Old 05-11-2013, 05:46 PM   #1
brisonac
puffin white smoke.. help!
the passenger bank was rolling out a lot of white smoke and the driver was a little. it was mostly only doing at it idle then it would go down at higher RPM's. pretty sure the heads are good, but not positive. had a little condensation happen and got a little bit of water in the oil, it was only ran for a little before I noticed it, then replaced as soon as I could. could the piston rings be stuck or bad? heads? gasket? I have the engine all tore down right now so I can change anything out if I have to, any input would help!
My Fleet:
1968 Mustang,1972 C10, 2002 Lincoln LS
Father and grandfater restored Fleet:
1957 Bel Air 2door convertable, (in progress)
1957 4 door post, (in progress)
1959 Star Chief, 1966 Impala, and many others
brisonac is offline   Reply With Quote
Old 05-11-2013, 05:56 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: puffin white smoke.. help!
Sounds like a head gasket that's allowing coolant to get into a cylinder.
FirstOwner69 is offline   Reply With Quote
Old 05-11-2013, 06:28 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Since you have the engine out: did you notice any areas of the head gaskets that looked damaged? Usually you can tell if there was a leak.
Also, since you have the engine torn down, take the heads and have them check to make sure they're not cracked and do a complete rework while in the shop. Save you a lot of problems later.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 05-12-2013, 04:55 AM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
Are any of the pistons clean? That is a sure way to tell that coolant got into the combustion chamber. Antifreeze will wash the carbon off. Something to look for.
TBONE1964 is offline   Reply With Quote
Old 05-12-2013, 11:09 AM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Dont forget to check the water passages between the intake and heads for a leak also.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-15-2013, 11:18 PM   #6
brisonac
crap, took the heads off and somehow a nut managed to get into the intake and blow a hole in the piston. scared the walls to, going to have to have it machined
My Fleet:
Old 06-07-2013, 08:16 PM   #7
2002RSX
I have white smoke coming out of my exhaust pipe as well. I believe it is the head gasket but never removed it before. Do i need to drain the oil before i remove my heads?
2002RSX is offline   Reply With Quote
Old 06-07-2013, 08:25 PM   #8
terry b
terry b's Avatar
No
terry b is offline   Reply With Quote
Old 06-07-2013, 08:36 PM   #9
68gmsee
Active Member
68gmsee's Avatar
It is possible that some of the coolant could have also gotten in the oil so if in doubt replace it. Otherwise it's not necessary -as mentioned above.
06 Trailblazer
Old 06-07-2013, 08:50 PM   #10
TBONE1964
Cluster King
TBONE1964's Avatar
You don't have to drain the oil before pulling the heads but you will absolutely want to do it before you fire the engine after replacing the head gaskets.
Old 06-07-2013, 11:47 PM   #11
black_sheep454
With a nut in the cyl it should have made some noise. Glad you figured it out and hope it fixes as easy as possible.
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
