Old 05-21-2013, 01:39 PM   #1
jks67ss396
trans cooler line exhaust clearance
Guys,
Trying to button up the 5.3/4l60e into my 71. Im using the trailerblazer manifolds. the stock lines (from a 04 tahoe 4l60e) are half an inch from the exhaust manifold.
Is that enough clearance or should i take them out and bend them? What would be the minimum clearance?
Also, i noticed that these lines do wobble just a bit when installed in the trans.
They install with these little clips and just push on... Is that wobble normal? Do you guys have any play in yours?
thanks guys!
jks67ss396 is offline   Reply With Quote
Old 05-21-2013, 03:39 PM   #2
JJH Jimmy
JJH Jimmy's Avatar
Re: trans cooler line exhaust clearance
I could not get the stock lines to work with the trail blazer manifold or my custom cross member, so i used russell pro classic hose and routed them inside the frame rail. I also made a heat shield where they go over the top of the exhaust. The factory clips suck and they will wobble a bit. The second picture is the fuel lines over the exhaust. I could not find a picture of the tranny line side, but i am sure you get the picture.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 05-21-2013, 11:43 PM   #3
chev3600
chev3600's Avatar
I had the same issue with the stock cooler lines, so I got the trailblazer SS lines. they route differently to accomodate the SS manifolds.
wobble is normal, as long as it doesnt leak....
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 05-22-2013, 12:09 AM   #4
jks67ss396
where did you get the trailblazer ss lines? got a part number?
thanks!
Old 05-22-2013, 12:06 PM   #5
chev3600
chev3600's Avatar
I don't have the part numbers handy. I got them off ebay after getting the numbers from gmpartsdirect.com. I'll see if I can find the numbers...
Old 05-22-2013, 12:14 PM   #6
chev3600
chev3600's Avatar
Hopefully the right ones. 15817516, 15817502. Seller was "rockbottomauto"
Old 05-22-2013, 07:56 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I ran braided lines tight to the pan and forward to my cooler under the rad. It has only a tiny but less clearance, but it avoids crossing over the exhaust at any point.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-24-2013, 01:21 AM   #8
mcmlxix
Collector of Projects
mcmlxix's Avatar
You can buy some thermal heat sleves to cover the trans line... Summit sells them. You may be able to find some NASCAR/IMCA left overs on eBay too....
CLICK HERE
Rich
1972 K5 Blazer CST Click HERE
