86 ccswb build
Well I finally got to start on my Crew Cab Short Bed build found a 4x4 body and frame the day after I got a 2wd crew cab so now the plan is to take the best parts from the two trucks and make a nice daily driver.
Truck will have 454,th400 and np205 for now I would like to do a Cummins conversion but the funds for that are not in the cards at this time so that will have to wait a little while. The K30 the day I brought it home The K30 after installing the front and rear with lift The K30 after installing the front and rear with lift The 77 C20 the day I brought it home |
Re: 86 ccswb build
both trucks have a more rust than I would have liked to start with but here in Missouri they all seem to or are way out of my price range.
The front end is a 44 that came in the truck I pulled the motor,tranny,t-case,new stainless exhaust, wheels and tires from I scraped the rest of the truck except for small parts as it was a plow truck and it was rusted real bad. The motor is a Crate 454 w/15000 miles and the trans and t-case where redone at the time the motor was put in. I sold the motor,bed and wheels off the 2wd two days after I got it home so now my total investment in the 3 trucks so far including my short fleet bed for the project is $1300 minus what I can sell the parts I'm not going to use and scraping the parts that are not worth saving. When I get the 4x4 done I am thinking of build the other truck as a crew cab short bed 2wd possibly slamming it on the ground with a ls style motor and trans for a little better fuel mileage. |
Re: 86 ccswb build
Today was a busy day got the front and rearends mounted and got the frame cut down and welded back together still need to get a couple plates for the inside of the frame.
Re: 86 ccswb build
gonna be sweet...
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
Second Chance Program
Re: 86 ccswb build
Subscribed!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
