05-25-2013, 10:25 PM | #51 |
Re: my 1965 C10
Oh my! That's NICE!
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
01-01-2014, 07:35 AM | #52 |
Re: my 1965 C10
i finally installed my amp in the truck. its a 4 channel Monolithic. for those that don't know Monolithic Sound Inc. is one of the most sought after old school amps by audiophiles and collectors. these are incredibly rare and quite expensive but the sound quality is better than anything car audio i have ever heard. so ever since the first time Ive listened to one in 1989 i have wanted a system with those amps. i also installed a 5 farad cap made by C.A.P. these are well known in the audiophile world also i rewired with new Audio Quest high end speaker wire. it took me a day and a half to complete but i wanted no wires to show once the seat was installed . just wanted a clean simple look plus the would be thieves cannot see anything special and it will be overlooked.also i did not want to drill any holes to mount the pieces because it would kill me to tear up this piece of history so i used 3M gray double sided adhisive tape. the stuff is amazing.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
01-01-2014, 08:12 AM | #53 |
Re: my 1965 C10
i will be installing this Monolithic monoblock amp in the future. i upgraded the power and ground wires on both amps. this amp we tested in my friends system against his new 400 watt bass amp and the 240 watt Monolithic sounded better had tighter bass and played louder and my amps are from the mid 1980`s.
02-03-2014, 08:52 AM | #54 |
Re: my 1965 C10
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ Last edited by corvettejim1968; 02-03-2014 at 08:57 AM. Reason: spelling |
02-16-2014, 08:14 PM | #55 |
Re: my 1965 C10
did some acoustic Fat Mat and some Dacron (pillow stuffing) in the doors today. made a big difference on the bass level and clarity. had to turn down the bass on the head unit to 0. it was set at +3.
02-23-2014, 11:20 PM | #56 |
Re: my 1965 C10
more upgrades to the system today. added the crossover ,swapped out the 5 farad cap for a 15 farad, also added a large relay and a small relay for the new cap. added a lot more Fat Mat at the back of the cab and painted over the primer white paint left from the big back window conversion.
03-02-2014, 10:04 AM | #57 |
Re: my 1965 C10
more upgrades to the system. took out the cheap china dash speakers and installed a 4in pair of Rainbow Audio. bought some foam cups for speakers and filled them with a little pillow stuffing for acoustics. also lined the underside of the dash with Fatmat. the system is really coming together now. it sounds great.
05-21-2014, 02:23 AM | #58 |
Re: my 1965 C10
The blue color on the lens is as close to factory as I have ever seen...,could you tell me where you bought the lens for your cluster ? Id apprecaiate it.
Always a place in my heart for old Chevy trucks: My build thread-project truck dream 65" http://67-72chevytrucks.com/vboard/s...d.php?t=510863 |
05-22-2014, 07:21 PM | #59 |
Re: my 1965 C10
i think i got it from Grumpy`s or LMC
06-10-2014, 05:19 PM | #60 |
I'm just glad to be here!
Re: my 1965 C10
Nice upgrades on your truck!
Are you worried at all about the Dacron (pillow stuffing) in the doors getting wet? Will it mildew if it gets wet?
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
06-10-2014, 07:33 PM | #61 |
Re: my 1965 C10
thank you. not at all i sealed the 6x9 in the door with 4-6 layers of Fatmat no water will get to it.
08-02-2014, 08:30 PM | #62 |
Re: my 1965 C10
today i installed my new Retro Sound head unit. it has
2 ...3.5mm input jacks 2... USB imput ports 6 pre amp outs ..front , rear, and sub Blu-Tooth and too much else to list. it sounds better than the old unit i had and plays louder too. i found some original backing knobs and modified the holes to work with the new style shaft. and bought some reproduction original knobs. turned out great.
12-06-2014, 12:34 PM | #63 | |
Re: my 1965 C10
Let me know please, Cheers, Ed.
12-06-2014, 12:44 PM | #64 |
Re: my 1965 C10
i think i got it from LMC. was like $49 or close to that
12-07-2014, 07:29 PM | #65 | |
Re: my 1965 C10
Thanks, Ed.
12-08-2014, 08:15 AM | #66 |
Re: my 1965 C10
no its really green. looks just like the original .
12-08-2014, 12:57 PM | #67 |
Re: my 1965 C10
So I am super jealous of your rig. I paid close to that for my 64 that is not in nearly as good of shape and needed a new motor. If you don't mind me asking how did you get your gauge cluster out? I have tried to get mine out and she doesn't budge. I know their are screws on perimeter but that's all I can find. I you or someone wouldn't mind walking me through the process I would be grateful.
12-08-2014, 01:28 PM | #68 |
Re: my 1965 C10
You know, I have the same problem with my 64. I removed all the screws and the speedo cable, but the cluster did not want to come out. I haven't tried too hard because I didn't want to chip or break it, so am anxious to hear any suggestions too.
Tim |
12-08-2014, 07:24 PM | #69 |
Re: my 1965 C10
it was disconnecting the hard oil line for me that made the difference.plus I disconnected everything else too.
12-08-2014, 09:49 PM | #70 |
Re: my 1965 C10
You have to remove the headlight switch, ignition switch, etc., and if your steering column is in place I believe that you will have to drop it out of the way a bit.
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
12-09-2014, 08:34 AM | #71 |
Re: my 1965 C10
yes everything comes out as one assembly. you cant tear it down until you can get to the back screws
07-24-2015, 07:41 PM | #72 |
Re: my 1965 C10
installed a 4 core Champion radiator , 16in electric fan, 195 degree thermostat, wire harness for fan, temp switch 190 degrees, and shroud. total cost $801 does not include paint and sand blasting.
07-31-2015, 09:00 PM | #73 |
Re: my 1965 C10
08-01-2015, 01:51 AM | #74 |
60-66 Nut
Re: my 1965 C10
Looking good
08-01-2015, 05:22 AM | #75 |
Re: my 1965 C10
Very nice. Great color choice!
