Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 01-25-2013, 01:41 AM   #26
Fw190d9
Re: 69 Blazer build
Finished interior pics
Fw190d9 is offline   Reply With Quote
Old 01-25-2013, 01:46 AM   #27
Fw190d9
Re: 69 Blazer build
Scored some new floor mats, plus changed out the window regulators, the originals were a bit wallered out. After test fitting the top again, I realized that it was missing the nut plates for the visor mounts. Without them the owner would get a lapfull of water every rainfall so I cut out an access hole, then glassed in a block of wood with the nutplate screwed to it. This way when the bolt in tightened down, it pulls on both layers of fiberglass, not just the bottom. Once the blocks were glassed in, I epoxied the cut pieces back in and glassed up the area.
Old 01-25-2013, 01:51 AM   #28
Fw190d9
Re: 69 Blazer build
Last but not least, I put the top back on and mounted the rear bumper with swing outs for gas cans and the spare tire. The bumper needed alot of surgery to fit right and I wouldnt recommend dealing the the manuf, Tactical Armor Group. very bad experience with them.
Old 01-25-2013, 03:57 PM   #29
72blaz
72blaz's Avatar
Re: 69 Blazer build
wow...sick ride...
1972 Chevy Blazer
Check out my build:
http://67-72chevytrucks.com/vboard/s...d.php?t=560741
72blaz is offline   Reply With Quote
Old 01-28-2013, 02:05 PM   #30
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: 69 Blazer build
Incredible project! That thing is all sorts of mean. Nice work.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 02-27-2013, 03:50 PM   #31
dazza
dazza's Avatar
Re: 69 Blazer build
well done!
Happen to have or could you give a quick diagram of how you have your battery separator wired up?
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 02-27-2013, 08:44 PM   #32
Fw190d9
Re: 69 Blazer build
I dont have the wiring diagram around but basically, its a big solenoid that is hooked up to the main battery on one side and the aux battery on the other. A small circuit board attached to the solenoid senses output from the alternator and battery voltage on both batteries. It will send charging current to the main battery first, then once it shows charged, it will charge the aux battery also. It also has a function that connects both batteries together when starting to get max voltage only if both show an acceptable charge. You can drain the aux battery with accessories like winch, stereo etc, and the main battery will stay fully charged and still allow you to start. Seems to work pretty well so far.
Evan Q.
Old 02-27-2013, 10:02 PM   #33
dazza
dazza's Avatar
Re: 69 Blazer build
Sorry Evan, didn't mean to have you explain its use, I guess I should have been more clear. I have a separator and I'm not so clear on the Aux. start connection. I have a basic diagram (that I don't where I got it from as I haven't worked on the truck in almost two years), but the diagram shows a connection from the separator to the alternator and I think that is for the 3v+ connection required for the Aux. start to function. Is this where you have yours connected?
Thanks,
daz
Old 05-21-2013, 01:49 PM   #34
gfreeze1025
gfreeze1025's Avatar
Re: 69 Blazer build
Nice build
I may have missed it. but what color is that. (IE color code)
I'm looking to get my Blazer repainted and I like the look of this one.
Also where did you get the carpet (custom or was it something from ACC)?
Gary
1971 K5 Blazer 350 V8
gfreeze1025 is offline   Reply With Quote
Old 05-21-2013, 07:22 PM   #35
Fw190d9
Re: 69 Blazer build
Gary, The color is 2010 GM torch red. the carpet was from ACC, great carpet and fit very well.
Evan Q.
Old 05-22-2013, 01:07 PM   #36
gfreeze1025
Re: 69 Blazer build
Evan Q.
Evan,
Thanks for the info. Your build has given me lots of ideas on what to do to my blazer.
I am just about to buy a vintage air kit and want to do what you did with the center dash ( double din and two vents)
I noticed the standard sure-fit kit for the blazer only has 3 vents (and two defrost) did you special order/custom build the kit, or was it a swap out to a 4 vent blower?
Thanks again
Gary
Gary
Old 05-22-2013, 06:52 PM   #37
Fw190d9
Re: 69 Blazer build
Gary, I bought 2 extra ball vents and split the center vent hose into 2 outlets. The vintage air works great.
Evan Q.
Old 05-22-2013, 10:02 PM   #38
elzombo
elzombo's Avatar
Re: 69 Blazer build
VERY nice work!
My '72 Blazer Rebuild
http://67-72chevytrucks.com/vboard/s...d.php?t=427586
elzombo is offline   Reply With Quote
Old 05-23-2013, 01:46 PM   #39
gfreeze1025
Re: 69 Blazer build
Evan Q.
Thanks Evan,
You ever consider sellling one of those center panels you fabbed up?
I'd like to do that to mine but I don't have tools. Willing to throw a little money at a fellow forum member.
PM me if you are interested.
Gary
Old 05-24-2013, 08:55 AM   #40
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: 69 Blazer build
Who is the member on here that did the restored center console?
Tom Vogel is offline   Reply With Quote
Old 05-24-2013, 10:13 AM   #41
Fw190d9
Re: 69 Blazer build
Gary, I made 2 of those center panels, the other was for my Daughter's C10, (look for Project Estelle in the LSX swap forum. That about used up my supply of 1/8 aluminum plate. I still have the template I made so I can make another for Project "April" that Im doing with my son. I would be happy to make another for you when I make the one for April, might be a couple of months before I get to that though.
Tom, The forum member was VA72C10, However, I dont think he's doing them anymore as I recently PM'd him about another and he said he no longer restores them.
Evan Q.
Old 05-25-2013, 09:35 AM   #42
TonyJohnson
TonyJohnson's Avatar
Re: 69 Blazer build
Very nice work. That center panel is very cool.
Had to come back and add that the rest of the fab work and resto are excellent, as well. Very sweet rig!
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 05-25-2013, 10:36 AM   #43
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Re: 69 Blazer build
Awesome
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
