Old 05-24-2013, 05:44 PM   #1
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Can you tell if this steering gearbox was changed or needs flared fitting adapters?
I just installed a new power steering return line on my '70 K10 steering gearbox because it was leaking at the fitting, to find out it leaks again. Pressure line seemed to be OK. After removing the line it looks like the steering gear may not be set up for the flared fittings like my hoses. It seems like there is a step on the internal brass fittings and not flared. I'm wondering if someone may have changed out this steering gear. I have seen where there are fitting adapters used for later model steering gears. Can you tell by these pictures if that is the case here? I tried to search but came up unsuccessful.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 05-24-2013, 05:59 PM   #2
68shortfleet
Re: Can you tell if this steering gearbox was changed or needs flared fitting adapter
Looks like it's set up for flare lines to me. But I bet the top line in the bottom picture is going to leak. The flare fitting inside appears damaged.
68shortfleet is offline   Reply With Quote
Old 05-24-2013, 07:55 PM   #3
mgchevyparts
mgchevyparts's Avatar
Looks damaged by an incorrect fitting that was previously installed
mgchevyparts is offline   Reply With Quote
Old 05-24-2013, 08:08 PM   #4
derotoreut
derotoreut's Avatar
The top fitting doesn't leak, it's the bottom one that does. I don't believe that they are flared inside.
~ Dan
Old 05-24-2013, 09:50 PM   #5
68shortfleet
Here is a link with a picture that clearly shows the difference between a "flare" fitting gearbox and an "o-ring" gearbox.
You have a "flare" gearbox.
http://forum.ih8mud.com/40-55-series...aw-ps-box.html
Old 05-25-2013, 08:24 AM   #6
derotoreut
derotoreut's Avatar
Then why won't the flare fitting seat? The mating surfaces are definitely different. When I put the hose on it's loose and doesn't fit like a flared fitting. The fitting in the gearbox is flat and kind of squared off like it should have an O-ring in it. Something is missing here and its just not right. With brand new lines it should seat if they are the proper fittings. I will try to post some better close up pictures.
~ Dan
