Old 05-10-2013, 03:06 PM   #1
Want2Run
Rear End Differentials (Posi)
I would eventually like to replace or change the differentials in my rear end.. I'm looking at a Eaton Posi differentials in the Jegs catalog. I've heard good things about Eaton but was wanting to see if anyone had any experience with Eaton?
Want2Run is offline   Reply With Quote
Old 05-10-2013, 03:24 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Rear End Differentials (Posi)
Eaton is the big player in that segment of the industry since they gobbled up everyone else.
Any advice would depend on how you plan to use the truck. I might recommend something different for off-road, strictly street running vs drag racing.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-10-2013, 03:53 PM   #3
Want2Run
I know Eaton is the big name for rear ends, but I was just getting opinion on them, I have a lowered 85 C10, not a drag truck but a fairly decent amount of horsepower and plan to up it asap, its more of a street racing kind of deal around where I live cause the closest track that is in use is probably Norwalk a good 3 hours away. so streetable use.
Old 05-10-2013, 04:25 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
What kind of road manners are you expecting and willing to sacrifice? Budget? Power level?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-11-2013, 09:45 AM   #5
Blackpony
Blackpony's Avatar
I bought an eaton style unit from a 70's camaro that I plan to install in mine soon. It's a clutch unit that should give good street manners. I plan to rebuild it with new clutches and tighten up the clutches a bit.
Blackpony is offline   Reply With Quote
Old 05-11-2013, 11:03 AM   #6
Want2Run
I'm looking for power not budget, but from my research I have done an Eaton Posi is what I am looking for not Eaton True Trac. more power and hook to the road. Like I said perform well if I do line em' up and race on Friday nights, ( street race we have a place we gather to street race). But I will still be able to use on the street for regular driving use. Do you understand what I mean?
Old 05-11-2013, 11:05 AM   #7
Want2Run
Black Pony let me know how that works out for you, the one I am looking sounds to be at least the same style as you are putting in if not the exact same.
Old 05-11-2013, 11:28 AM   #8
Bigdav160
Bigdav160's Avatar
A True Trac has excellent road manners and will never wear out. The down side is the off road performance can be a problem. A locker is better suited in that environment.
Clutch type limited slips are rebuildable and tunable and the most popular with the drag racing crowd.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 05-11-2013, 12:46 PM   #9
Want2Run
So you are saying a Tru Trac should be the way I go instead? Off-road doesn't bother me, from my research the Tru Trac seemed to be for more for all out drag not the clutch style? But I'm not afraid to be wrong. What makes the Tru Trac better for streetable manners?
Vette 350 Dropped 85 C10, NOS Equipped.
62 Nova Wagon 355, Heidts front end, Pushing 500
1984 Cutlass Supreme 350
1999 Tahoe
1990 B2200 Mazda(gas getter)
Old 05-11-2013, 03:49 PM   #10
ont_guy_38
ont_guy_38's Avatar
That's what I have also, I do some time at the track. i am very happy with the way it performs there and on the street.
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 05-12-2013, 01:26 PM   #11
Want2Run
You have the clutch style differentials? They perform well on the track, and on the street and no problems? How long have you had the differentials in?
1999 Tahoe
Old 05-12-2013, 01:43 PM   #12
ont_guy_38
ont_guy_38's Avatar
It performs awesome in both places. I have a buddy with a 10 second Nova and that's all he has in his rear end also. they have more than proven themselves over the years as being reliable. Part #410408 is for 2.73-up ratios, 410409 is for 2.56-down ratios
1985 C10
2004 Avalanche
Old 05-12-2013, 11:02 PM   #13
Want2Run
Is there any maintenance that is done to make sure it runs good? or just straight install and basically forget it? But thanks ill have to look the number up.
1999 Tahoe
Old 05-13-2013, 06:44 AM   #14
ont_guy_38
ont_guy_38's Avatar
It has to be setup correctly and the additive put in but once all that is done there is no maintenance other then maybe the odd lube change every few years.
1985 C10
2004 Avalanche
Old 05-13-2013, 10:44 AM   #15
Want2Run
Well that sounds pretty good basically no maintenance, Thanks again for all the help.
1999 Tahoe
