Old 05-17-2013, 10:36 PM   #1
hpcgmc
hpcgmc's Avatar
rebuilding steering column - what is involved?
The stock steering column in my 67 GMC is missing a couple bbs in the bearing that sits right behind the steering wheel. I dont want to spend $500 on a new column, and a tilt wheel isn't that important to me. I'm thinking of pulling the steering column, replacing the bearing and the rag joint, then reinstalling. Is there anything else I should be looking at?
1967 GMC 1500 SWB. Driving this truck since I was 14.
hpcgmc is offline   Reply With Quote
Old 05-18-2013, 12:35 AM   #2
69chevy lwb
69chevy lwb's Avatar
Re: rebuilding steering column - what is involved?
manual, 3 on the tree, or automatic column? there not too bad i think 3 on the tree is the hardest you have an upper and lower bearing you can replace them both if you like its good to clean it out then lube it up when assembling take care to keep all the parts in order of how they go together it will save a few min
69chevy lwb is offline   Reply With Quote
Old 05-18-2013, 11:36 AM   #3
hpcgmc
hpcgmc's Avatar
Sorry, I should have clarified- the truck has four on the floor, no tilt. Should I replace lower bearing? Will the bearings need to be pressed in and out?
Old 05-18-2013, 05:28 PM   #4
69chevy lwb
If its loose replace it mine was fine but I had already bought one I didn't press it on though I beat the old one to pieces to get it off and the new one went on pretty easy but I doubt it will need more than a good cleaning and lube
Old 05-18-2013, 06:15 PM   #5
SS Tim
SS Tim's Avatar
This is covered in detail in the factory service manuals, Section 9. If you don't have one, download and take a look at what is inside.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
SS Tim is offline   Reply With Quote
Old 05-21-2013, 10:38 PM   #6
hpcgmc
hpcgmc's Avatar
Thanks for the link to manuals, but i'm having some trouble getting them to open and download.
To change the bearing by the steering wheel, do I have to remove the steering column, or can I change that bearing with the steering column in the truck?
Old 05-22-2013, 01:24 AM   #7
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
you just have to remove steering wheel for that.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 05-22-2013, 04:25 PM   #8
1970 C10 MJW
1970 C10 MJW's Avatar
subd, anyone aware of where I can buy the parts to do this? I am in need of repairing mine
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 05-22-2013, 05:37 PM   #9
JointTech
JointTech's Avatar
LMC has the upper bearing.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=126
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
