Old 05-12-2013, 04:03 PM   #1
2mas
Question 1966 c20 vs. c10
Hi,
I've search but not found any info on this topic.
What is the main differences between the two versions?
And what issues or problems would I encounter if I choose
a c20 instead of c10 if renovating and adding airride, disk brakes etc?
br / Thomas
2mas is offline   Reply With Quote
Old 05-12-2013, 05:25 PM   #2
cb1965
cb1965's Avatar
Re: 1966 c20 vs. c10
C10 1/2 ton vs. C20 3/4 ton. 6 lug vs. 8 lug. most aftermarket stuff is for 1/2 ton trucks unless you use oem stuff. As far as airride it should be the same but im not sure.
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 05-12-2013, 05:45 PM   #3
2mas
Will a c10 disk brake conversion fit, with new dropped spindels?
/Thomas
Old 05-12-2013, 07:13 PM   #4
rideblue00
rideblue00's Avatar
No, half ton and three quarter ton parts don't interchage. C 20 trucks have heavy duty upper and lower front control arms. And a big rear axle. C20 trucks are usually a bit cheaper to buy. If you plan on changing the suspension anyway, look for a chevy truck from 1973 to 87 and you can use the whole front crossmember setup. There is some info out there for this change.
rideblue00 is offline   Reply With Quote
Old 05-12-2013, 07:59 PM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
c 20 used a the vulcanized rubber "shear" type of rear cab mount, often 1 or both are broken, they can be changed out to the c/10 style though.
Old 05-15-2013, 12:53 PM   #6
2mas
Hi guys,
Just purchased a c20 1966. Factory AC, big back window, custom cab, straight and complete, but with some rust... Also has 327 v8 with auto. Build sheet is included.
Also this one is going to Sweden for restoration, has a 1964 since before!
br /Thomas
Old 05-16-2013, 12:40 AM   #7
cb1965
cb1965's Avatar
congrats on the purchase!!. Now how about some interior and engine pics..
'66 chevy lwb c10
'65 chevy lwb c20
Old 05-16-2013, 01:00 AM   #8
2mas
he're are some pics of the truck.
How do you usually handle the 8 lug if you want nice wheels? should I rebuild to 6 or 5 lug? I guess the 8 lug is a bit unusual?
/T
Old 05-16-2013, 01:01 AM   #9
2mas
motor
Old 05-16-2013, 08:40 AM   #10
1963c-10
1963c-10's Avatar
2mas....great looking truck you bought. Has some nice hard to find parts and it looks like it hasn't been messed with to much. Great find.
1964 Short bed trailer
Old 05-16-2013, 04:35 PM   #11
2mas
Is it only the upper and lower contol arms that are differen in the front?
As I understand a c10 dropped spindel with 5 lug disk conversion will not fit?
Old 05-16-2013, 10:58 PM   #12
rideblue00
rideblue00's Avatar
No. However you may be able to buy the whole setup. Im talking about the upper and lower and the spindle as a set. The crossmember is the same on 1/2 and 3/4 ton. As for the rear axle, well just find a 5 lug setup. Others may chime in on which axle you may want as i havent done research on axles.
Old 05-17-2013, 09:11 AM   #13
billd5string
billd5string's Avatar
I'm pretty sure the crossmember is different between 1/2 ton and 3/4 ton trucks. The lower control arm mount for the c20 won't accept even a later C20 lower control arm because of design changes, so you can't just swap in control arms and spindles from a C10.
I just finished swapping a complete from crossmember/steering box/brakes/etc. from a 75 C20 into my 65 and it was a fairly straighforward process, just redrilling some new mounting holes. I'm pretty sure the easiest approach to go 5 lug would be the same thing, get a full front suspension from a 73-87 C10 and bolt it in.
65 C20 Fleetside longbed, 350, turbo 400, 8-lug disc brakes, power steering, air conditioning - Totaled by a guy running a red light. Pulling parts off the carcass for my next truck
billd5string is offline   Reply With Quote
Old 05-17-2013, 04:00 PM   #14
2mas
I'm shipping this c10 also, maybe I should do a swap of the parts between these?
