Old 05-13-2013, 08:11 PM   #1
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
49 5 window frame mod/swap questions...
What's up guys ...
I have a childhood friend of mine that has a 49 truck sitting for almost 20 yrs, and is gonna want to build it soon.
Plans are to run current patina on truck, SBC, and lay the truck out.
Along with the truck, he has a 78 Camaro front clip.
He's set on running that clip. I told him go with aftermarket, or even S-10...
But, he's a stubborn ol greenhorn ...
Plans are to run a steelwheel, with a fat white wall...with a standard offset look.
Not sure if the track of the 'maro clip will be right for that truck.
Typically the clips are positioned under truck frame, right ??
We want to lay frame/fenders with this truck ...
Ideas ? Thoughts ?
I can fab...just need to be prepared......besides, I'mma 60-66 guy !!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 05-13-2013, 08:19 PM   #2
let it loose
let it loose's Avatar
Re: 49 5 window frame mod/swap questions...
I'm doing a '49 five window myself. I had a '54 with a 1978 Camaro sub-frame done by the previous owner. It was positioned underneath the truck frame as you mentioned. Personally I would like to try the S-10 frame but I'm sure others have good ideas for you.
let it loose is offline   Reply With Quote
Old 05-13-2013, 09:54 PM   #3
G&R's57GMC
G&R's57GMC's Avatar
Speedway has a bolt in IFS for that truck.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 05-13-2013, 10:58 PM   #4
mr48chev
mr48chev's Avatar
I'd convince him to sell the Camaro stub and go S-10 or aftermarket crossmember. I'm not a fan of the laying frame nonsense anymore than S-10 frame swaps but in this case it simplifies things so much that it would be the way to go. Front and rear kits and or front and rear setup info is so easily available for the S-10 Chassis Where getting everything right with that Camaro stub is going to be an effort and it still may not turn out as he expects.
On the other hand he could buy a complete MII setup that was already engineered for bags and had the bags with it and you wouldn't be up to your elbows in fabricating a bagged setup for what ever chassis he does use.
My ongoing truck projects:
Old 05-14-2013, 01:10 AM   #5
parkwood
parkwood's Avatar
I will go along with Mr48 and go with an after market Mll front end with bags if he wants to go low... check out my build and you can see how nice a Mll front end can go in.. plus then you don't have to make mounts for the fenders and the whole front end..
parkwood is offline   Reply With Quote
Old 05-14-2013, 01:30 AM   #6
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Right on fellas, thanks for the info ...
I will pass this info on to him, and report back
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-14-2013, 11:01 AM   #7
mr48chev
mr48chev's Avatar
I have had two vehicles that were subframed, both my 48 at one time and my 51 Mercury coupe that I had for 32 years. While both drove great getting the front end sheet metal to fit and getting it fastened down right was a real challenge. For me on the 48 it was fit/trim/fit/trim on the inner fenders and other pieces to get it to set right on the subframe and get the hood lined up right and then it was a day's work to get the bumper fitted right.
Add to that I ended up doing a complete rebuild on both subframes under both rigs. That included all of the bushings, ball joints and several tie rod ends plus I had to swap out the steering box on one as it had been sitting out exposed to the elements for some time before I acquired it. Add to that I switched both from drum brakes to disk brakes. The financial cost to me wasn't that bad at the time as I had a good discount at the parts house and I had access to wrecking yards with friendly prices but The cost of a rebuild kit for a Camaro Subframe, steering box and replacement brake pieces may run into several hundred dollars if he needed much of it. He needs to throw that into the equation before he starts doing any swapping.
Old 05-14-2013, 11:59 AM   #8
rcrahn
rcrahn's Avatar
Review this with him John....think you'll like this approach
http://www.welderseries.com/blog/mus...ication-chart/
rcrahn is offline   Reply With Quote
Old 05-15-2013, 06:36 PM   #9
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I totally agree with you all.
He's looking at 100+ hrs for the Camaro clip swap....
I'm sure he will agree with me !
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-15-2013, 08:26 PM   #10
Bubba54
I have a 79 camaro sub frame on my 54. I think they are just a bit wide for the 47-54 trucks. I narrowed the stock a-arms 1 inch on both sides for better tire fit.
If doing it again, I would go s-10 or mustang II on stock frame.
Good luck on the build.
Bubba54 is offline   Reply With Quote
Old 05-15-2013, 09:20 PM   #11
parkwood
parkwood's Avatar
Attachment 1107839
I must say that took some balls to cut and weld the a-arms... did you lose any turning radius?
Old 05-15-2013, 10:10 PM   #12
mknittle
mknittle's Avatar
Fatman fabrication sells 1" narrowed tube arms but not cheap. around $600
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 05-16-2013, 01:18 AM   #13
65Ch3v3LL3
I can't say I'm a fan of any of these options. The S-10 requires some work to get the body mounted and more than likely you will need to rebuild the front end and do brakes anyhow. The Camaro clip really doesn't fit the truck and if he wants to lay frame then the subframe is going to hit first. The Mustang II front end is really not the best geometry out there either but the best of all the above choices. The Roadster Shop has a new weld in front independent suspension that has good camber curve, no bump steer, uses new Corvette spindles so you have a ton of brake options. It's really nice and well designed.
1952 3800 GMC
2008 Harley VRSCDX
2011 Road King Classic
2012 Sierra Denali 2500HD
1966 Datsun Roadster 1600
1965 Chevelle SS
65Ch3v3LL3 is offline   Reply With Quote
Old 05-16-2013, 05:04 PM   #14
Bubba54
I tig welded the a-arms about ten years ago. I havent drove it alot but they seem to have held up fine. The truck rides nice and i can turn the wheel all the way, without any tire interference.
