Closed Thread
Old 05-15-2013, 09:34 PM   #1
dormat13
dormat13's Avatar
New Guy - Looking 4 some Power Brake Guidance
Hello All,
I recently bought a 67 c10 and have been doing some serious crash course research on the site and am looking to do a power brake conversion. I just got the booster and rod assembly needed for the conversion and after some thorough research I feel good about the upcoming switch from manual to power brakes.
MY Only Question Is: where have those of you that have done this very common conversion hooked up your vacuum line???
I guess I am going to do a search looking for some pics showing where it would go, but I figured i'd go ahead and shoot a post out in the hopes that some of ya might send me some helpful responses.
my mechanical skills are not that high so please excuse this question if it seems foolish to you. I hope to do as much work on the truck myself that I can...this seems relatively easy enough so I hope to complete it myself.
I have the parts coming in for a power steering upgrade as well..so hopefully when the time comes I can get some help in that area too if its needed.
I have a 350 in the truck if that helps in diagnosing where the vacuum line should go. I guess some pics would be great if anyone has any.
Thanks In Advance For Any Help/Recommendations Sent My Way!!
dormat13 is offline
Old 05-15-2013, 09:36 PM   #2
jjhare
jjhare's Avatar
Re: New Guy - Looking 4 some Power Brake Guidance
From the booster to the carb or intake.
1972 C10 CST LWB
jjhare is offline
Old 05-15-2013, 10:16 PM   #3
dormat13
dormat13's Avatar
ok. thanks for the reply - like I said, my mechanical knowledge is definitely on the low side, but i'm looking forward to expanding my know how with the new old truck!
I have an edelbrock carb (not sure which model or series) and based on some of the stuff I've been reading while looking for a solution, they apparently have a power brake port. not sure if mine does or not but will definitely check tomorrow.
would be nice if this was a "problem solved" discovery.
thanks again for the help
dormat13 is offline
Old 05-15-2013, 11:41 PM   #4
JOJABOY
Two pointers for you. One: Make sure you have a check valve on the vacuum line. Two: Don't tie the vacuum line in with any other vacuum accessories.
For example....don't TEE off the same port as your trans, PCV or anything. Try to go directly off the intake or the non-ported spot on the back of the carb.
JOJABOY is offline
Old 05-16-2013, 10:53 AM   #5
dormat13
dormat13's Avatar
Ok. I will definitely follow your advice. thank you.
Quick question, i'm hoping for some help on
the more I read about this conversion, the more I hear of people replacing the entire pedal rod assembly. well...I purchased a Brake Pedal Rod Extension Kit from summit racing (SUM-760125) with the hopes of not having to replace anything else. I was thinking that this would allow me to just use the trucks current brake pedal set up.
does anyone know if this should work or am I going to have to find a whole new brake pedal assembly?
I haven't posted pics before, but will attempt to include a pic of the extension rod with this post
dormat13 is offline
Old 05-16-2013, 02:08 PM   #6
Lattimer
Lattimer's Avatar
That should work fine.
Keep in mind that your pedal may sit a bit lower even with the rod adjusted out all the way. I had to lengthen mine to get the pedal to sit even with the clutch.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline
Old 05-16-2013, 02:12 PM   #7
Lattimer
Lattimer's Avatar
Bottom center on the back of all Edelbrock carbs is a port for power brakes.
You will just need an NPT to hose barb fitting.
Shawn
Lattimer is offline
Old 05-16-2013, 08:29 PM   #8
dormat13
dormat13's Avatar
great...preciate the tips.
well, this seems to be an easy upgrade, only issue I have is that the booster kit that I ordered from summit (its a TUFFSTUFF kit) does not line up and directly bolt in like I was told it would. if I were to drill into the firewall, the new bolt location would have one bolt coming into the cab right where the spring on the brake pedal is and one of them would have to bolt into the steering shaft bracket under the hood. not sure I want to do that.
is there any kit out there that anyone knows of that would be a pretty simple bolt in for my 67???
