Old 05-15-2013, 02:08 PM   #1
marlo73
cutting lower control arm cups down
Starting to bag the front of my 73 c10 using the upper plate and lower cups which are a little over 2inches. How much can I trim off the cup to avoid rubbing if anyone has done before. Thanks
marlo73 is offline   Reply With Quote
Old 05-16-2013, 05:45 PM   #2
marlo73
Re: cutting lower control arm cups down
Wow!!!!!!!!
Old 05-16-2013, 08:15 PM   #3
king-918
king-918's Avatar
what kind of bags and pictures would help
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 05-16-2013, 08:52 PM   #4
marlo73
Dominators 2600 AVS upper plate lower cup kit the cups are 2inches tall now wanted to see if anyone knew how much I could cut them down without bag rubbing the arm
Old 05-20-2013, 08:06 AM   #5
wraprail
wraprail's Avatar
I cut mine down and guess what....they rub
wraprail is offline   Reply With Quote
Old 05-20-2013, 08:27 AM   #6
northeimcustom
northeimcustom's Avatar
i cut some to 1 3/8'' bags rub. put 2'' cups in they work perfect, thats with dominator 2600......
*^MY BUILD STORY^*
northeimcustom is offline   Reply With Quote
Old 05-20-2013, 10:51 AM   #7
marlo73
thanks for the replys i ended up leaving them at 2 inches and it worked perfect im about 2 inches from control arms touching the ground probally could be lower but when aired out im only able to go so far down till inner fender sits on tire i guess if i removed it would be on the floor
Old 05-20-2013, 05:34 PM   #8
northeimcustom
exactly the same with mine.... i removed the wheel wells and it pretty much is right at the inner part of fender i thought and wanted the control arms were going to hit the ground.....
*^MY BUILD STORY^*
Old 05-20-2013, 05:47 PM   #9
marlo73
Ok so you did remove inner fenders ? Once removed are you control arms on the ground
