Old 11-22-2003, 10:47 AM   #1
special70gmc
special70gmc's Avatar
need wireing help
i just got the new wireing harness for hei and intturnal reg alt but since it tore the truck complely apart i cant remember how it hooks up. i hooked the purple wire to the starter as well as a 1ga cable from the batt. how does the rest of the truck get power? i have no power in the cab or anywhere except the starter. im deffenitly not the best machanic when it comes to wireing, but id really like to get this truck running soon. thank you -kyle
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 11-22-2003, 10:57 AM   #2
bpmcgee
bpmcgee's Avatar
There are two small wires -- a purple and a white I believe -- that hook up to the starter. One on each of the small posts to each side of the battery wire, but I don't remember which.
Also, there are a couple of wires on the other harness the other direction past the headlights, above the radiator, and hook to an insulated post on the fender next to the battery.
I'm not sure which one powers the cab, my memory says it's the one off of the starter, but I may be remembering my '75. My tiny brain again!
Brian
bpmcgee is offline   Reply With Quote
Old 11-22-2003, 05:08 PM   #3
gonebad2
Merciless Butcher
gonebad2's Avatar
Here's how you get power to the cab. There is a black plastic terimal on the front of the passenger side fender. There is a wire that comes off the positive battery cable hook it up to the terminal on the fender. Ther is a heavy red wire that also hooks up to the fender terminal. This heavy red wire is the wire that runs power back to the cab. If you are using and HEI, there aore only two wires you need to hook up to the starter. The heavy purple wire and the positive battery cable. The heavy pruple wire hooks up to the terminal on the starter solenoid that is closest to the engine block. You can discard the yellow wire that was hooked up to the coil and the other terminal on the starter when you were using the points ignition.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 11-22-2003, 06:45 PM   #4
special70gmc
thanks guys do you happen to have any pics i think i can get it now but some pics would help thanks -kyle
1958 belair 2door
Old 11-22-2003, 06:48 PM   #5
john
member #16
john's Avatar
Here you go. http://www.geocities.com/chevroletc1070/wiringdias.html
john is offline   Reply With Quote
Old 11-22-2003, 07:22 PM   #6
gonebad2
Merciless Butcher
gonebad2's Avatar
Sorry Kyle,
No pics. I went with a painless wiring harness. It's a little different.
Thanks, Greg
Old 11-22-2003, 08:58 PM   #7
Tuck
is this what you want a picture of? Sorry its a little dirty. its wet sand residue.
Tuck is offline   Reply With Quote
Old 11-22-2003, 09:46 PM   #8
truckresq
truckresq's Avatar
everything you need....
Is right here
http://67-72chevytrucks.com/vboard/s...threadid=13698
John
Sacramento Area
1969 C10 Fleetside
truckresq is offline   Reply With Quote
Old 11-22-2003, 10:20 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The second wire mentioned for the starter should be deleted on your truck since you have HEI. It would have been yellow and would have gone from the R terminal to the Positive on the coil...but that don't matter.
The purple wire goes on the S terminal of your starter.
The rest should be like in the picture.
Old 11-23-2003, 10:22 AM   #10
special70gmc
thanks allot guys -kyle
1958 belair 2door
Old 11-23-2003, 12:32 PM   #11
special70gmc
just want you to know i got it workin not running yet but i got power and i cranks! im sooo happy almost ready to run after 1 1/2 years takin this slow so i dont screw up my LT-1 trhanks -kyle
1958 belair 2door