I've read of several different ways people have gone about this on here and honestly thought I had it set...apparently not.
dormat13 is offline
Old 05-16-2013, 08:34 PM   #9
dormat13
dormat13's Avatar
better yet...has anyone out there ran into issues with all 4 bolts not lining up??? if I can make what I have work, that would be nice. trying to go straight into firewall...no bracket
dormat13 is offline
Old 05-16-2013, 10:23 PM   #10
dormat13
dormat13's Avatar
after more reading, it does seem a bracket may be the best arrangement, possibly something from captainfab
dormat13 is offline
Old 05-16-2013, 10:26 PM   #11
JOJABOY
i just picked up a used booster, bracket and rod off a junkyard truck. isn't there a salvage yard in ozark or dothan???
JOJABOY is offline
Old 05-16-2013, 10:45 PM   #12
dormat13
dormat13's Avatar
I actually just moved here about two months ago so I haven't honestly looked around for any junkyards yet. I intended on looking one up today and going by while I was off but couldn't get around to it.
i'm sure there are some around though. i'll actually try and google some now and get out to one tomorrow.
are you aware of any similar vehicles that may offer something comparable to the bracket off of a 67-72 c10, or am I better off continuing the search until I find one of these trucks specifically...it's a small town, I just wonder what the likelihood of finding one around here is. guess I won't know until I go.
dormat13 is offline
Old 05-16-2013, 10:49 PM   #13
70cst
70cst's Avatar
Hey dormat13 ...
Just want to say to the forums and from Ohio.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline
Old 05-16-2013, 11:04 PM   #14
JOJABOY
There are a ton of members here that sell used truck parts too. You could always see if someone has what you need. Most will ship to you.
JOJABOY is offline
Old 05-16-2013, 11:06 PM   #15
dormat13
dormat13's Avatar
Originally Posted by 70cst View Post
Hey dormat13 ...
thanks 70cst.
very happy to be a new member of the forum and excited to finally be the owner of a c10.
looking forward to getting to know some of the other members and learning a wealth of knowledge regarding these trucks!
dormat13 is offline
Old 05-16-2013, 11:25 PM   #16
dormat13
dormat13's Avatar
i'm quite sure that I will indeed be purchasing several parts from members in both the near and distant future while working on the truck
dormat13 is offline
Old 05-16-2013, 11:41 PM   #17
JOJABOY
I've got a couple friends that live in Dothan. I'll ask them if they have any leads on parts and yards.
JOJABOY is offline
Old 05-17-2013, 12:11 AM   #18
dormat13
dormat13's Avatar
man that'd be great. I was wondering if you were familiar with the area after you mentioned Ozark...it's not really one of those cities many people have any idea about most of the time.
dormat13 is offline
Old 05-17-2013, 12:31 AM   #19
JOJABOY
Ain't that the truth.
JOJABOY is offline
Old 05-17-2013, 12:38 AM   #20
JOJABOY
Try the Truck Farm in Troy, AL
Truck Farm Salvage
12487 County Road 7, Troy, AL
(334) 474-3178 ‎
JOJABOY is offline
Old 05-17-2013, 01:03 AM   #21
dormat13
dormat13's Avatar
Try the Truck Farm in Troy, AL ‎
will do...thanks
dormat13 is offline
Old 05-17-2013, 01:55 AM   #22
pennhunter
pennhunter's Avatar
I purchased a booster and master cylinder from O'Reilly's and a Tuff Stuff bracket from Summit. It would have been nice if the bracket had an instruction sheet. After mounting it what I guessed was correct my mechanic neighbor insisted the master cylinder should tilt up, not down. We flipped the bracket and the rods didn't line up. It still is mounted upside down but I have since found a thread on this site and a picture. I printed both to end the argument with my neighbor and painter who agreed with him. I will mount it correctly this weekend.
If you get the Tuff Stuff bracket the pivot point for the lever thingy is on the bottom.
pennhunter is offline
Old 05-17-2013, 05:22 AM   #23
blazercrazy70
blazercrazy70's Avatar
Do you need a bracket I have an extra one I will sell. Let me know
blazercrazy70 is offline
Old 05-18-2013, 11:18 AM   #24
dormat13
dormat13's Avatar
what is it off of? do you know the spacing between the holes that the booster would bolt to? is the other side a good match up for bolting directly in on the 67 firewall?
dormat13 is offline
Closed Thread
