05-07-2013, 12:49 PM | #2126 |
Re: What Did You Do With Your Truck Today ?
Thanks Indian, Now I'll think twice
The kid says it needs work around the edges, not sure on what that one meant..Can anyone find a photo of a Truck that needs work around the Windows ?
1971 GMC Sierra 1959 GMC 100 |
05-07-2013, 01:01 PM | #2127 |
After what I've been through on my windshield install, I believe I could install one by myself if I had a normal truck to install one on! But would you even want to install the glass before paint?
Dne' ------------------------------Back to Thread Post---------------------------------------- When I bring it home, first thing I am going to work on is putting the Glass in, may take a while but I can get it done[/QUOTE] Posted via Mobile Device
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com |
05-07-2013, 01:08 PM | #2128 |
[QUOTE=Denee007;6057352]After what I've been through on my windshield install, I believe I could install one by myself if I had a normal truck to install one on! But would you even want to install the glass before paint?
Dne' I'll need to do some welding and putting on new Panels etc..Is the Steps on the bed bolted on or Welded ?
05-07-2013, 03:15 PM | #2129 |
I've never looked at the side steps to see how they are attached to the truck. Perhaps if you had room, you could remove the bed, put it on some stands and work on it at your leisure.
05-07-2013, 03:25 PM | #2130 |
the steps are held on with bolts. Just take a look underneath the steps and you'll see the bolt heads, They attach upwards into the step side fenders
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
05-07-2013, 03:30 PM | #2131 | |
HE STILL HAS THE ORIGINAL 59 Hub Caps that went on the Truck
05-09-2013, 12:46 PM | #2132 |
Almost 4 years ago, I started my "long term" 59 Apache project. It didn't get very far because I wasn't able to title the truck I'd bought. As of yesterday, the project is real again This time with a clear title and upgraded to BW.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
05-09-2013, 12:48 PM | #2133 |
great start !!! have a great time building it - we are all here to help out if you have questions
05-09-2013, 02:24 PM | #2134 |
Congratulations!!!
05-09-2013, 02:31 PM | #2135 |
Awesome project build man, looks pretty much like mine
05-09-2013, 04:20 PM | #2136 |
Looks good Rick. What the short version of why you couldn't title it, then you could?
I'm working on my speaker hole repairs today. I got the passenger door patches welded in. One of the patches left two gaps I'll have to "bridge" somehow. Of course this had to be after I welded in the first patch successfully thereby eliminating my ability to get my arm in there with a copper backer! I may have to make something out of a long, flatten piece of copper pipe. Oh, and due to me being an IDIOT! I realized after I'd welded in the patches that I forgot to turn on my gas! What a bonehead, huh? Learning, learning ! Posted via Mobile Device |
05-09-2013, 04:26 PM | #2137 | |
I've never done that! not!
05-09-2013, 04:27 PM | #2138 |
I know, and I'm not even blonde! (Externally, ha ha)
05-09-2013, 04:48 PM | #2139 |
Thanks Daze, Denee, Dan and Schrum. Dan, I'm almost embarrassed to say. First truck was supposed to have a title, but PO couldn't find it at home and said he'd have to check his storage unit. I was dumb and trusted him, but he never produced. Then I discovered there was no VIN plate for me to even get a bonded title. Live and learn... I just bought the pictured truck yesterday. At least I've got two trucks worth of parts to work with!
05-09-2013, 06:52 PM | #2140 |
Ugh, that sucks. Oh well, you're looking on the bright side - always a good thing. Have you got any of those parts you're missing on the 1st truck? Those rear fenders, hood, any kind of drivetrain?
05-09-2013, 07:04 PM | #2141 |
I've pretty much got all the body parts needed, and will end up with a bunch of extras. I'd already aquired and rebuilt most of the drivetrain other than engine. I've got a couple 350's, but not sure yet whether I'll rebuild one of those or go a different direction. Both trucks were pretty much stripped to a shell, but this one came with a guage cluster i might be able to restore, and an original seat frame with springs that might also be restored and upholstered. Still missing a lot of interior parts though.
05-09-2013, 07:22 PM | #2142 |
It started raining this afternoon so I had to shut down before I was totally done. But I managed to do final fitting/grinding on the passenger side speaker holes.
That's not a burn through on the upper left it's a burn mark of a bit of paint that was too close. Threw some primer on it just to keep it from flash rusting until I get back to it tomorrow - I hope! QUESTION: Do most of you guys and girls weld all the spots in and then grind everything down smooth? Or do you put in a few tacks, grind, tack some more, etc? I ground them all at the end and thought too much heat built up. In this case, I could NOT reach behind to hammer & dolly as I went. Last edited by Dan in Pasadena; 05-09-2013 at 07:28 PM. |
05-09-2013, 07:49 PM | #2143 |
Looks good Dan real good for a first project of that type.The contoured panel isn't the easiest to start off with. |
05-09-2013, 07:54 PM | #2144 |
I would put some body filler, block sand and call it done
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
05-09-2013, 08:09 PM | #2145 |
I got a 200r4 transmission that I am thinking about using for my 52. the best part is it is free. all I have to do is take it out.
I also rounded up my 20 some year old B&M Mega shifter that has never been used. I will have to buy a plastic indicator window for the overdrive trans and maybe a taller shroud so I can raise the shifter a bit. that is if I don't change my mind again And my gave me some DOM tube and urethane spring bushings that will work good for my motor mounts. |
05-09-2013, 08:44 PM | #2146 |
Yup, that's pretty much my plan.
I agree I should have made my first repair something easier. Maybe the small rust-through where the toe board/kick panel/floor meet? I didn't because I thought the only way to do that right was to pull the front sheet metal - is that right? I also have a buuunch of miscellaneous holes all over. What the hell was it with old trucks and drilling holes in them?! I plan to do those with the copper backing - I've not tried that yet. Doesn't the weld stick to it AT ALL? |
05-09-2013, 09:22 PM | #2147 |
Way to go Dan! Looking good! no, GREAT!
05-10-2013, 06:37 AM | #2148 |
I started installing A/C kit
Going with the Gen VI universal Kit I took the rear bracket flipped it upside down and put a bend in it to attach to dash. Posted via Mobile Device |
05-10-2013, 07:22 AM | #2149 |
Elev8r Man
Installed my front fenders and there is good clearance to tires when I deflate the airbags, installed fender seals / welting, and inner fender wells. Next is the radiator support, driveshaft, cross bed sills, drill for electrical stub outs and measure for shocks. Gonna be a busy weekend.
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!! 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. |
05-10-2013, 07:52 AM | #2150 |
Ordered my wheels from Wheels Vintiques. Really helpful guys.
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
