Closed Thread
Old 05-09-2013, 11:27 AM   #7626
ChevyJr
Junior Member
ChevyJr's Avatar
Re: What did you do to your truck today?
Cleaned up the 700r4 I'm swapping into my '65
ChevyJr is offline
Old 05-09-2013, 11:38 AM   #7627
robber grin
Having installed the TH350C on the 283 in my 62 C10 day or so ago - last night after some thought and scrounging for steel I went to work on a rear crossmember for the tail shaft mount.
I cut the original standard crossmember down and came up with this piece.
Hope to put it in tonight...
rg
robber grin is offline
Old 05-09-2013, 12:35 PM   #7628
CRGRS 66
CRGRS 66's Avatar
Originally Posted by WCHLVR View Post
Make this my first post-
Installed some 64 Cadillac Hub Caps on my new 64 Custom. If you know about Caddy caps you know this is not any easy task! LOL
As you can see I also took off the All Terrains in favor of some passenger car tires. 3" whites coming soon!
Nice Truck, caps look good on there, welcome aboard!!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline
Old 05-09-2013, 12:36 PM   #7629
CRGRS 66
CRGRS 66's Avatar
Originally Posted by racecougar View Post
Pulled the stock sixxer and three-speed. Once I get the rust repair on the cab finished up, we'll take it down to a bare frame.
Is it just me? Your truck looks like it is leaning significantly to the passenger side...
Craigerrr
CRGRS 66 is offline
Old 05-09-2013, 02:46 PM   #7630
WCHLVR
WCHLVR's Avatar
Originally Posted by dantimdad View Post
Nice truck!
Welcome to the board!
I would have never thought hubcaps would work those rims.
Steven
Thanks for the props folks. Yeah... it took a little creative engineering to make the caps happen. Super pleased with the results though!
WCHLVR is offline
Old 05-09-2013, 03:38 PM   #7631
racecougar
racecougar's Avatar
The frame is level, but the cab is absolutely leaning, as I'm in the middle of replacing the floor pans, cab supports, door pillars, rocker panel, cab corner, etc on the driverside...it's all in my build thread.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline
Old 05-10-2013, 09:26 AM   #7632
robber grin
Welcome home WCHLVR!
Many many build pics are appreciated...
rg
Old 05-10-2013, 11:33 AM   #7633
T2vigil
T2vigil's Avatar
One headlight connector later I finally got all of the lights working as they should including the "Bright Lights" in the instrument panel. Now I have no issues with driving at night.
T2vigil is offline
Old 05-10-2013, 11:42 AM   #7634
Blue_Aura
Blue_Aura's Avatar
What do you mean by "bright lights"? Please explain and provide part numbers. Thanks
Current Vehicles:
'62 C10 - 350 (current project), '03 Tahoe (C Series)
Some Past Projects:
'69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB
Blue_Aura is offline
Old 05-10-2013, 01:27 PM   #7635
WCHLVR
WCHLVR's Avatar
rg
Thanks RG. As I get a little further into her I will make up a build thread for her!
WCHLVR is offline
Old 05-10-2013, 03:20 PM   #7636
T2vigil
T2vigil's Avatar
On the dash there is a lamp that lights when the dimmer switch turns on the bright lights. On my truck there is a piece of red plastic the has "Bright Lights" written on it. When the bright lights are turned on the lamp shows through the red plastic to iluminate the "Bright Lights" indication. Sorry I do not have any part number.
T2vigil is offline
Old 05-11-2013, 01:40 AM   #7637
Blue_Aura
Blue_Aura's Avatar
Went for a 3 hour round trip drive to go pick up some TJ springs for $10.
Sanded down my air cleaner that was going to be matched to the blue metallic paint on my engine. I had to change up my scheme for the valve covers and air cleaner since the masking job turned out to be a nightmare!
Current Vehicles:
Some Past Projects:
Old 05-11-2013, 02:10 AM   #7638
coulter
coulter's Avatar
modded one of my trailing arms
trimmed it for better clearance
stretched 1" to center up the wheels in the wheelwell when laid out
took 6degrees of angle out for better pinion angle when driving low
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline
Old 05-11-2013, 02:29 AM   #7639
donthekawguy
donthekawguy's Avatar
Very nice! Now I feel bad cuz I just powder coated mine.
66 shorty
donthekawguy is offline
Old 05-11-2013, 01:25 PM   #7640
coulter
coulter's Avatar
luckly mine were only spray painted hahaha
coulter is offline
Old 05-11-2013, 03:35 PM   #7641
ACK
ACK's Avatar
Although me and the engine weren't seeing eye to eye, got the oil pan out today. Next step is cleaning the pan really good and painting it. Also got my parts to reconnect the transmission and new connectors for the transmission cooler hoses. The parts place even put bubble flares on them to help keep the hoses in place nice and snug.
My truck ain't dead, it just smells funny.
ACK is offline
Old 05-11-2013, 09:53 PM   #7642
JPBrecheisen
got my new tires mounted to the slot mags and installed.
1960 GMC K1500 LB Fleet Side
1962 GMC K1000 LB Step Side
1988 Chevrolet C2500
JPBrecheisen is offline
Old 05-11-2013, 10:06 PM   #7643
TJ's Chevy
TJ's Chevy's Avatar
I hauled a bunch of wood in mine today. Nice tires ya got there J. B. I sure could use a set!
TJ's Chevy is offline
Old 05-11-2013, 10:22 PM   #7644
jayoldschool
Moderator
Drove seven hours round trip to pick up a set of wheels that will fit my stock hubcaps!
jayoldschool is offline
Old 05-11-2013, 10:25 PM   #7645
JPBrecheisen
Thanks. Best ones out there are the ones you can still use and not worry about scratching.
Old 05-11-2013, 11:32 PM   #7646
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: What did you do to your truck today?
Starting on the drivers side door now.
Project: "Full Metal Yellow Jacket" Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline
Old 05-12-2013, 03:35 AM   #7647
Vernski
Doors lookin cool, will they be electric?...Vernski
Vernski is offline
Old 05-12-2013, 04:20 PM   #7648
TxRat
TxRat's Avatar
Repaired some rust in the floors today
TxRat is offline
Old 05-12-2013, 06:58 PM   #7649
robber grin
Installed my modified 83 GMC factory AT shift linkage, then installed the new U-Joints, and newly painted driveshaft.
Put my 62 in "Park" for probably first time ever - it was a 3 speed truck originally and PO had gone to a toploader before it came to me.
Swapped out the rear wheels - so all four match now.
rg
Last edited by robber grin; 05-12-2013 at 07:08 PM. Reason: dumped blurred photo for better one
Old 05-12-2013, 09:45 PM   #7650
1964Chevy
1964Chevy's Avatar
Realized that if I turn my a/c on then off the electric rad fan will not come on until I turn the truck off and start it again, aaaarrrggghhh. I reckon I'm taking this electric fan out and putting the mechanical one back in, only with a fan clutch this time......
If your strength is small, don't carry heavy burdens. If your words are worthless, don't give advice. Chinese Proverb
1964Chevy is offline
Closed Thread
