05-11-2013, 05:02 AM | #1 |
Gear Ratio Opinions
Ive got 2 different 12 bolt rears. 3.40 and 3.73. Truck has a mild built 350 with 700R4 trans and 295/50/15 rear tires (26" tall). Which gear ratio would be best?
05-11-2013, 07:43 AM | #2 |
Re: Gear Ratio Opinions
With that small a tire 3.40s would be good. They are almost 27" tall, have them on my car...
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
05-11-2013, 02:23 PM | #3 |
3:73s will make you go fast but use a lil more mpg than the 3:42.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
05-11-2013, 02:40 PM | #4 |
3.40 and even then you will be turning too much rpm on the freeway
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
05-11-2013, 05:42 PM | #5 |
Not with an OD tranny.
05-11-2013, 05:44 PM | #6 |
I missed that. Yeah go with the 3.73s then
05-11-2013, 06:47 PM | #7 |
I vote for 3.73.
That's what I have in my truck with the overdrive and I love it. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-11-2013, 06:48 PM | #8 |
I'd try 3.73's with that wide a tire the extra rpm would not hurt or may help a bit.
05-11-2013, 11:37 PM | #9 |
The few times I have come across these trucks at wrecking yard with an OD trans they all had 3.73 rear ratio.
What difference does the Width of the tire have to do with gear ratio?
05-12-2013, 12:16 AM | #10 |
3.73 it is...thanks guys.
05-12-2013, 12:33 AM | #11 |
The wider or heavier the tire a bit more rpm can help. On a friends C10 switching from 235/70/15 to 275/60/15 made a difference in acceleration, and took a couple mpg off the cruising. Then sometimes it doesn't make a difference, and I have seen it both ways.
05-12-2013, 09:37 AM | #12 | |
It makes no difference in the gear ratio at all...but it may have some effect on how the truck drives/feels. Wider and heavier tire/wheel combinations can put more load on the entire drivetrain, under-powered vehicles will notice this more.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
