72 gmc k15 4x4...HELP lost brakes
![]() I was driving home from Virginia beach last weekend and lost all brakes, had to pump them to get stopped, wife did not like that ride home at all! I do have power brakes with brand new pads on the front and decent drums on the rear. My dad and I bleed all the brakes and still nothing. If I pump the brakes a few times then I get some brakes, but I'm lost now. Anyone have any suggestion as to where to look next, how to check the master cylinder and/or the brake booster? Posted via Mobile Device |
Re: 72 gmc k15 4x4...HELP lost brakes
It is most likely the master cyl. I would pull the rear drums first & make sure something hasn't come loose like a wheel cyl. rod not in the brake shoe. If the rear brakes are OK & adjusted up replace the master cyl. Remans are not expensive. Bench bleed it before you put it on. Pull the vacuum check valve out of the booster & make sure there is no brake fluid in it.
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
most likely the master cyl if none of the wheels are wet
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
![]() Join Date: May 2012
i agree with everyone else, you have a bad master cly.
#5 | ||
"I ain't nobody, dork."
Is it a stock engine? Or do you have a snotty cam in it with a lot of overlap?
Gary
Thanks for all the replies,
I took the check valve out to check the vacuum (was good) then I did have a little bit of brake fluid come out of the hole on the booster. Wiped it off and it never showed again. I have a basic 350 with bolt ons no internals. So no cam issues. I will try the master cylinder, as nothing is wet. I will post my results later this week, thanks guys! Posted via Mobile Device |
