11-21-2003, 07:29 PM | #1 |
amp really hot?
I was working on the door panels in my truck and thought i smelled something burning. The amp was really hot (couldnt touch it) so i pulled it out. does anyone know what could cause this?
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires -'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree -'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials -dads '70 burb (red, 5-7 drop, 350...) www.geocities.com/userc10/truckhome.html AIM: Auntjoedadda |
11-21-2003, 09:00 PM | #2 |
I need a brake!
A few of the things I have learned from hooking up amps:
Use a good size + and - wire. The ground wire (and it's size) is just as important as the power wire. I always use 4 gauge when running amp power wires. Sometimes it is overkill, but I have caught a carpet on fire with too small a wire and not having everything fused well. Use the correct fuses for the amp you are using. Also, be sure no stray copper is jumping from + to - this can cause fires, too. Amps can get pretty darn warm, but I haven't encountered them getting too hot to touch if everything is hooked up right.
JP MEMBER OF THE DISCS UP FRONT CLUB 1971 Chevy C10 |
11-21-2003, 09:03 PM | #3 |
well, it was professionally instatalled using big wire (not sure, would have to look) and is fused. Been fine for 2 years. Any other ideas? I'm going to take it by teh place taht installed it and see if tehy know anything
11-21-2003, 09:11 PM | #4 |
Usually caused bad a faulty ground. Take the wire off of the body, use sand paper and sand till it is bare metal. Then used a little silicone grease on the connection.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
11-21-2003, 10:47 PM | #5 |
Try spinnin 4 rear tars
sounds like you may have a short somewhere... Since it has been in there for 2 years, wire insulation may have worn through. Of course this only applies if you hear whatever speaker(s) is hooked to it is cutting out (from the short).
Is your amp turned ALL of the way up?! In the last 2 years, have you changed your interior to something or moved something that would cause your amp to not get circulation?! If the need be, you can go to radio shack and get a 12V computer fan. I did this on an amp I had mounted inside the console in an old Jeep. Just wire the fan to your remote wire on the amp, everytime your headunit is turned on, the fan comes on and blows air over your amp. Worked for me
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB Last edited by SWEET7T; 11-21-2003 at 10:50 PM. |
11-22-2003, 01:19 AM | #6 |
i did change the seats but they've been like that for awhile...i'll check theinsultation, but the sub was out of the truck (amp was still in there) while the truck was painted....i guess i can hook it back up and try, just dont want to burn it up
11-22-2003, 01:23 AM | #7 |
Pronounced "Pew-al-up"
I had a similar thing happen to me and it was because one of the speaker wires popped off inside the door and was graounding to the door. I had crossovers so it only blew the crossover not the amp. Sure stunk bad though...
Classic GM Trucks of Washington Club Member 1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's, Power Locks, Truck Photos |
11-22-2003, 01:27 AM | #8 |
dano, you may have it, i'll check tommorrow...i dont know if teh wires were covered since the sub wasnt in there...
thanks
11-22-2003, 05:04 PM | #9 |
amp problem
I have installed car stereo since 1986. I was also going to suggest you check to see if the wires were touching each other or ground. If I can help you PM me or call 3346575583. Also your install was probably fine but don't asume that it was done right just because it was done by a shop. Make sure the ground went straight to metal not a seat bolt or anything.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
