05-17-2013, 12:29 AM | #1 |
Tie Rod End Question
Installing a tie rod end rebuild kit on the '59. The threaded plug didn't want to go in any further. I assume this isn't a good thing. Any suggestions?
thanks |
05-17-2013, 04:29 PM | #2 |
Re: Tie Rod End Question
I tossed mine and went with the ball joint style
05-18-2013, 12:06 PM | #3 |
Are you sure that you removed all of the original components? FSM shows a plate, spring, first half of ball socket, the ball, second half of ball socket, and the threaded plug, starting from the inner most side. I believe from looking at the pic in the FSM that the two halves of the ball socket must be oriented correctly to fit in. I can scan the pic and post it if it will help.
05-18-2013, 12:23 PM | #4 |
Check the thread where the cotter pin holes go through the end they are probably boogered up. you may be able to work the plug back and forth with a big screwdriver.
If that doesn't work see Newkingfisher's post. |
05-18-2013, 06:44 PM | #5 |
05-19-2013, 02:01 PM | #6 |
Thanks everybody. I figured it out.
The kit came with inner 3 spacers; two short, one tall. I used a tall where I should have used a short. |
05-19-2013, 08:05 PM | #7 |
05-22-2013, 05:41 PM | #8 |
Arturo as in Arturo Bandini, perhaps?
05-22-2013, 08:49 PM | #9 |
Not even Arturo Sandoval.
