05-24-2013, 10:28 AM | #1 |
Turn Signal blows brake light/hazard fuse
I have a 1982 C10 Stepside. So I was driving home and turned on my left turn signal. Notice the radio was blinking along with my blinker. Then a pop and smoke! It turned out to be my brake light/hazard fuse. All other lights worked fine except for the brake lights/hazards. Tail lights still come on with head lights.
I was able to recreate the symptoms but only when the truck is in drive. It will not do it while in park. Both sides of the turn signal causes the radio to flicker and the battery voltage meter to dance! HELP PLEASE |
05-24-2013, 12:44 PM | #2 | |
Re: Turn Signal blows brake light/hazard fuse
05-24-2013, 03:38 PM | #3 |
It's probably shorted to the frame somewhere under the bed. THe whole tail light harness is nothing more than 4 conductor trailer wire with no covering held to the frame with metal clips. I had the same problems as you and spent a while chasing down shorts, eventually just replaced the tail light harness with new wire in split tubing.
05-24-2013, 03:55 PM | #4 |
I had a similar problem with my '77 it wound up being the turn signal switch wires in the column one had rubbed through got a new switch and no more issues...
Posted via Mobile Device |
05-24-2013, 05:15 PM | #5 | |
05-24-2013, 05:15 PM | #6 |
06-03-2013, 11:57 AM | #7 |