Old 05-17-2013, 10:13 PM   #15
66Submarine
66Submarine's Avatar
Why not leave it a 3/4? Lots cooler than a generic "slammed" half ton, IMO. The late model GM "PYO" wheels look nice if you want aluminum wheels. And there are really a lot of 8 lug aftermarket wheels with the hot-rod 3/4 diesel / four wheel drive thing as big as it is, just do a google search.
Also, a 3/4 or 1 ton with OE stuff will handle and stop pretty nice as it is. I have a '65 C-30 myself as my current daily driver. As OE a '60-66 C-20 has 40% more brake area than a C-10 does.
66Submarine is offline   Reply With Quote
Old 05-18-2013, 01:40 AM   #16
2mas
You might be right. Dont where I'm going with this build. Guess I will start with the rust and paint and decide later.
Old 07-06-2013, 03:36 AM   #17
2mas
Hi, cant get this out of my head.
since i have these two trucks, what is yourcsuggestion on going forward. I really want air bagged, centerline smoothies. I want to keep the big window. Since I'm in Sweden I have issues getting parts. new parts ok over internet, but its always difficult to buy used parts over phone or email in US. (Could really use a c10 friend in Indiana/Michigan for parts.)
Option one: Swap 8 vs 6 lug between trucks and buy c10 5 lug konverion.
Option two: Re-drill 8 lug to 5 lug? and buy air ride that fits c20.
(Going to the worlds largest car meet today in Vasteras Sweden, look at www.bigmeet.com. At least they say its the largest, quite cool! 20.000+ US cars in one small Swedish city)
Old 07-06-2013, 07:08 AM   #18
19666Trucker
19666Trucker's Avatar
http://centerlinewheels.com/wheel_de...ehicle&data=11
they make the smoothies in 8 lug
19666Trucker is offline   Reply With Quote
Old 07-07-2013, 12:51 AM   #19
Captainfab
60-66 Nut
It is my opinion, that for what it sounds like you are wanting, you would be better to change to the C10 5x5 wheel stud pattern. You really do not need the 8 lug if you are not hauling heavy loads. Also the '66 C20 will likely have a low geared rear differential (high engine rpms at highway speeds). There is basically no aftermarket parts for those differentials. The C10, 12 bolt differentials have many aftermarket parts available.
Are used parts for '73-'87 C10's available in Sweden?
Old 07-07-2013, 09:08 PM   #20
factorystock
factorystock's Avatar
One is more muscular than the other. http://www.purplewave.com/cgi-bin/mn...?120822A/D4339
factorystock is offline   Reply With Quote
Old 07-08-2013, 05:34 AM   #21
2mas
I've actually found a c10 1985 that could be donor truck.
Br /Thomas
Old 07-08-2013, 05:43 AM   #22
2mas
Will there be different width in back and front if changing to eighties c10 set up? Will I need different backspacing when ordering wheels?
Old 07-08-2013, 06:51 AM   #23
bmur66
There are disk brake conversion kits for 8 lug C-20's. I think Performance Online has them. Good looking 8 lug wheels are available. I am fine with mine and don't plan on changing it. 4.10 rear end ratio is OK with me also. I quess it depends on what you want to do with your truck. If I was bagging it then maybe I would switch.
No Weak Links
bmur66 is offline   Reply With Quote
Old 07-09-2013, 01:12 AM   #24
Captainfab
60-66 Nut
That will depend on what diameter wheels you use and just how low you want to go. I would definitely use that '85 C10 to convert your C20 to a C10
Old 05-30-2015, 01:29 PM   #25
slsartguy
Question Re: 1966 c20 vs. c10
I just want to ask about my truck: Can I swap out the 1/2 ton suspension for a 3/4 ton to my C-10? As an artguy, I would like my truck to resemble the 3/4 ton I had years ago. I'm not going to haul any heavy stuff at all. I would to have 8 lug high profile/narrow wheels.
I really Dig this site! I'm very new to it and hope it's OK to ask a question and get an answer now an again.
Chuck
slsartguy is offline   Reply With Quote
