#2226 |
![]() ![]() Join Date: Nov 2008
Re: What Did You Do With Your Truck Today ?
#2227 |
Elev8r Man
Nope, my shop and my home are both in Glendora. My shop is next to Walmart off the 210 / 57 freeway interchange
1955.2 C4 Carry-all / Suburban ![]() 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. |
#2228 |
Oh sure, I know exactly where that is.
Posted via Mobile Device |
#2229 |
gotta love it when a plan comes together.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
#2230 | |
Elev8r Man
![]() ![]() Posted via Mobile Device
#2231 |
It's a complex complex?
![]() But seriously, if I get a chance I'll come by for sure. Posted via Mobile Device |
#2232 |
Elev8r Man
Lmao, didn't see that. I guess I should proof read my posts
#2233 |
I got the cutting and drilling done on my motor mounts. these bolt to my Camaro clip replacing the clamshell mount. I made them to use 70s Camaro shackle bushings.
#2234 |
Sorry, I didn't see this earlier. I WOULD have said next week, BUT I found out I have a leak somewhere, and I have water mixing with my oil....
So TWO weeks! ![]() |
#2235 | |
#2236 |
I know this probably isn't the right place to ask,
but has anyone used those E-brake cable repair kits you can buy at auto parts stores, to fix their brakes? |
#2237 |
big guy
![]() Join Date: Jun 2008
#2238 |
Thanks Ray,
They just didn't look right without holes. But next tome I will drill the holes BEFORE I cut the parts out. ![]() ![]() They replace these. the plate welded to the frame under the motor mount is to move the mount to the rear a couple inches. ![]() Last edited by mknittle; 05-16-2013 at 09:25 AM. |
#2239 |
All I've done is make a final parts list and start ordering today. The small detail stuff now like park lamps, a couple grommets and some new seals for the vent windows
#2240 |
Today I am planning on welding up my motor mounts. Then next week I can set the engine in the frame and finish the parts that bolt to the engine.
#2241 |
Ordererd weatherstripping and whiskers so I can finish up the doors. Found a great deal on the product, but oversize shipping killed me.
#2242 | |
polishing a turd
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
#2243 |
nice job!
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
#2244 |
I pulled the axels out and put new seals and lube in.
#2245 |
Made a windshield washer on/ off switch for my t f ala OrrieG put in place of the choke
Cable. - works v v well Thank you OrrieG Posted via Mobile Device |
#2246 |
What would you like to know?
#2247 |
#2248 |
Started painting the wheels today. Happy with the result although not sure with the one I've put back on the truck yet. Will post a pic when I yet them all done.
A white wall will make all the difference I think. Hard to paint chrome wheels but lots of scuffing with a wire wheel, etch primer, surfacer primer x 3 coats and a top coat x 3. Only a temp tidy up until I get new rims and white walls. ![]() ![]() ![]() Found a slight coolant leak and it doesn't look like its from the radiator hoses. Explains why my coolant level has been dropping over time. It maybe coming from the water pump but I'm not sure. I know little about these motors (or any for that matter) and I'm not sure how to positively I'd that the leak is from the water pump. Will pull it out tomorrow and have a better look. Not too much to replace but would rather not spend if I don't have to. Thought I'd replace the hoses anyway but they are a nightmare to find as well. Different ends going from the 50 radiator to the later SBC means different diameter ends. Anyone have ideas on this? Posted via Mobile Device Posted via Mobile Device |
#2249 |
Yea! Love it when a plan works....
#2250 |
Elev8r Man
Starting stringing my body lines and bed to cab to front end alignment, now ready to tighten it all down and start my sanding, buffing, & polishing.
