Old 11-21-2003, 05:28 PM   #26
70ChevyLongbed
Howzit?!?
70ChevyLongbed's Avatar
Wink
Originally posted by dtlilly
Thanks, I will too. It should look more classy than a dirty coolant jug
Don,
Would my brother-in-law's Tall Boy can of Bud Ice zip tied to the radiator be classy, or classic. :p
Jason
Hawaiian-J
70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters.
1999 Chevy Tahoe
2004 Mini Cooper S
71 BMW 2002 - Sold
70ChevyLongbed is offline   Reply With Quote
Old 11-21-2003, 06:46 PM   #27
Catfishking
I don't know why you all bother with a resevior on these old trucks. They don't have a 2 way pressure valve in the radiator cap like the new ones do (or none at all). If your truck is spewing fluid, then the truck is either overheating and causing too much pressure, or you need to buy a new radiator cap to pressurize the cooling system correctly.
Catfishking is offline   Reply With Quote
Old 11-21-2003, 06:52 PM   #28
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
You can get the fancy aluminum or stainless overflow tanks on e-bay. Here is one with a buy it now for $22.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2442873174
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-21-2003, 07:06 PM   #29
bpmcgee
bpmcgee's Avatar
Catfishking,
When you replace that radiator cap, buy one from a '75 instead, and THEN you can use a coolant recovery tank! Hmm. What a great idea!!
Brian
P.S. Great way to make a first impression
bpmcgee is offline   Reply With Quote
Old 11-21-2003, 07:15 PM   #30
BtnkBndt
Pennyless Fool
BtnkBndt's Avatar
And I like being able to check my coolant level at a glance and with no brow burns.
BtnkBndt is offline   Reply With Quote
Old 11-21-2003, 09:49 PM   #31
Andy4639
Old member
Andy4639's Avatar
Cool Classey
dtlilly,
My water jug compared to this! Now that is class.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-23-2003, 07:29 PM   #32
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
I put one in my 71 and out of an old s-10 pickup sitting in the trees. All it does is catch the overflow. It will not suck it back up because i do not have a closed system. You have to get certain types of caps for your radiator and your overflow tank. The overflow tank should not vent until it gets full and reallly hot!! This way it will hold pressure build up and when the engine is off that built up pressure will push the fluid back into the radiator.
WRMZ71 is offline   Reply With Quote
Old 11-24-2003, 01:01 AM   #33
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Actually the tank can be vented and it'll still work properly. The vacume created by the contracting cooling in the rad is what sucks it back in.
Old 11-24-2003, 03:10 AM   #34
jorgensensc
jorgensensc's Avatar
Racedvl,
Does your radiator suck the fluid back in from the resevoir? I have that same vent radiator cap and am going to get a washer resevoir this next weekend and am curious if it will work. Thanks!!!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-24-2003, 03:30 AM   #35
Andy4639
Old member
Andy4639's Avatar
Cool Cold to hot / Hot to Cold
If you get a 15lbs. cap and hook up a overflow tank it will work, it don't matter what kind of tank or cap it has on it as long as the hose from the radiator is under the level of coolant in the jug. That's why I choose a tank out of the 80's model monty carlo, the hose connects in the bottom of the jug and it stays under the fluid level. If you have a jug that the hose runs through the top it has to stay covered up with coolant at all times for the suction to work.
Old 11-24-2003, 03:40 AM   #36
jorgensensc
Andy4639,
Thanks for clearing that up!!! Should the resevoir be mounted below the highest point of the radiator to aide in suction??
Old 11-24-2003, 04:46 AM   #37
Andy4639
Old member
Andy4639's Avatar
Cool Level
I would put it either level or below the cap on the radiator. If you look at the picture I posted earlier in this thread you will see that the hose is below the cap. I would at the least have it level. I know that the jug is dirty, but it's my driver I can't have it clean everytime I need a picture of something.
Old 11-24-2003, 04:57 AM   #38
jorgensensc
Thanks Andy4639!!!
Old 11-24-2003, 11:01 AM   #39
tom hand
CCRider
tom hand's Avatar
The advantage to running a Expansion (Overflow) Tank is you can run the radiator completely full....it is much more efficient without any air in it. Where the tank is mounted doesn't matter if you have the correct cap....it will suck it back in.
http://www.mycarwizard.com/autoshop/cooling1.html
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 11-24-2003, 03:00 PM   #40
69ChevySB
dropped69
my reservoir was cracked so i took it off when i first got it...ive always drove without it on yeah it spits on the ground but i just put more water in it every now and then. ive drove the truck atleast 250 miles one way to mexico in the summer and it never got hot on me....also drove it about 200-250 miles up north in the winter time ....that was before i had the turbo400 in it...i had a little 307/3speed on the floor standard...then i switched to 350/t400 dont know if i could go that far again my radiator is only a 2 core but its brand new and so is my water pump, what do you guys think? will my truck get hot with the 350/th400 setup faster opposed to the 307/3spd? thanks
"And yet I find, yet I find...repeating in my head. If I can't be my own, I feel better dead." -Layne Staley (R.I.P)
69ChevySB is offline   Reply With Quote
Old 11-24-2003, 04:55 PM   #41
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Yes, it will warm up quicker. All automatics run hotter than standards, because of the cooler lines going to the radiator and the hot transmission fluid flowing through it.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
