Old 05-21-2013, 01:36 AM   #26
chevyman70
Re: Getting A/C going for first time on 5.3l
okay... after two different adapters, and using the stock fitting, I still get this... What am I missing?
chevyman70 is offline   Reply With Quote
Old 05-21-2013, 03:09 AM   #27
ls1nova71
ls1nova71's Avatar
Doesn't look lke the adapter has the step down part on it. Is it flat across the bottom? If it is , it isn't going to seal. How did you try the stock fitting?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-21-2013, 09:13 AM   #28
chevyman70
It's stepped. I used the hose that came with the compressor. I just sealed the other end so it wouldn't leak. I just wanted to see if it was the adapter or something else. The compressor is a 10s17f.
Old 05-21-2013, 11:03 AM   #29
ls1nova71
ls1nova71's Avatar
If it still leaked with the factory fitting, I would suspect you either don't have the right seal (o ring) or maybe the compressor is cracked or has a gouge around the seal surface that isn't letting it seal properly.
Old 05-21-2013, 11:18 AM   #30
chevyman70
That's what I am afraid of. I used new seals and used old seals and same deal.
Old 05-23-2013, 12:30 AM   #31
chevyman70
okay, so I took off the compressor to have a closer look. So it first I noticed a light cut on the high side, but it does not go all the way down to where the oring seats. Also checked how the fittings seat. The suction side seats well, but the high side has 1/8 of a gap between the fitting and the compressor. once I tighten it, it starts to move out of its seat. Has any one ever experience this? I tried the stock fitting as well as the adapter and they both fit the same way. Also, I noticed the pulley is slightly damaged, but it spins smoothly. I also noticed some trash inside the compressor, that can be flushed out, right?
Old 05-23-2013, 02:16 AM   #32
truckdude239
truckdude239's Avatar
If it was me id replace that compressor it was either droped hard or wrecked and theres no telli g the damage inside
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-02-2013, 09:52 PM   #33
chevyman70
Well, after a new compressor, I have cold air! So the high side on the compressor did have a small scratch on the seat which caused it to leak.
Thanks for everyone's input!
Okay another question, I currently show 35psi on the low side. It blows cold air and all. However, I don't see the clutch cycling. I have a trinary switch on the high side. Do I need more refrigerant?
Old 06-02-2013, 10:05 PM   #34
truckdude239
35 is good not all a/c compressorz cycle on and off if its blowing cold id leave it.
David fuller
2000 Tahoe 5.3l 378
Old 06-02-2013, 10:06 PM   #35
truckdude239
Btw i like to see 35-45 on the low side and 175-250 on the high side
David fuller
2000 Tahoe 5.3l 378
Old 06-03-2013, 12:04 AM   #36
chevyman70
Okay mine was 210 on high side, so I guess I am fine. Thanks!
