05-10-2013, 08:23 PM | #1 |
1969 Painted Grille???????
Any one Paint there 1969 Grille???? Lets take a Look At Them. I cant seem to find any one who can Restore it here in Texas go Figure.
05-10-2013, 11:17 PM | #2 |
402 BIG BLOCK
Re: 1969 Painted Grille???????
Chevy or GMC
1967 C10 swb 1970 GMC Jimmy 4x4 2005 Chevy tahoe Z71 2001 Chevy impala |
05-10-2013, 11:44 PM | #3 |
Why not just restore yours yourself properly, rather than painting over it? Here's my thread on how to do it
http://67-72chevytrucks.com/vboard/s...le+restoration Posted via Mobile Device |
05-11-2013, 07:12 AM | #4 |
1969 Custom 30 wrecker
I just recently did the one for my 69 wrecker. I went through years thinking these were black but learned they were actually a gray color.
I matched the gray color of my original as closely as I could to what was on my shelf. Summit stainless steel was the winner. (no longer available btw) The ends were painted black so I redid those in semi-gloss Krylon. I think it looks pretty sharp.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
05-11-2013, 07:21 AM | #5 |
The Niner
^^Nice job Bob!
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
05-11-2013, 09:32 AM | #6 | |
05-11-2013, 09:34 AM | #7 | ||
"I ain't nobody, dork."
That looks factory mang!
Gary
05-11-2013, 09:43 AM | #8 |
Oh, and to further complicate things, reproduction GM outer grilles were painted differently than factory grilles that came on the trucks. On the reproduction grilles, there was a black square painted just outside the marker lights on either side, as you have done. On factory original grilles, there was no square, and instead the lines carried over. Also, the upper and lower vertical line paint stayed inside the indentations, rather than filling it and creating an edge above and below.
What you did looks awesome! Just clarifying for anyone trying to get it exactly as it rolled off the assembly line Posted via Mobile Device |
05-11-2013, 12:14 PM | #9 | |
Every original 69 inner grille I've seen (as well as mine when the truck was new) had the "upper and lower flat edges", as you refer to them, painted silver/gray to match the egg crate portions as bobs409 has done. The 70 inner grille was all black plastic (not painted) with 6 raised sections on each horizontal egg crate bar which were silver or chrome. The outer grille Bob shows is as you describe in post #8, but factory replacements as early as 1972 were, as you correctly noted, different from the originals. I know this as a fact since mine had to be replaced in 1972. This was/is not just the reproductions currently being sold. Last edited by FirstOwner69; 05-11-2013 at 12:26 PM. |
05-11-2013, 02:02 PM | #10 | |
Also, here's a close up of an original '70 grille insert, that shows both the channel grooves, and the black paint. I've verified this on a couple occasions with '70 grilles I've seen at the yard or purchased from the yard. Also note the black edges Posted via Mobile Device |
05-11-2013, 06:25 PM | #11 | |
But, since we are on this topic... As I said in my previous post I agree with everything you said about the outer grilles. I was only noting that as early as 1972 GM had changed the tooling and paint application on the outer grille service replacements. I also tried to describe the inner 1970 grille exactly as the picture you supplied. However, where we differ, is what the original 1969 inner grilles looked like. In 1972, after some clown took out the left front of my truck with his car, all GM could supply for the repair was the incorrect outer grille service replacement and a 1970 inner grille. I suspect that the inner grille in the picture with the box was a later GM compromise between the 2 years. It appears to be just like the current reproductions, which are also incorrect for either year. In fact, I bet if you look closely you'll see the raised areas on the horizontal bars are present which were silver on the 70s. I believe, and can verify with a quick junkyard check on Monday, that the 69 did not have the "steps" in the horizontal egg crate bars. I'll take a camera with me to get some pics. Also, I think if you look more closely at an original 69 inner grille, you'l see that what you thought was weathered black plastic was, in fact, weathered silver paint which is allowing the black plastic to show through. |
05-11-2013, 08:55 PM | #12 |
Painted outer grilles. Sorry guys.
05-11-2013, 09:14 PM | #13 |
You remember when drinking too many beers was a bad idea? Me neither. |
05-12-2013, 06:36 AM | #14 | |
Just to be "politically correct", the part your asking about is the "grill surround" which is the aluminum part.
05-12-2013, 10:39 AM | #15 | |
I'm also not sure about the theory that faded inner grilles turn black. Here's my original '69 grille before and then after. Here's the after shot Posted via Mobile Device |
