05-22-2013, 01:52 PM | #51 |
Re: 1966 F100 Short/Fleen Full Stock Resto Build Thread
Amazing work, you never disappoint!
05-31-2013, 04:57 PM | #52 |
WOW great resto!
06-12-2013, 10:47 AM | #53 |
Thanks guys!!
We converted the oil bath on the '66 to a paper filter using a universal 9" round Mr Gasket air cleaner. The height is perfect to keep the outer lid in the right position. No need to fabricate or weld in upper/lower plates to seal the filter or hunt around for the right filter. The original fiber filter was falling apart so we didn't want any of it getting it in the engine. Also didn't want it backfiring and puking oil all over the detailed engine! Uncrimped the inner flange and cut the "spokes" around the edges to remove the old filter material that was disintegrating. I still need to remove the inner ring on the original lid for more filter clearance. The new air filter base fits perfectly over the original base. I will drill ~1" holes around the perimeter of the original base for easier air intake. Just enough of the stud sticks through for the wingnut. Finished up the mods on the air cleaner- drilling holes in the base for better air flow and cutting out the inner ring of the lid to clear the new inner filter. Then blasted and primed it with DPLF epoxy. The new fuel lines came in so they're installed with new stainless clamps.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
06-12-2013, 12:34 PM | #54 |
Very nice work!! Great attention to details that many will never even see
Posted via Mobile Device |
06-12-2013, 03:12 PM | #55 | |
Just painted/detailed the tie rods. Cleaned the boots with 3M adhesive remover to clean the mold release wax off, then applied Duragloss Rubber and Vinyl Dressing, before and after.
06-13-2013, 04:36 PM | #56 |
Air filter lid was sprayed with epoxy, minor dings filled and blocked flat, shot with high build, then flat areas blocked with 180, then wetsanded with 600. I sprayed it with the same single stage urethane we've been using, but added 25% flattener instead of the usual 33%.
06-13-2013, 04:59 PM | #57 |
You sir are the man..
06-14-2013, 03:25 PM | #58 |
Thanks Chad! I know you'll appreciate the next update... I wetsanded/buffed the air filter lid, didn't like the slightly dull finish.
06-16-2013, 09:53 AM | #59 |
Again.........Speechless.
Top notch work, John!
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
06-16-2013, 02:15 PM | #60 |
Tot Roddin'
Killer work!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
06-17-2013, 02:13 PM | #61 |
Thanks dudes!!
Stuck the repop decal on the lid. Can't wait to get the carb back from being rebuilt/restored so we can install it and the filter back on the engine.
06-24-2013, 04:16 PM | #62 |
The carb came back today and it looks great! Also picked up some NOS clamps for the heater hoses and water pump bypass.
Chucked the clamps in the bead blaster and lightly went over them to brighten them up a bit.
06-24-2013, 04:55 PM | #63 |
06-25-2013, 11:53 AM | #64 |
I'm just glad to be here!
WOW, I am amazed with your work.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
06-28-2013, 09:15 PM | #65 |
He only has one speed PERFECTION
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
06-29-2013, 10:47 AM | #66 |
That is AMAZING work!
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
07-01-2013, 04:04 PM | #67 |
Thanks dudes!!! I forgot to post these the other day, so here they are. We cut out the floor pans and started trimming the new ones to fit. The don't fit well and they're missing the upper outside edges so we'll have to make those and weld them on. The inner rockers are mostly good except for the very front area where the hinge pillar meets up and overlaps. Whoever designed the way the cab metal assembles was an idiot... and further cements the reasons why I'm a Chevy guy Screwed in over the original pans to mark the trim lines. Cutting the floors out. Making a template for the seat risor area. Right side inner kick panel rust. This area is a PAIN to work around, and the layers of sandwiched metal layers is impossible to fix without tearing out good metal around it. Upper kick panel edge along the toe boards. The floor flange that welds to the kick panel underneath the truck, this was missing completely on the new pans... :-roll The cab mount plates are solid. Lower kick panel edge from the outside. Drilled the spot welds... Making the new floor pan flange to weld to the kick panel. The inner rocker rust. Starting to drill the spot welds and separate the inner rocker from the other layered panels.
07-01-2013, 04:10 PM | #68 |
Started back on the right side rust repair today, got everything cut out and a couple pieces ready to weld back in.
Started by drilling the spot welds. These weren't welded to anything though... Separating the layers. Inner rocker out, exposing whats left of the kick panel layer. Inside half of the inner rocker. Making a paper template to fix the rusted spot. Template transfered to metal, and I rolled a bead along the spot what will be the edge once its bent. Bending the edge in the metal brake. Edge detail. Front edge folded up straight like the original piece. Both pieces bead blasted, marking the original for cutting.
07-01-2013, 04:14 PM | #69 |
Marked the lower cowl for cutting.
More hidden rust. Cutting out the kick panel. Floors, inner rocker, and kick panel rust completely cut out. Ready for sandblasting, priming, and fitting/welding the new panels. Fabbed and fitted the rear floor panel.
07-01-2013, 08:06 PM | #70 |
PROJECT 7DEUCE
Amazing work for sure... Keep up the good work your builds are always so informative..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
07-01-2013, 09:16 PM | #71 |
Wow, I'm thinking there's not a truck too far gone for you to bring back. Those look like complicated pieces to make with all those multiple bends and angles. I would love to be able to make panels like that.
07-02-2013, 09:55 AM | #72 |
That is a ton of work and a bunch of rust. Your work is top notch. I wish you were closer, I could have you do my cab for me...Oh Well, guess I'll have to learn from your work and pictures here...
07-02-2013, 03:08 PM | #73 | ||
Here's the build thread. http://www.thesamba.com/vw/forum/viewtopic.php?t=471779 Thanks Karl, yall are doing a great job on your son's truck!!
07-02-2013, 03:22 PM | #74 |
Made the passenger side kick panel today. Had a couple beads to roll in it and I had to form a curved 90* flange on one edge.
I started comparing the original inner kick panel on the driver side to the patch I made yesterday, and there were differences that I didn't catch. The passenger side was rusted away badly and the template I made from that didn't carry over the original shape well enough. So I made a new template from the driver side and made two new pieces, L&R. This shows the curved top flange that I made straight on yesterday's piece. Making the top flanges. Rolled a bead on the edge. Welding the flange to the new inner rocker patch. Smoothing the welds with a 2" grinder, being careful not to lose the details of the rolled edge. Sanded with the DA to smooth the grinding marks. Panel for the other side.
07-02-2013, 03:44 PM | #75 | |
I know most guys are brand loyal, done to the bone. I have had the "discussion" with the Ford guys about the comparison of the '60s Ford and Chevy trucks, and have laid out all the differences. EVERY aspect of the Chevy is better, from the suspension, the engine, the transmission, and the body structure. I will give Ford credit in one area, though. Whoever designed their door latches did a great job. You can go to any clapped out Ford in the wrecking yard, and the doors close and latch soooo nice. Other than that, their trucks are not even close.
