SS blazer a/c comp mount bracket question
just received a new SS trailblazer a/c compressor for my 68 c10 with a 2001 5.3. The compressor mounting holes don't line up on the factory 2001 a/c mounting bracket. I'm assuming that i need the SS trailblazer mounting bracket from probably a 2005-2007? The new compressor is a factory sanden trsa12b. The suction and discharge ports sit parallel to the engine crankshaft and are indexed point up high as this was my choice so i didn't cut the frame out. If i have to get the trailblazer bracket, does it have mounting holes on the front flange for the belt tensioner? Any help with pics and info would be great. Thanks, Brian F.
#2 | |
Proud owner of a 55.1 AD
![]() Join Date: Oct 2006
Re: SS blazer a/c comp mount bracket question
While researching putting an LS2 out of a 2006 Trailblzer SS into my '72 Jimmy. I would like to retain the TRSA12B compressor. Did you ever find a solution on a way to mount the TRSA12B compressor on you 5.3? Thank you, Bob |
I would like to know this too.
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
I imagine that the stock compressor bracket for the trailblazer compressor would work right?
1968 LWB C20 / AC / Wood Bed |
Like this one https://goo.gl/CWYSEK
Ah, and the lower portion bolts to the oil pan so a dropdown bracket has to be fabbed: http://67-72chevytrucks.com/vboard/s...8&postcount=36
1968 LWB C20 / AC / Wood Bed Last edited by crakarjax; 01-24-2017 at 04:41 AM. |
