Old 05-17-2013, 02:57 AM   #1
blazercrazy70
blazercrazy70's Avatar
Van tilt column question any input
I have a nice van tilt column but I understand you have to shorten it or crush the inner part to have it shortened. Well asking for input on this or is it just a bad idea. Somebody mentioned before about crushing it takes the impact cushion out of it. But the columns in the truck would not have this if I am correct maybe not anyway looking for thoughts on using it or not and how do you collapse the column to make it or work
blazercrazy70 is offline   Reply With Quote
Old 05-17-2013, 05:45 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Van tilt column question any input
I always set the bottom against the shop floor and hit the top with a mallet to shorten them.
There is still some collapse left in the shaft after you shorten it if ever needed during a wreck.
As far as the safety concerns about the less collapse available after shortening, you'll have to decide if you can be okay with that or not. Keep in mind, earlier trucks had a solid shaft from steering wheel all the way to the box, so some collapse is still better than that by a long shot.
Tx Firefighter is offline   Reply With Quote
Old 05-17-2013, 06:48 AM   #3
uncle
Or you can get the amount you shorten it off int. shaft and have same crash amount.
uncle is offline   Reply With Quote
Old 05-17-2013, 07:54 AM   #4
OhioDan
OhioDan's Avatar
If you look at item # 26 on the pic, that's where the steer shaft needs to be shortened when you install a van column. There's 2 plastic (rivets?) in the shaft holding the 2 pieces together. Set one end of the shaft on the floor and smack the other with a BFH. Shorten as necessary. Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 05-18-2013, 04:00 AM   #5
blazercrazy70
Thanks guys sounds like a plane to me just was not sure where to use the BFH. Thanks alot
Old 05-18-2013, 01:28 PM   #6
WIDESIDE72
WIDESIDE72's Avatar
You will also have an issue with the location of the neutral satey switch on the van column.. IIRC it is too low for a truck. Do a search on the forum for for van column for details
WIDESIDE72 is offline   Reply With Quote
