulator and return to the tank from the reg correct?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-14-2013, 04:32 PM   #136
69trk
69trk's Avatar
I have a holley regulator and they say to go from the pump into one rail, then out of that rail into the other rail then into the regulator, then out of the regulator back to the tank...
But aeromotive says to come out of fuel pump into y block, then into both rails, then out of both rails into regulator then back to the tank...
But my regulator has a 1-10an inlet and 1-10an outlet which will be plugged. and 1-8an return...
I think either way will be fine...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 05-14-2013, 08:26 PM   #137
68GMCCustom
Interesting.....as compared to the Vette filter/regulator that goes between tank and fuel rails, dumping the fuel back into the tank from there...regulating the pressure before entering the rails.
Kurt -
Old 05-15-2013, 11:41 PM   #138
85burb
85burb's Avatar
The brown and the white trucks both showed up at my house today. I got what i think is the rest of my fuel system in and my flywheel and bolts and crank bushing deal. I am gonna have a pretty good relationship with the fedex folks soon. The ups driver and i already know each other well. He goes to my work and drops packeges everyday. He is one busy sob. He shows up at my work at 930am or so and does not get to my house tell as late as 9pm sometimes.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-17-2013, 08:59 PM   #139
85burb
85burb's Avatar
I got the fuel tank set in its semi-final possition. I had a old bed frame laying around so i cut it up and made a few cell mounts with it. I have two L shaped metal crossmembers bolted to gether to make a C and Notched the ends to sit on top of the frame. It is not a high doller set up but is seems like it will hold the tank well. Just need to pick up a new rear crossmember from porterbuilt and get some bolts and it will be final. It is close enough to run the fuel lines and stuff. I will paint it and the cell straps befor it is final. The tank sits with a 2 degree slope to the rear sump. I assume that is plenty. May be less when bolted down.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-18-2013, 05:30 PM   #140
85burb
85burb's Avatar
I got most of my fuel system installed today. Tank is in, filters are in, pump is in, regulator is in, fuel injector o-rings, 3/4 or my return line. I need 2 more 90 degree fittings and a few more feet of hose. Pretty happy with it so far. I didnt even stab myself.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-18-2013, 05:38 PM   #141
68GMCCustom
Coming along! That's how I built mine....all s.s.flex line.
Kurt -
Old 05-18-2013, 05:41 PM   #142
85burb
85burb's Avatar
It is sure expensive but I love the look. I think i may just buy about 500 feet of it next time. I alway run out befor i am done. I used about 25 feet today and need 10 more. That is what i used on my burb too for the supply side. I used the factory metal line for the return side cause i am using the stock tank.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-20-2013, 08:40 PM   #143
85burb
85burb's Avatar
I once again put a order in for the last of my fuel system. I sure hope this is it. Also my maf exstension harness came in and was too short. I told them i needed 2 feet and they send 1 foot. They will be sending the correct one tomorrow for free and i get to keep this one.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-22-2013, 11:13 PM   #144
85burb
85burb's Avatar
I can say this with confidence this time. ALL of my fuel system came in today. My rollover valve, 2 90 degree fittings and 10 more feet of hose. Got it all installed and I am ready for the wiring portion of the swap. Started removing all the wires i wont need anymore from the trucks under hood harness. Also half ass got a idea of where everything will be going. I looked over the connections i need to make for the motor harness and it is way better then the harness in my burb. I have desided to not run the motor then take it out. I am just going to wire everything up and then pull the motor to clean the engine bay and paint the motor. I cant wait. I almost have everything i need other then time and a monkey to do the work for me.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-02-2013, 09:19 PM   #145
85burb
85burb's Avatar
Not a hole lot going on. Going to pull the motor next weekend and clean it and the engine bay up. Maybe even put it back in. But this weekend I removed the valve covers and painted them.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-03-2013, 09:35 PM   #146
85burb
85burb's Avatar
A small bit of progress. I installed the freshly painted valvecovers today. I also trimmed the starter wires and put new ends on them. Just need to shorten the alt wire and put a new end on it and the truck side will be done. I plan on pulling the motor this weekend and getting it ready. Not a hole lot more i need to do now with the motor in.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-04-2013, 03:29 PM   #147
85burb
85burb's Avatar
Painted coil brackets too!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-08-2013, 05:06 PM   #148
85burb
85burb's Avatar
A buddy and I pulled the motor today. Then I got the bay pressure washed and almost ready for paint. I cant wait to get this thing running.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-09-2013, 05:58 PM   #149
85burb
85burb's Avatar
Got the motor painted. Will have pics soon.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-09-2013, 06:39 PM   #150
85burb
85burb's Avatar
painted motor
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
